| DIY (Do-It-Yourself) Guides For all DIYs. |
#29 |
Drives: Scion FR-S Whiteout
Sorry, I'm just really confused by the purpose of this mod.
Sent from my phone. Might have typos. Sorry.
2013 Scion FR-S
#30 |
#31 | |
Drives: Scion FRS Firestorm
#32 |
Oh, ok. I thought it was some sort of faux brake duct before lol.
2013 Scion FR-S
#33 | |
#34 |
Not what you think
Drives: 718 GTS 4.0
this looks great would love to do something similar to my BRZ when I get an oil cooler for the summer
#35 |
Drives: Moped
Here is another potential twist on this DIY...purchase the side grills from Grillcraft and adapt to fit your needs:
#36 |
driving smoother faster
Drives: Sold
DIY: Making Air Vents Out Of The OEM Fog Light Bezels
So, on the driver side the opening is in front of the windshield washer fluid tank, and on the passenger side it is in front of the wheel well lining unless oil cooler or something else is installed there. Wonder if air going through the opening on the passenger side, at highway or track speeds, with nothing but the lining behind it, would push on the lining and deform it, causing tire rub? I had APR CF duct pieces installed and a bracket for a trans cooler pump right behind the opening, and had some wheel rub near full lock. May have been the bracket that caused the rub as it pushed against wheel well liner, don't know. Had both trans cooler and APR pieces taken out since and no more rub. In the OP application, doubt it would be an issue with the rad behind the hole.
I have the big center grille from Grillcraft to protect SC cooler, oil cooler and Koyo rad behind them, since it has smaller openings than stock grille. Bought the small side pieces also but won't install them since a new plastic piece with LED strips (DRL) is going in next week. Just an FYI Last edited by dp1; 05-24-2014 at 10:57 AM. |
#37 |
Drives: White 2013 FRS
How much space is there between your oil cooler and the bezel? I was planning to modify one of these to provide the most possible airflow to the oil cooler, but a worried that there may not be enough room for it:
![]() The shroud/duct is 6" deep. |
#38 | |
#39 | |
#40 |
Usually I'd just pop the bumper cover off and look, but with front splitter attached it's no longer a 5 min process.
I'll probably buy the core, mount it up and reassess. It would be great to have a ducting kit for this. Might be time I learn how to lay CF and make something for the community. |
#41 |
Drives: 2012 WRX, 2003 RSX Type S
Why don't you guys just use RTV, takes time to cure but man, does it hold like a champ! we use it on our helicopter turbine engine sensors when we need to seal them up from getting moisture and water into them.
#42 | |
| **Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 | nigel-jdmparts | Exterior Parts - The Rest | 524 | 02-28-2016 10:24 AM |
| WTB: fog light bezels | natesparxxx | Exterior Parts (Aero, Lighting, Etc.) | 1 | 03-20-2014 11:44 AM |
| Pair of FR-S fog light bezels | speedrye | Exterior Parts (Aero, Lighting, Etc.) | 2 | 02-21-2014 01:28 AM |
| Installing JDM Fog Light Bezels | knewsom32 | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 01-22-2014 01:29 PM |
| Color matched fog light bezels | NyC Zn6 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-05-2013 12:10 AM |
