#29 |
#30 |
Noob
Drives: FR-S Mammogram
So they're overproducing at the factory and spun it off into another venture?
#31 |
#32 |
Ridge Racerrrrrrrrr
Wrong forum here I think
| The Following User Says Thank You to SkAsphalt For This Useful Post: | DC2R (06-25-2014) |
#33 |
in orbe terrum non visi
Drives: violent
Sbd is a good company distributing for a not so moral company. OP doesn't know enough about cars to go FI and needs a bigger budget. I'm going to bed now.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#34 | ||
Noob
#35 | |
Be born with enough money and you don't have to know anything about anything. |
#36 |
Drives: violent
Ugh.
Anyway there has been two threads recently where greddy said zage does not make their kit. That zage copied it. Zage is in china and greddy says there's is made in Taiwan. Sbd smartly will not comment and now makes it very obvious they are a zage distributer and its not an SBD kit. Just something sbd sells. That's a smart way to avoid being sued. One member does claim his zage kit sold by sbd has a greddy elblem on it that was ground off. I feel like I'm one of the last people to build my car on jackstandsnin my driveway. Sent from my SAMSUNG-SGH-I747 using Tapatalk
| The Following User Says Thank You to Reaper For This Useful Post: | sshole (06-24-2014) |
#37 | |
Dismember
Drives: 2013 Red Scion FR-S
Oil pumps can fail on turbos, and they require tapping the oil pan, but a self-contained system requires its own fluid change and watching of fluid level. Cooling is also better through the engine oil. If a system has its own reservoir and cooler, it needs its own pump, lines, radiator, and so on. Lots more failure points. More importantly, there are superchargers that tie into the engine oiling system, and there are turbos that use their own lubrication. The whole point you made has little to do with the supercharger vs turbo question other than, maybe, what is the preferred method of cooling, and what is offered in mainstream kits.
#38 |
Drives: small
In a basic theoretical sense, it comes down to heat management (Turbo) versus more mechanical parts (Supercharger). In practical terms, it really comes down to the quality of the design and installation and whether the needs and capabilities of the driver are met.
I would do more homework before deciding based purely on input on this thread. Start with learning the basics of how an internal combustion engine works (air in, fuel in, mixture compressed, mixture ignited, piston rotates crank, exhaust out). Then learn how both FI solutions work so you can see what's being offered on the market so you can better process their designs and user feedback related to your needs. You don't need to have years wrenching on your car, but I would recommend a basic mechanical understanding of how your engine works before going FI. A few key things. Pay particular attention to how compression ratio and boost with valve timing and duration affect detonation and pre-ignition based on the fuel to be used in the car. Then look at the whether the stock rods and pistons (then transmission, axles, wheels and tires, etc.) will support your desired power output. |
| The Following User Says Thank You to Boxer486 For This Useful Post: | KGB (06-24-2014) |
#39 | ||
Small penis big dreams
Drives: '13 Scion FR-S
with that kit you're looking at 250rhp i had an exhaust and we maxed out the fuel pump on the dyno at 260rhp. throw in a fuel pump, and aftermarket injectors to get the most out of it. if you want a little more, you'll need a smaller pulley. for even more, E85 thats been my experience. i currently have everything but E85 and she's a blast to drive. its great for DD and having fun on the way to work or taking a spirited cruise. Quote:
we are here to help each other out, not bash.
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE 277hp 93 octane 370hp on E-85 |
| The Following 3 Users Say Thank You to draggin_az For This Useful Post: |
#40 |
Drives: violent
Ecutek with racerom is 800 $ not including dyno time.
#41 |
Drives: 2014 BRZ
thanks guys for all your helpful comments. Looks like I still have a ton of research to do. ill try to find a decent tuner shop in Vancouver BC and ask them for a advice also. Thanks again gentlemen.
#42 |
Drives: The silvertrooper 10 series
Also check out Kraftwerks kit, the C38 with a tune from delicious is and the most basic supporting mods is around 5K, over 300 whp around 400 on e85, but you'll need clutch with that. separate belt system so if a belt broke for what ever reason, your not stranded..
| FR-S / BRZ reliability stats | mkaresh | Scion FR-S / Toyota 86 GT86 General Forum | 82 | 03-12-2017 02:40 PM |
| Concerned with reliability... should I be? | hmong337 | Scion FR-S / Toyota 86 GT86 General Forum | 37 | 07-01-2013 07:02 AM |
| ECU Tuning for Reliability | regal | Engine, Exhaust, Transmission | 7 | 06-27-2013 07:07 AM |
| Scion top rated for reliability | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 10-29-2012 04:13 PM |
