Old 03-02-2020, 09:39 AM   #29
Originally Posted by Trap63 View Post
Hello @EZx2, do this mosfet control ground circuit in unit? or whatelse?
I solved carry on another ground point on main harness and insert a by-pass from door open/close switch, at now all works fine. I damaged circuit of map light working for new led door.
EZ hasn't logged onto this forum in 3 years so don't expect an answer. Maybe somebody else can reply though.
Old 03-13-2020, 12:32 PM   #30
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
Yes, that is correct. This mosfet does the switching for the ground circuit on the dome lights. It doesn't do anything else besides that.
Originally Posted by GJR726WY View Post
Yes the bulb is good, If I put it in the other door it will light up normally. I'm unsure what you mean by "harness behind the door panel". I haven't investigated anything further since eliminating the BIU.
What I meant was, take a look at the wires that are attached to the bulb socket. Make sure they are intact and there is no damage to them. You'll most likely have to remove the door panel to take a proper look at the wires though.
I pay more per month for insurance than I pay for the FRS.
itsAlex is offline   Reply With Quote
Old 03-19-2026, 02:32 AM   #31
Moto-P
Moto-P's Avatar
Drives: Many types of cars in R&D.
I know, very late reply.
But in that method, only difference is there is no pre-lightning of cabin dome lamp when doors are remotely unlocked, and there is no delay timer after you exit and shut the door. Yes it is ground control trigger, but the doors are not the only thing it is triggered by. Though, mostly that's fine for all practical purposes. Some people like the security of seeing inside the car before they get inside.
Moto Miwa
R&D Driving Engineer, Product Designs
Consulting for Cusco, OEM+, RS-R, Toyota Japan, and Unplugged Performance.
Moto-P is offline   Reply With Quote
FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! Diode Dynamics Interior Parts (Incl. Lighting) 158 08-08-2018 06:52 PM
<<< NEW Interior LEDs ~ FR-S + BRZ Domelight/Trunk/Packages (BRIGHTNESS OPTIONS)>>> KI_ZN6 Interior Parts (Incl. Lighting) 939 02-18-2016 11:02 PM
