Old 07-07-2014, 11:07 AM   #29
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Originally Posted by Sportsguy83 View Post
At least from quick research I did online on LS1 and LS3 weight, they seemed really close.
I still might be completely wrong....
Most of the weight is from the T56, which is towards the center of the car anyway if you place it right.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 07-07-2014, 11:20 AM   #30
Cross
It's the Mad Cow
Cross's Avatar
If you have oil in your engine bay, then my guess is that you "windowed" the block. I look forward to the details so I can add you to my list. @nelsmar is the only one I know with a built motor running relatively high compression, but I believe you two don't get along too well.
Don't think it would still run and not have oil all over under it leaving milky oil in the pan if it was windowed.
Decided to let the dealer puck it up after talking to the service manager I know and being up front. Because there is a tsb for the codes I have we shall see what happens.
As for LS1 vs LS3 the LS Series are all Aluminium. There are the LQ Series which are normally Iron but I do believe they can be found in Aluminium occasionally (Escalades) the 5.3 comes in both but that's not an LS1. They are all VERY similar and share/swap parts but I would be using the smaller 5.7L LS1 and it is all aluminium. Looks like I might just put some serious thought into selling my turbo kit and doing this...
Old 07-07-2014, 12:22 PM   #31
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
When the time comes ill be high comp. Even if I have to refine my own fuel.
Old 07-07-2014, 02:19 PM   #32
dabocx
dabocx's Avatar
Drives: Scion FRS
I think ill go in the 10-11.5 range, I have easy access to e85 so I dont have to go to low
dabocx is offline   Reply With Quote
Old 07-07-2014, 04:25 PM   #33
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
LS swap time @Cross. Keep us all posted to your findings.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 07-08-2014, 12:35 AM   #34
Dephective
Drives: '13 Whiteout FRS
@FullBlown do you guys have another bearing option other than new OEM bearings?
Pretty much everyone I see doing builds always have OEM bearings still and you would think this far in there would be something as simple as bearings...
Sorry to thread jack OP, but in my opinion, the LS1 will still have a relatively low center of gravity, being that it's push rod. Weight is just about where the FA20 + turbo kit would be. Like mentioned, most of the weight will be from the trans, which would be closer to center. I'll take a few more lbs in the center for a trans that can take a thrashing and not pop.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
Old 07-08-2014, 09:38 AM   #35
boarder1995
Drives: 2013 Subie BRZ Limited, black, 6MT
Don't know if this has been posted here, but these guys have done LSx swaps...
http://frsbrzperformance.com/tag/brz-engine-swap/
boarder1995 is offline   Reply With Quote
Old 07-08-2014, 12:52 PM   #36
xwd
That's the Weapons Grade car/kit which is fairly well known at this point. A couple others have done them as well, there is a shop in Atlanta here who just built a supercharged LS2? drift car. Vorschlag is also making a LSx swap kit, but they aren't that far into development so it will be awhile.
I guess your options may change depending on what the damage actually was, the block could be fine for all you know at this point.
Old 07-08-2014, 12:54 PM   #37
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Really upsets the balance......
This is my full interior, 17x9.5 275/40/17 Drag Radial equipped, Full bodied with lip kits and all FRS with a 6.6Liter LS2 T56 swap in it. Look at that cross weight.
Pure Automotive is offline   Reply With Quote
Old 07-08-2014, 01:11 PM   #38
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I don't think most people take into account the added weight of the transmission that you'll need too. Unless it'll be a highway puller or drag car, I'd rather stick with the FA20
Old 07-08-2014, 01:14 PM   #39
Reaper
Reaper's Avatar
Drives: violent
500 ft pounds of torque at 1500rpm is pretty nice though. I don't think any fa20 has hit 500tq period.
Old 07-08-2014, 01:19 PM   #40
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
http://www.ft86club.com/forums/showp...0&postcount=86
Old 07-08-2014, 01:23 PM   #41
Cross
It's the Mad Cow
Cross's Avatar
Alright LS1 Swap it is, time to sell everything off and get the remaining pieces aka Transmission and figure out how the hell the wiring is going to work.
Old 07-08-2014, 04:13 PM   #42
Pure Automotive
That weight is with the transmission in it already, its a finished running car.
'Sloane' - Cali first time build Re~Mix Member's Car Journals 6 06-24-2015 08:22 PM
The time attack build by Rob SavingManuals Member's Car Journals 8 04-27-2014 08:01 PM
Adventure Time! (E.Ts BRZ/86 Build) E.T Member's Car Journals 4 01-20-2014 01:02 AM
Frs300 Fa20club built motor and turbo build Frs300 Member's Car Journals 32 01-18-2014 05:27 AM
New FRS owner.. time for a build? sero901 Forced Induction 5 10-24-2013 09:40 PM
