Old 03-12-2014, 02:34 PM   #29
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
All of my US-spec tunes now use the B01 ROMS. I strongly recommend upgrading to this latest flash release as it contains all factory updates released to date, including DI seal issue, idle drop, etc.
- Bob
Circuit Motorsports is offline   Reply With Quote
The Following User Says Thank You to Circuit Motorsports For This Useful Post:
AZFA20 (03-12-2014)
Old 03-12-2014, 03:33 PM   #30
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
- Bob
So I just updated to the latest Software Versions from 14639 to the new 14761 and in addition updated the ROM database. For whatever reason my ROM database does not have the B01 ROMs, just the "A"s. The feature and license information does in fact show the B01 ROMs as supported but no B01 ROM files to build from.
Am I missing something?
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 03-12-2014, 04:19 PM   #31
1Cor10:23
1Cor10:23's Avatar
- Bob
Hey Bob,
Does running A01C create wear issues compared to B01C? Thanks!
Old 03-12-2014, 04:27 PM   #32
Circuit Motorsports
Unless EcuTek is doing something different for the professional suite which I am not aware of, you should have the B01 ROMs. Try running the update again. I've experience this where the first time I run a software update is just updates the software without ROMS, then running the update again picks up the new ROMS.
- Bob
AZFA20 (03-12-2014)
Old 03-12-2014, 04:28 PM   #33
Circuit Motorsports
Originally Posted by 1Cor10:23 View Post
Hey Bob,
If you are referring to the DI seal issue, A01C included the adjustments for that, so no, running A01C should be fine in that regard.
The Following 2 Users Say Thank You to Circuit Motorsports For This Useful Post:
1Cor10:23 (03-12-2014), forwallblakmail (03-12-2014)
Old 03-12-2014, 04:31 PM   #34
1Cor10:23
1Cor10:23's Avatar
Yeah just wanted to make sure...I think a few popular tuning solutions are still running A01C as the base so just wanted to see if there's any potential harm being done. Thanks!
Old 03-12-2014, 05:42 PM   #35
uncivilised
Drives: 86 GT
i have an april 2013 build 86, done 25000km on the clock, done 6 hard trackdays and countless mountain runs, no codes and no DI issues so far.
i have a mate with a june 2012 86 that got the DI issue on his second track day.
hope this helps
uncivilised is offline   Reply With Quote
The Following User Says Thank You to uncivilised For This Useful Post:
Old 03-12-2014, 06:40 PM   #36
AZFA20
AZFA20's Avatar
- Bob
I had tried updating a few times with no luck. I shot @EcuTek an E-mail in regard to it just to see if perhaps the retail version and the trade version are differing at the moment with ROM accessibility. Mine is also RaceROM BRZ enabled so we shall see.
Strangely the RaceROM feature files do include the B01 RaceROM feature but obviously I cannot add it without the base B01 ROM which is missing.
Old 03-13-2014, 02:05 AM   #37
regal
I literally just got finished switching all my maps over to the A01C ROM..
Why didn't you just flash the newer rom instead of all the copy/pasting, just curious.
@AZFA20 what are your thoughts on people still seeing DI seal being compromised with the A01C? A few people still hold to it as being a definite failure down the road.
Sent from my SGH-I317M using Tapatalk
Well there hasn't been one reported failure on this forum with a 2013 or later build date, fairly definitive. Also these injectors are used in other Toyotas and the DS-4 DI has been around forever. All positives.
Originally Posted by raul View Post
How often are you shifting aggressively (WOT-lift-WOT) through gears 3-4-5-6, shifting at redline?
This is what kills the injectors, some roads require you to drive in the upper power band on/off throttle. GSGMike said he could blow a DI seal driving this manner in 500 miles.
Originally Posted by jamesm View Post
the car spends most of it's time doing WOT pulls lol.
Those aren't a problem because you aren't making quick "transient" throttle changes at high rpm.
So no one has shared the B01 ROM's yet? I'm still trying to get my head wrapped around why it seems so difficult to flash these cars to the latest factory calibration.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 03-13-2014, 03:15 AM   #38
AZFA20
AZFA20's Avatar
I am not sure what you are using in regard to tuning and there may be some confusion because there is sort of different conversations taking place. The ROMs we are referring to are base ROMs. For someone like me who is highly modified there is very little left in the tables that are stock when I am done tuning so I have to start with a base ROM and build from there which for retail consumers requires the copy and paste method from my already built ROMs. Trade versions are slightly different with the comparison software that trade clients have access to (Basically for this scenario their life is made a little easier to transfer data from one ROM to another).
So to make sense of what we are referring to is more of an EcuTek understanding. I was given a B01C stock ROM this evening so now I will do the same as I did with A00,A01,and now B01. So an example of some things that change between revisions are min and max values in certain tables. The transient retard table for instance is a perfect example between A00 and A01. We could alter the tables but we were limited with the range of tuning if that makes sense. I don't want to get too technical because I don't know how familiar you are with what I am talking about. Denso along the way increases our ability to tune or simply build a better foundation from which to work with for lack of better words. If you just needed a stock reflash but you wanted the most recent revision there would be no need to do all the extra work that I have to do. In addition I have made a bunch of custom RaceRom maps so those all have to be added to the base ROMs also haha. Make any better sense?
Old 03-13-2014, 03:26 AM   #39
regal
Yes it mkes sense tuning has come a log way since I did with Honda's
My understanding was that none of the software had everything defined, so copy past you may miss something?
Also PM sent
Mods:
Old 03-13-2014, 03:31 AM   #40
AZFA20
AZFA20's Avatar
Also PM sent
Correct but only if you wanted to transfer say tables you already had previously modified on the previous ROM.
Old 03-13-2014, 03:36 AM   #41
regal
So EcuTek has everything defined, I thought there were thousands of table. You have got to be patient as all hell. A lot different than the Hondata days.
Mods:
Old 03-13-2014, 03:41 AM   #42
AZFA20
AZFA20's Avatar
Not thousands but several hundred once you add the custom maps to the equation haha. It's for sure time consuming but I have gotten quick at it. At first it was frustrating but in hindsight it literally forced me to become very familiar with all the maps and have made things easier for me in the long run
FR-S / BRZ reliability stats mkaresh Scion FR-S / Toyota 86 GT86 General Forum 82 03-12-2017 02:40 PM
Concerned with reliability... should I be? hmong337 Scion FR-S / Toyota 86 GT86 General Forum 37 07-01-2013 07:02 AM
ECU Tuning for Reliability regal Engine, Exhaust, Transmission 7 06-27-2013 07:07 AM
Scion top rated for reliability FRiSson Scion FR-S / Toyota 86 GT86 General Forum 7 10-29-2012 04:13 PM
