Old 06-03-2014, 02:43 PM   #29
OrbitalEllipses
Drives: Attitude
Originally Posted by gramicci101 View Post
Interesting, thank you.
Z32 calipers are dirt cheap as remans too. You might even be able to find aluminum ones.
Old 09-08-2015, 01:50 PM   #30
rx3
I've been considering a slightly larger BK (e.g. Tarox B32 should save about 10 lbs in total).
Example:
http://www.factory-solutions.com/cms...r/DSCI0432.JPG
However, even with slicks I'd actually prefer more of a rear bias (and not more front bias).
Has anybody installed pads with a higher friction coefficient in the rear in order to work around this and if so what option did you choose?
rx3 is offline   Reply With Quote
Final Drive Calculations wootwoot Engine, Exhaust, Transmission 34 12-19-2014 04:06 AM
CHP bias ndsleep612 Northern California 11 07-28-2013 11:05 PM
Bad gas, station bias? Bg8780 Engine, Exhaust, Transmission 20 05-09-2013 02:52 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
Suspension Calculations mla163 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 10-18-2012 11:30 PM
