Old 07-21-2014, 12:07 PM   #29
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
How would I check this?
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 07-21-2014, 12:42 PM   #30
marcoaferrer
marcoaferrer's Avatar
Drives: Whiteout FR-S
Originally Posted by deucethemoose View Post
I dont know why this picture made my day....
marcoaferrer is offline   Reply With Quote
The Following User Says Thank You to marcoaferrer For This Useful Post:
deucethemoose (07-21-2014)
Old 07-21-2014, 01:59 PM   #31
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Originally Posted by edeekeos View Post
Yeah, I tried retorquing the axle nut, to no avail. Also, for whats it's worth, I just went and did the rear deck popping fix. Original high piched pop still persists. I will be taking it to the dealer this coming weekend, and see what they think.
Re-doing the axle nut did not fix mine. They had to replace the entire thing. Its the metal getting cracked in the cv joint.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
edeekeos (07-21-2014)
Old 07-21-2014, 02:05 PM   #32
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
I do what I can.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 08-21-2014, 03:01 PM   #33
gonzo
Drives: frs
[ame]http://youtu.be/OZoN6mWBgro[/ame]
Does it sound like this? My dealer can't figure it out after leaving the car with them all day.
gonzo is offline   Reply With Quote
Old 08-21-2014, 06:10 PM   #34
stugray
Drives: 2013 GBS BRZ Limited
Mine is at the dealers right now for that very noise.
I swore it was a CV joint, so they replaced the whole drvs side axle.
They just called and said the noise did not go away.
So they are going to replace the wheel bearing next.
Here is my noise (sorry vid taken in the dark):
[ame]http://youtu.be/Yn8y8lnsHWA[/ame]
Old 11-24-2014, 04:02 PM   #35
gonzo
Drives: frs
So what was it? Mine is getting worse (clicks more often). Now sometimes it'll click twice in rapid succession.
Btw your video is private so we can't see it.
Old 11-24-2014, 04:29 PM   #36
DAEMANO
Time Traveller
I had the click in my left rear (for quite some time). It sounded just like the OPs video. It didn't get worse or better.
Recently I had some ARP extended studs installed. The mechanic had to remove the rear hubs. Install complete and now the clicking is totally gone. It's bee a couple of weeks now and the click has not returned. My guess, summin' is loose back der.
Old 11-24-2014, 06:31 PM   #37
stugray
They replaced the whole drv side half-shaft that comes with both CV ends.
The noise didnt go away so they replaced the wheel bearing.
Then the noise sounded better to them so they declared it fixed.
On the test drive, I told them they fixed the drv side, but now I could hear the pass side.
So they probably got rid of the noise on the drv side with the half shaft, and they were then hearing the pass side. So they changed the bearing when they didnt need to.
Now the pass side does it and it is getting worse, so I'll just wait until it's about to fall off before I take it back again.
I am convinced it is the CV joint.
Try the video again (it's just audio)
Old 11-24-2014, 07:22 PM   #38
M&W_FRS
Drives: FRS
Mine makes the same noise as in the video. The head mechanic at the dealership I currently have my car at swears its a normal noise from the drive shaft, but that doesn't explain why it only started making the noise 2 weeks ago after 18 months of ownership.
M&W_FRS is offline   Reply With Quote
Old 11-26-2014, 09:52 AM   #39
enivid
enivid's Avatar
Drives: WRB JR BRZED
Mine does that. I can get multiple clicks in a row. Can always hear it when pulling out of the garage or if I'm on the gas and release, it will click.
enivid is offline   Reply With Quote
Strange Noise from rear of car while OFF mike2100 Issues | Warranty | Recalls / TSB 23 12-17-2014 08:14 PM
Rear axle click when entering the car? kurbkilla Issues | Warranty | Recalls / TSB 10 07-01-2014 08:38 PM
Rear driver side clank and click spyingwind Issues | Warranty | Recalls / TSB 11 04-04-2014 11:26 PM
click, clank click sounds when cooling down and more? leaking oil? Boofneenee Issues | Warranty | Recalls / TSB 19 10-02-2013 11:27 AM
Click sound from left rear Tt3Sheppard Issues | Warranty | Recalls / TSB 1 09-25-2013 05:58 PM
