Old 08-16-2014, 08:16 PM   #29
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Originally Posted by cnk View Post
60" between the front and rear jack points.
Contrary to popular belief, you do not have to use the stock jacking points with this type of lift. The reason you are told to use the jacking points with the stock jack is because the stock points have a cutout that fits the stock jack where the seam fits in the cutout and the jack actually contacts the flat area around the seams. Plus the contact footprint and the ground footprint of the stock jack is VERY small vs. the rubber pads and jack provided with the BL-3500/5000, so the stock jack has a much higher risk of bending the seam on the stock points and doing damage. The BL-3500/5000 or the Axis use a MUCH larger contact point with rubber pads and the ground footprint on the jacks is FAR larger so there is much less chance for movement and damage to the vehicle. As long as you have the BL-3500/5000 properly positioned and centered under the BRZ you should have no issues jacking the BRZ with the Ranger jack.
The video was jacking a BMW Z4 which has very similar dimensions and jacking points as the BRZ/FR-S. In fact both cars are the same overall length and the wheelbase of the Z4 is only 4 inches shorter.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
The Following User Says Thank You to Sony For This Useful Post:
cnk (08-16-2014)
Old 08-16-2014, 08:40 PM   #30
cnk
Drives: '13 DGM BRZ Limited
Thanks for the feedback. I've actually posted up a question about the necessity of reaching the jack points up on the garagejournal.com forums to see what others experiences are. I would honestly like to go with something like the BL-5000, P-6B or Atlas Kwik Bay 7000 if I could instead of having to do something like a MaxJax as I would then have to unbolt 1 of the towers after each use. Hopefully the feedback is in line with what you've already stated.
cnk is offline   Reply With Quote
car lift, jack stands, race ramp
How do you guys feel about lifted trucks? Guff Off-Topic Lounge [WARNING: NO POLITICS] 219 06-20-2019 01:24 AM
