Old 04-08-2014, 12:31 PM   #29
Trettiosjuan
Drives: GT86
(nevermind, 17)
Trettiosjuan is offline   Reply With Quote
Old 04-13-2014, 07:11 PM   #30
makesdrivingfunagain
I heard someone mentioning 15" wheels. I was wondering about running a staggered set up, something like a 15x7 or 15x6.5 in the front with a 205/?/15 and a 16x7 wheel in the rear, say a 225/45/16 or a ?/?/16. I haven't heard of anyone running a 15" setup yet. I saw a NSX at the track the other day that gave me this idea. I was wondering what that would feel like with the stock suspension, as my budget is very tight right now. Running a 15" wheel could save weight and tire height. Has anyone done this? It sounds kind of radical to go this way. Many people go + 1 sizes 18" haven't heard of anyone going - 2 sizes...From a naturally aspirated point of view I need to save weight wherever possible. I am interested to hear any thoughts some would have.
makesdrivingfunagain is offline   Reply With Quote
Old 08-04-2014, 02:35 AM   #31
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
http://www.speedhunters.com/2013/01/...he-80s-trd-86/
Old 08-20-2014, 09:37 PM   #32
WedsSport SA-15R 16x7 48 offset 225/50/16
Old 08-21-2014, 12:02 AM   #33
Dihudaxia
Drives: 86
Are you guys here running 205's or 225's??
I am contemplating getting a set of 225/50/R16 tires for track use on my OEM 16' x 6.5J rims.
I reckon it may bulge slightly, but are there any negative effects on the track??
Based on what i read on other forums, 7J size may be the better choice but many users say running 225's on 6.5 size is ok, but they never mentioned anything about tracking on them.
Any feedback?
Dihudaxia is offline   Reply With Quote
Old 08-21-2014, 02:51 AM   #34
troek
troek's Avatar
Drives: 2012 Toyota 86
i tracked on mine quite abit with that combo. while not ideal, i never had any serious issues besides flexy side walls. i just upped the psi a little and i got pretty even wear at the track. i wished i would have just went with 205 though to tell you the truth.
Old 08-21-2014, 03:17 AM   #35
Dihudaxia
Drives: 86
Thanks for the quick reply.
Was also thinking of running stock 16' size. But good tires are hard to find in this size in SG.
And wont the amount of grip diminish significantly?
Just outta curiosity, stock diameter tires are 55, technically it would mean even more sidewall flex no??
Old 08-21-2014, 03:36 AM   #36
troek
troek's Avatar
The tires sidewalls will be sitting more vertically so maybe better stiffness. All the guys that run in the gazoo 86 racing series that have 16s run 205/55 here even on 16x7. I think i think the tire being more square on the rim results in the same contact patch as a pinched 225, minus the extra weight. From reading the more experienced drivers posts on here it seems the minimal grip gained could be offset by added rotating weight in the straits. But id love to see some numbers someday on same tire/car/wheel combo between 205 and 225.
The Following User Says Thank You to troek For This Useful Post:
Dihudaxia (08-21-2014)
Old 08-21-2014, 03:59 AM   #37
Dihudaxia
Drives: 86
Great. Thanks for your input.
Keep em coming...
Old 08-21-2014, 09:12 AM   #38
I would generally agree with this. As my tire sticks out a little from the edge of the rim (at 35psi cold). I wouldn't have minded to much to go with a 205. However, it may depend on what tire you go with. Some tires weigh more than others. I went with a Max Performance (according to tire rack) Extreme Contact DW Continental 225/50/16 weighs 21lbs (my scale it weighed a few ounces less and it weighs less than most 205/55/16. In this particular case the weight isn't there. Just my two cents. I may go 205 next time. I just don't want to add weight for the street car I have. It is more comfortable than the stock tires for the road in the US. It also looks more masculine than the stock wheels. The stock wheels with the Whiteout can be perceived as a bit "glittery" by some..
Old 08-21-2014, 09:26 AM   #39
Wayno
Wayno's Avatar
I wouldn't use a 225 on an oem 6.5". Next time i think i might go back back to 205 on my 16x7 too, just because of the weight. The RE002 is about 2lb heavier than the oem Yokohamas, and fun!
225 on 7" isn't pinched, it's noticeable wider than 205.
Old 08-21-2014, 11:37 AM   #40
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Any feedback?
For performance, the rule of thumb is that the tread width be +/- 1" of the rim width. With a rim width of 6.5", that has you looking at a tread width of 5.5" to 7.5", and using that criteria, most 205 DOT-R compound track tires are wider than is desirable. The 225s are quite a bit further out of the desired range.
In addition, while you have a 2" range to play with, it's generally considered a good idea to err on the side of: narrower tread-width tire on wider rim. This is because it provides a more stable platform due to the tread being as flat as possible and the sidewalls having as little flex as possible.
Because when running a wide tire on a narrow rim the tread is rounded enough that the full tread width is not on the pavement, the driver is losing grip not only in the corners but also during hard acceleration when starting down a straightaway.
Which brand and model of tires are you going to be using?
dradernh is offline   Reply With Quote
The Following User Says Thank You to dradernh For This Useful Post:
Dihudaxia (08-22-2014)
Old 08-21-2014, 08:39 PM   #41
I am running the 225/50/16 on the 16x7 wheel and I seem to bulge a little. However, Continental recommends running a 16x7 with this wheel. I am not an automotive tire engineer, so I think I should trust that this bulge is ok.
What PSI are you guys running on the street for the 225/50/16? What do you Guys recommend?
thanks
Old 08-22-2014, 01:19 AM   #42
Turdinator
Señor Member
Turdinator's Avatar
After I wore through the stock Yokahamas on my factory 16" wheels I went with Yokahama C-Drive tyres in the stock size. They are definitely more grippy and cheaper to boot but I don't like how soft the side walls are. Does anyone have a suggestion of a 205/55R16 with stiff sidewalls?
1974 TA22 Celica
2013 86 GT
"I put in WORK" **The Official Work Wheels Thread** mr. slim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 128 09-26-2016 11:42 AM
Is there a collective "stock parts weight" thread? Bullnettles Scion FR-S / Toyota 86 GT86 General Forum 1 05-28-2013 01:46 PM
WTB: OEM 16" wheels/tires or similar 16" skinny alloy wheels (USA, CA) smmmurf Wheels and Tires 0 04-05-2013 12:42 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
