Old 08-12-2014, 03:45 AM   #29
ikkomaji22
ikkomaji22's Avatar
Drives: Subaru brz
Originally Posted by Candlejack View Post
Oh yes. She's freaking adorable. That's Lizzy.
__________________________________________
Rims went on today. Blue lugs! I love it more than I thought I would. Needs more low though. I'm thinking Eibach but I can't decide if I want Prokit (1.5") or Sportlines (2")--I don't feel like a 1.5" drop is enough...
i went with sport line springs and i love them! the drop is just perfect and the ride isn't as bad as i thought it would be. As far as camber plates and bolts you need to factor in expenses vs the price of actual tire wear.. For instance, if you purchase a set of tires around $800 so lets say $200 a tire and you lose 10% of the tire due to the degree of camber. thats equals to $80 over the life span of your tires (avg 2 to 3 years) ORRRR would you rather dish out the cash for a set of lower control arms for the rear, due to the lack of adjust-ability and camber plates and bolts etc... could run you close a grand... depending on the brand. So my opinion on this matter is that i would rather spend $80 on tire loss than hundreds of dollars on something that might not be worth it in 4 to 5 years when you decideto trade the car in for a next gen version lol.. just something to think about. I hope this helps
ikkomaji22 is offline   Reply With Quote
Old 08-12-2014, 04:11 PM   #30
TWMPerformance
Drives: Manual Transmission, All the Way!
Looks great!
Renato
Team TWM Performance
TWMPerformance is offline   Reply With Quote
Old 08-26-2014, 10:51 PM   #31
Candlejack
Ignorance Intolerant
Candlejack's Avatar
Drives: '13 WRB BRZ Limited
Niteshaded my DRLs today. Loving it.
Off.
On with Parking Lights
Off with Headlights
So shiny!
I'll take better pics tomorrow. Obviously there's light loss. But they're not for seeing anyways.
Candlejack is offline   Reply With Quote
Old 08-26-2014, 11:01 PM   #32
Kayysonie
Badass Member
Drives: 2014 SWP BRZ Limited
Off.
Off with Headlights
So shiny!
How'd you get them off? I saw this mod a while back and they had to take their bumper off. I've been wanting to do this.
Kayysonie is offline   Reply With Quote
Old 08-26-2014, 11:10 PM   #33
Candlejack
Candlejack's Avatar
lmao take their bumper off?! 3 clips in the fender liner, peel it back and undo TWO 10MM bolts. Unplug from the fog light and then from the wiring harness and you're done.
People are dumb.
HOWEVER I will say that when I took my driver side off, the bolts kept spinning and I couldn't figure out why. Then the light just kind of fell off and hung there and as it turns out the freaking molded-in-bolts had just ground their way out of the light housing. So I had to deal with that. Some JB Weld later and problem was solved but seriously I was pissed. The passenger's side bolts both came off with a loud pop when I first loosened them, but the molded-in-bolts held. It was a weird ordeal but an easy fix.
Old 08-27-2014, 02:02 PM   #34
Kayysonie
Badass Member
People are dumb.
I shall copy this mod!
Old 09-24-2014, 12:26 AM   #35
Candlejack
Candlejack's Avatar
I had my Passenger tail light replaced under warranty a couple weeks ago--condensation issues.
End of last week both of my fog lights and my Driver's tail has condensation in it. So they're getting replaced too. Yaaaaay. #annoyed
Old 05-17-2015, 11:48 PM   #36
Candlejack
Candlejack's Avatar
Forgot to update all this ish...
Tail-as-turn mod from @Diodedynamics
Awesome product!!!
Installed Bayson-R Front Lip and Side Skirts...
May 5 - May 11
Really need to get her out for a real photoshoot soon...
Old 09-08-2015, 10:24 PM   #37
Candlejack
Candlejack's Avatar
OEM Arm Rest Installed July 16, 2015
Old 09-08-2015, 10:31 PM   #38
Candlejack
Candlejack's Avatar
We had an FT86 Meet Up at one of our Member's shops near Detroit on August 16, 2015.
A bunch of transmission/diff fluid changes, a Perrin exhaust install, and my Eibach Sportline Springs.
Mid-swap:
Before/After comparisons:
_____
_____
_____
Old 10-18-2015, 03:45 AM   #39
Taimaishuuyo
Drives: 2014 BRZ
Great build!
Taimaishuuyo is offline   Reply With Quote
Gopherboy's WRB BRZ Limited - Build Journal Gopherboy6956 Member's Car Journals 41 03-22-2015 01:28 AM
White BRZ Limited Build Thread NoFlush Member's Car Journals 4 05-10-2014 02:04 PM
Digitalanalog's 13' GBS Limited build Digitalanalog Member's Car Journals 2 03-18-2014 03:46 AM
No Limit's DGM BRZ limited build thread No Limit Motorsport Member's Car Journals 10 05-10-2013 12:09 PM
Kohei's SWP BRZ Limited build BRZPDX Member's Car Journals 5 02-11-2013 07:04 PM
