Old 07-28-2014, 10:23 AM   #29
mikepaul21
mikepaul21's Avatar
Drives: 2013 Subaru BRZ
What types or sizes of batteries are compatible with this WMI kit?
mikepaul21 is offline   Reply With Quote
Old 07-28-2014, 12:02 PM   #30
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
All batteries that can currently be used with our PTUNING Lightweight battery tray can be used with our WMI System. See below:
http://www.ft86club.com/forums/showthread.php?p=1190939
If you already own our PTUNING battery tray, we will offer the WMI kit minus the battery tray components. Since we designed our WMI system to use the modular PTUNING battery tray, it can be mounted directly to our WMI System without having to purchase a new tray.
MrC
Mrc@ptuning is offline   Reply With Quote
Old 08-22-2014, 01:14 PM   #31
ptuning
ptuning's Avatar
Drives: White FR-S
If you're relatively local to us and are interested in running our WMI system with the following forced induction kits, please contact us. We can offer the first customer for each FI platform a discount on tuning services.
Already taken:
PTUNING Turbo - 4 pending
Vortech SC - 1 pending
FBM, JDL, P&L, or MAP Turbo - 1 pending
Superchargers:
Innovate SC - available
Jackson Racing, Kraftswerks, or HKS Rotrex SC - first of any kit only
SC Notes: We would prefer cars running a higher than standard boost pulley to take full advantage of the WMI.
Turbochargers:
AVO Turbo - available
Greddy Turbo - available
TC Notes: We would prefer cars that are running a 3" exhaust system. We'll be targeting higher boost levels that are not achievable with pump gas alone.
Other notes:
You will need to run our custom machined WMI bung on your upper intercooler pipe. We can quote you for installation of this if you opt to have your WMI system installed with us.
We highly recommend installing an optional AEM flow gauge to allow for seamless integration with the factory ECU using our custom RaceROM maps. Otherwise, we'll tune your WMI system in standard fashion.
We'll likely only offer this tuning deal for a limited time during the intro period for our PTUNING WMI system.
- Toan
Old 08-22-2014, 04:12 PM   #32
Ryan P
Already taken:
Superchargers:
Turbochargers:
FBM, JDL, P&L, or MAP Turbo - first of any kit only
Other notes:
- Toan
JDL , in Richmond w/ 3" exhaust and gt3076 if it hasn't been filled yet.
Ryan P is offline   Reply With Quote
Old 08-22-2014, 04:47 PM   #33
ptuning
ptuning's Avatar
Drives: White FR-S
Done, shoot me a PM with details of your setup and we'll make it happen.
- Toan
Old 08-22-2014, 04:49 PM   #34
protpibe
protpibe's Avatar
Damn, if I was anywhere near Virginia, I would be all over this
Old 08-24-2014, 02:11 PM   #35
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Toan @ptuning would I qualify? I mean my system is more PTUNING than FA20 sans the turbo and header. I already have the WMI bung.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 08-25-2014, 02:08 PM   #36
ptuning
ptuning's Avatar
Drives: White FR-S
Yes, give me a call here when you get a chance and we'll make it happen for you too.
- Toan
Old 09-20-2014, 06:32 PM   #37
protpibe
protpibe's Avatar
Has anyone with the AVO kit had one of these installed yet? I want one for my car, but I would like to know what I'm getting into prior to dropping $1000 canadian pesos.
Also, does this replace the factory washer bottle? I was reading something on the website about the factory washer bottle baffle and the low fluid warning light? Anyways, some clarification would be great
Also, I have the FBM oil cooler kit mounted in my passenger side fender well, so I'm hoping it bolts into the drivers side and will clear intercooler piping.
Thanks
Old 09-20-2014, 06:53 PM   #38
mike the snake
I have a similar WMI system (Hydramist, basically Aquamist controlled by Hydra standalone) and I'm using the window washer bottle for the meth tank.
It holds a little more than a gallon, and works great.
Old 09-20-2014, 07:05 PM   #39
protpibe
protpibe's Avatar
Yeah, my brother has the same setup on his SC Tacoma. Ideally I would love to ditch my OEM bottle and use that space for the WMI pump.
Old 09-24-2014, 03:41 PM   #40
ptuning
ptuning's Avatar
Drives: White FR-S
Thanks
Our WMI System includes the AEM 1-gallon tank with new style conductive level sensor (most other companies are still using a float style sensor).
Our pump bracket has been designed to fit on both the driver and passenger side bumper beam (underneath it). Since the pump is tucked underneath the bumper beam arm, it should clear your AVO intercooler and silicon IC pipe just fine.
What will you get for $1,000 Canadian pesos?
- If you run the 1000cc jet with a 50/50 mix, you'll likely have the ability to tune for mbt all the way to 15-17psi. You won't have to constantly fiddle around with the timing to make the engine happy. The WMI provides immense detonation suppression and cooling, something that this ultra-high compression engine really needs.
Old 09-24-2014, 05:40 PM   #41
protpibe
protpibe's Avatar
Thanks for the info.
I'll post up pics of the install when I get it. Cant wait!
Old 11-11-2014, 11:34 PM   #42
kanundrum
Drives: 2013 Whiteout FR-S
Picked up the car from Ptuning today after their tuner worked their magic with the header and water meth. Car Pulls like a bat out of hell but still gets great gas milage (not under load of course). I need to upgrade brakes pretty fast now lol. As always thanks to @ptuning @Mrc@ptuning and crew for the amazing work!
ptuning, water meth
PTUNING: PnP Water/Methanol Injection System w/Optional Failsafe ptuning Forced Induction 121 09-29-2017 02:01 PM
Water Methanol Injection? NA application. hmong337 Engine, Exhaust, Transmission 12 07-16-2014 12:19 PM
AU GT86 Rear view camera Plug-n-play on Canadian (Pioneer) navigation system ? Simon99 Electronics | Audio | NAV | Infotainment 26 04-24-2014 04:38 PM
water methanol injection Silverdub Forced Induction 22 07-11-2013 03:58 PM
AEM WATER METH METHANOL INJECTION KIT JPxM0Dz Engine, Exhaust, Transmission 10 04-13-2013 11:03 PM
