Old 05-07-2014, 06:41 AM   #29
jeepmor
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Acetone absolutely will eat the plastic, use nail polish remover, conservatively.
jeepmor is offline   Reply With Quote
Old 05-10-2014, 12:12 AM   #30
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Anyone have more pics of success(perfect or close to perfect, no haze) and failures (haze, eaten plastic, etc.)?
fooddude is offline   Reply With Quote
Old 06-21-2014, 02:39 PM   #31
ZOMFGAARON
A Demon
ZOMFGAARON's Avatar
Drives: Raven GT86
Originally Posted by xrinnenganx View Post
If there is an SD card or some removable media from the head unit (maybe inside?) then it should be as simple as sticking it to you computer, finding the default image, and replace it with another one and rename it accordingly right?
It's not that easy, it's a locked firmware.
You have to tap into the software by cracking whatever code it's in then locating the image and reflashing it to the image you want. Making it simple enough for a DIY would take more time then it's worth.
Old 07-10-2014, 10:40 PM   #32
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Can't you somehow login using bluetooth to change the image. Like adding images to a camera via usb?
Chad86 is offline   Reply With Quote
Old 07-10-2014, 11:07 PM   #33
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
No...
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 07-11-2014, 11:47 AM   #34
Chad86
Chad86's Avatar
Drives: Toyota GT86
Originally Posted by Danklvr View Post
For those wondering how to remove the Scion logo from your headunit trim ring....
DIY at own risk
Acetone will remove this silk screened logo from the black plastic without discoloring the plastic. Takes a couple minutes wetting and rubbing, but it comes off relatively easily.
[ some members have reported that acetone has made the h/u trim ring appear faded, or scratched looking.
1 - Please make sure to thin down acetone with water if you have pure acetone - nail polish remover contains acetone but is generally to diluted already.
2 - make sure to use a cotton ball / q-tip / microfiber cloth / anything non abrasive to rub the silk screened logo off as to avoid marring the surface of the trim ring itself. ]
This has really complimented my Toyota rebadge, now to eliminate the Scion splash screen from the headunit boot up sequence..
Others are encouraged to post pics and feedback.
Anyone tried using Goo Gone? This seems to work for everything.
Old 07-11-2014, 02:00 PM   #35
NIN69
Izzy Gure (Senior Member)
NIN69's Avatar
Drives: FR-S TRD Release Series 1.0 / #1459
Acetone seem to be the fix from previous posts but use it carefully.
Visit me on Facebook:
http://www.facebook.com/izzygure
NIN69 is offline   Reply With Quote
Old 07-11-2014, 02:53 PM   #36
Danklvr
Danklvr's Avatar
try some goo gone and let us know the results!
Old 07-11-2014, 10:40 PM   #37
Chad86
Chad86's Avatar
Drives: Toyota GT86
I may just do this. I WILL use it sparingly though...
Otherwise
Old 07-12-2014, 12:32 AM   #38
kodyo
Drives: Scion FR-S
Goo gone is so weak as a solvent compares to acetone I doubt it will work.
kodyo is offline   Reply With Quote
Old 07-12-2014, 03:42 PM   #39
Chad86
Chad86's Avatar
Drives: Toyota GT86
Has anyone used a non-acetone nail polish remover? This may take longer but seems it will be less harsh, and hopefully won't damage the trim.
http://health.howstuffworks.com/skin...sh-remover.htm
Old 07-12-2014, 03:52 PM   #40
FRSure
Drives: Toyota
Or goof off?
FRSure is offline   Reply With Quote
Old 07-16-2014, 11:14 PM   #41
Dino451
Dino451's Avatar
Drives: Scion FRS/Whiteout/OEM spoiler
I just removed the scion from the head unit. Nail polish remover with acetone and a cotton ball did the trick. I had to do a little light rubbing but it all came off eventually. As soon as it was off I got a cotton ball with watered down dish soap and a damp cloth. Light coat of soapy water then rinsed with cloth. Then I hit it with maguires natural shine. Looks ok so far.
It did fade a bit with the nail polish remover so that's why I rinsed. After that it looked normal even after drying. I did the maguires to give it the bit of protection the plastic needs from the sun.
Whiteout 2013 FRS/ OEM Spoiler/ Clear side markers/TRD Intake/ Shark fin antenna/Rex speed blue wide mirrors/DD fog lights/Grimmspeed Strut bar/
Dino451 is offline   Reply With Quote
The Following User Says Thank You to Dino451 For This Useful Post:
NIN69 (07-16-2014)
Old 07-17-2014, 02:38 PM   #42
Dino451
Dino451's Avatar
Took this pic this morning of my results from last night. Forgive the dirty screen and song choice. In the light I see very very fine scratches from the rubbing but honestly its very hard to see and only up close.
head unit, logo, rebadge, scion, stereo
headunit splash screen. encity5 Electronics | Audio | NAV | Infotainment 21 08-11-2017 04:00 PM
Remove logo from FR-S OEM all-weather floormats? nalc Cosmetic Modification (Interior/Exterior/Lighting) 4 11-11-2013 06:11 PM
GT86 logo centered (replaced Scion logo) jacobzking Cosmetic Modification (Interior/Exterior/Lighting) 7 06-10-2013 11:13 PM
How to remove sync'd phones from headunit? ShoNUFF Electronics | Audio | NAV | Infotainment 3 01-09-2013 06:54 AM
