Old 03-05-2014, 05:04 AM   #29
Victor Draken
Drives: Toyota Gt86
Originally Posted by DriftHappens View Post
For anyone having the RPM stopping short issue, I found a fix. Change all of your throttle position values to 100. VD has an issue where it assumes non-WOT below a certain value (not sure what the value is or how to change that yet, im working on it). All of my TP values were hovering just above 90% above 4k or 5k rpm and it wasn't plotting those.
if the throttle is less then 92.63 VD doesn't count it as WOT.
Should we report it as a bug?
Victor Draken is offline   Reply With Quote
Old 03-05-2014, 05:18 AM   #30
DriftHappens
Drives: '14 FRS White
Can't hurt. However, if you go to File -> Options turn off TPS auto trim. You'll be good, but you'll definitely want to make sure you shave all non-WOT info from the log.
DriftHappens is offline   Reply With Quote
Old 03-05-2014, 05:25 AM   #31
Victor Draken
Drives: Toyota Gt86
Good to know. Now I just need to find a properly flat road, my VD charts show 185hp and is not possible lol.
Is it WHP or crank HP?
Old 03-05-2014, 05:52 AM   #32
DriftHappens
WHP. click the sae button so you can make corrections to barometer (if known), temperature, and don't forget to edit the weight, tires (if necessary). The more accurate the info, the more accurate the graph. Also, you may want to change the smoothing on it as well.
Old 03-05-2014, 05:57 AM   #33
Victor Draken
Drives: Toyota Gt86
Yeah I already did that. It's probably the road that is not good, need to find a better one. It's a problem around where I live ahaha
Old 03-05-2014, 07:30 AM   #34
wparsons
wparsons's Avatar
Originally Posted by bfrank1972 View Post
If you're pulling in higher gears wind resistance will probably come into play, no?
Virtual dyno has a frontal area parameter to take care of that.
flickr
Old 03-05-2014, 08:13 AM   #35
Victor Draken
Drives: Toyota Gt86
Originally Posted by wparsons View Post
^^ Virtual dyno has a frontal area parameter to take care of that.
what do you mean? if road is bumpy/not flat VD cant do much
Old 03-05-2014, 08:25 AM   #36
bfrank1972
Drives: 2013 FR-S Argento
I think he may have been referring to my post way back about wind resistance
Sent from my QMV7A using Tapatalk
bfrank1972 is offline   Reply With Quote
Old 03-05-2014, 08:40 AM   #37
Victor Draken
Drives: Toyota Gt86
that makes sense.
Old 03-05-2014, 10:10 AM   #38
wparsons
wparsons's Avatar
Yep, that's what happened. Edited the post to quote the proper post
flickr
Old 03-05-2014, 10:24 AM   #39
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
this is interesting. i gotta try this out later
Old 03-05-2014, 01:17 PM   #40
jeebus
Drives: 2015 Mustang GT (on order)
Here's another dyno of e85 after a few weeks of learning vs the same map shortly after flashing. Ignore the dip at the top, I hit a bump that triggered TC.
jeebus is offline   Reply With Quote
Old 03-05-2014, 08:33 PM   #41
wparsons
wparsons's Avatar
Originally Posted by Apoc View Post
I took a look at this too. Remove the empty rows so only the column headers are left. Now loading the files looks to have a problem with the column names so do the following. Rename "Time(s)" to "Time", rename "Engine Speed" to "RPM" and "Throttle" to "Throttle Position". It appears that it recognizes all column names and loads now.
If you want AFR to show in the graph, rename it to "Lambda (Bank1) (AFR)". Also, if anyone tries to modify the column headers to match an EcuTek log you'll find ridiculous hp readings, I think it's because there isn't a vehicle speed channel logged.
Now to go get better logs of full pulls (instead of lifting at 6700rpm) and see how they look!
flickr
Old 03-06-2014, 01:18 AM   #42
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
According to this my WHP is 34whp higher than stock BHP on e85 I'm not sure if it is 100% set correctly. I did select the BRZ right in the options and I verified things like the COD and weight from Subaru's literature.
Luckrider is offline   Reply With Quote
Data Logs! Post them here. feldy Software Tuning 2164 08-17-2026 10:43 PM
Anyone help interpreting data logs? cuddefred Engine, Exhaust, Transmission 8 10-11-2013 06:30 PM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
