Old 04-21-2014, 02:19 AM   #29
retrosmiths
Drives: Scion FR-S Whiteout
Sorry, I'm just really confused by the purpose of this mod.
Sent from my phone. Might have typos. Sorry.
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 04-21-2014, 02:45 AM   #30
suaveflooder
air flow to….whatever. I his case an oil cooler
suaveflooder is offline   Reply With Quote
The Following 2 Users Say Thank You to suaveflooder For This Useful Post:
blackfireball5 (04-21-2014), hotpanda1 (04-21-2014)
Old 04-21-2014, 08:00 AM   #31
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
On top of my oil cooler, my car has a Full Blown Motorsports turbo kit. It gets a LOT hotter in the engine bay. So any kind of additional airflow helps.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
The Following User Says Thank You to blackfireball5 For This Useful Post:
retrosmiths (04-21-2014)
Old 04-21-2014, 12:07 PM   #32
retrosmiths
Oh, ok. I thought it was some sort of faux brake duct before lol.
2013 Scion FR-S
Old 04-21-2014, 12:20 PM   #33
blackfireball5
It very well could be adapted to be brake ducts by adding some tubing on the inside and directing it at the rotors.
Wheelwell Profile
Old 04-24-2014, 01:56 PM   #34
alpine
Not what you think
alpine's Avatar
Drives: 718 GTS 4.0
this looks great would love to do something similar to my BRZ when I get an oil cooler for the summer
alpine is offline   Reply With Quote
The Following User Says Thank You to alpine For This Useful Post:
blackfireball5 (04-24-2014)
Old 05-24-2014, 09:13 AM   #35
Lonewolf
Lonewolf's Avatar
Drives: Moped
Here is another potential twist on this DIY...purchase the side grills from Grillcraft and adapt to fit your needs:
The Following User Says Thank You to Lonewolf For This Useful Post:
blackfireball5 (05-27-2014)
Old 05-24-2014, 10:46 AM   #36
dp1
driving smoother faster
Drives: Sold
DIY: Making Air Vents Out Of The OEM Fog Light Bezels
So, on the driver side the opening is in front of the windshield washer fluid tank, and on the passenger side it is in front of the wheel well lining unless oil cooler or something else is installed there. Wonder if air going through the opening on the passenger side, at highway or track speeds, with nothing but the lining behind it, would push on the lining and deform it, causing tire rub? I had APR CF duct pieces installed and a bracket for a trans cooler pump right behind the opening, and had some wheel rub near full lock. May have been the bracket that caused the rub as it pushed against wheel well liner, don't know. Had both trans cooler and APR pieces taken out since and no more rub. In the OP application, doubt it would be an issue with the rad behind the hole.
I have the big center grille from Grillcraft to protect SC cooler, oil cooler and Koyo rad behind them, since it has smaller openings than stock grille. Bought the small side pieces also but won't install them since a new plastic piece with LED strips (DRL) is going in next week.
Just an FYI
dp1 is offline   Reply With Quote
Old 05-24-2014, 09:41 PM   #37
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
How much space is there between your oil cooler and the bezel? I was planning to modify one of these to provide the most possible airflow to the oil cooler, but a worried that there may not be enough room for it:
The shroud/duct is 6" deep.
OjiGeorge is offline   Reply With Quote
The Following User Says Thank You to OjiGeorge For This Useful Post:
blackfireball5 (05-25-2014)
Old 05-25-2014, 12:09 PM   #38
blackfireball5
Just an FYI
Interesting. I haven't experienced any issues with that.
Wheelwell Profile
Old 05-25-2014, 12:24 PM   #39
blackfireball5
Hmmm. I'll have to go look. I have a feeling you might have issues getting that in there. There's not much space. Then again, I was surprised I was able to get the 19 row oil cooler in there at all. Lol. The only thing might be the turn signal bulb on the inside gets really close to the oil cooler nozzle on the top of the cooler.
Wheelwell Profile
Old 05-25-2014, 06:32 PM   #40
OjiGeorge
OjiGeorge's Avatar
Usually I'd just pop the bumper cover off and look, but with front splitter attached it's no longer a 5 min process.
I'll probably buy the core, mount it up and reassess. It would be great to have a ducting kit for this. Might be time I learn how to lay CF and make something for the community.
Old 05-27-2014, 08:19 AM   #41
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
Why don't you guys just use RTV, takes time to cure but man, does it hold like a champ! we use it on our helicopter turbine engine sensors when we need to seal them up from getting moisture and water into them.
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
Old 05-27-2014, 08:32 AM   #42
blackfireball5
Never heard of it. Thanks for the suggestion! Maybe someone can give it a try and post their experience with it. I'm going to be redoing mine with JB Plastic Weld here shortly. I already purchased it.
Wheelwell Profile
**Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 nigel-jdmparts Exterior Parts - The Rest 524 02-28-2016 10:24 AM
WTB: fog light bezels natesparxxx Exterior Parts (Aero, Lighting, Etc.) 1 03-20-2014 11:44 AM
Pair of FR-S fog light bezels speedrye Exterior Parts (Aero, Lighting, Etc.) 2 02-21-2014 01:28 AM
Installing JDM Fog Light Bezels knewsom32 Cosmetic Modification (Interior/Exterior/Lighting) 13 01-22-2014 01:29 PM
Color matched fog light bezels NyC Zn6 Cosmetic Modification (Interior/Exterior/Lighting) 1 06-05-2013 12:10 AM
