Old 02-11-2014, 04:08 PM   #29
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by jamesm View Post
I got the wrx one, non-sti. The only difference is the included bracket I believe.
It is. That's the only difference. This has the STI bracket. Not that that matters for the BRZ.
^GT5 Replay Photo Mode^
The Following 3 Users Say Thank You to SirBrass For This Useful Post:
jamesm (02-11-2014), lbroskee (02-11-2014), Sportsguy83 (02-11-2014)
Old 02-11-2014, 04:19 PM   #30
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
BTW, sorry @Sportsguy83 for the thread jacking
dont hate me
lbroskee is offline   Reply With Quote
Old 02-11-2014, 04:24 PM   #31
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
dont hate me
It's all good. My build thread is more an off topic/random thoughts/chat room kind of deal this days.
The Following 4 Users Say Thank You to Sportsguy83 For This Useful Post:
jamesm (02-11-2014), lbroskee (02-11-2014), SirBrass (02-11-2014), whitefrs (02-26-2014)
Old 02-11-2014, 04:25 PM   #32
lbroskee
lbroskee's Avatar
ur build thread is the friendliest place on the dam forums
The Following 2 Users Say Thank You to lbroskee For This Useful Post:
jamesm (02-11-2014), Sportsguy83 (02-11-2014)
Old 02-11-2014, 04:52 PM   #33
SirBrass
SirBrass's Avatar
Now if only selling my Cobb APv2 were this easy...
The Following 2 Users Say Thank You to SirBrass For This Useful Post:
lbroskee (02-11-2014), whitefrs (02-26-2014)
Old 02-11-2014, 05:11 PM   #34
Sportsguy83
Drives: Limited BRZ
local Subaru FB group should be piece of cake!
Old 02-11-2014, 05:17 PM   #35
SirBrass
SirBrass's Avatar
Nope. None of them would bite. Well, one did, but he never showed up to get it (or to pay me).
Old 02-12-2014, 09:11 PM   #36
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
This is great. So basically this takes the aftermarket wideband o2 sensor reading and feeds it into the stock ecu? As you know im running a failsafe as well, does this then mean that the failsafe will no longer read the afr? confused on that part.
Also you said its for racerom users only, so does that mean i have to upgrade my software? OR will this still work for a tune from a master tuner?
gdrider77 is offline   Reply With Quote
The Following User Says Thank You to gdrider77 For This Useful Post:
Sportsguy83 (02-12-2014)
Old 02-12-2014, 09:15 PM   #37
jamesm
your gauge will still work as normal.. you use one of the other outputs to feed into the ecu (0-5v). your tuner would have to add a custom map to scale the output, then you'd log the result of the custom map just like you would with an ethanol content analyzer in a flexfuel setup (i.e. custom map m result or similar).
The Following User Says Thank You to jamesm For This Useful Post:
Old 02-12-2014, 09:38 PM   #38
Sportsguy83
Drives: Limited BRZ
Yes, like @jamesm said. If you are tuning the car yourself, you add a custom map that reads the output of the rear O2 sensor. You would need the BRZ RaceRom upgrade from Ecutek to be able to create custom maps.
The white wire coming out of your Failsafe harness is the Wideband analog output. You would connect that to the blue rear O2 cable. You will also need to connect the brown cable to ground.
As soon as your tuner creates the map and updates your tune to RaceRom version 7, you are good to go!!
You would then log custom map X (whatever map he assigned) and it will log your exact AFR
Old 02-19-2014, 02:33 AM   #39
spdbydesignchris
spdbydesignchris's Avatar
Drives: 2013 BRZ Premium
Are you using the rear o2 sensor ground to connect? or connecting to a chassis ground location?
Where are you wiring the 12V + switched?
spdbydesignchris is offline   Reply With Quote
The Following User Says Thank You to spdbydesignchris For This Useful Post:
xjohnx (02-26-2014)
Old 02-25-2014, 07:28 PM   #40
gdrider77
gdrider77's Avatar
Gonna do this tonight....got a new tuner lined up, and dropping the car off, wish me luck!
Sportsguy83 (02-26-2014)
Old 02-26-2014, 10:22 AM   #41
xjohnx
Grip>Slip
xjohnx's Avatar
Would like to know this too. Also, are you disconnecting the OEM rear O2 sensor harness completely and splicing in to the blue wire on that harness? Or leaving the harness connected to the o2 sensor and splicing into the blue wire?
Old 02-26-2014, 10:51 AM   #42
spdbydesignchris
After seeing the AEM Uego wideband, you would be simply running the 0-5V output wire from the gauge, inside the car, to the blue wire on the rear o2 sensor.
I'm using the passenger ECU wiring harness loom grommet, making a small slit with a razor and sliding the AEM harness through. (As well as the 0-5V output wire, which will need to go into the engine bay.)
BRZ Front and Rear LED Turn Signal Bulbs convoy Cosmetic Modification (Interior/Exterior/Lighting) 23 11-25-2013 08:51 AM
Aftermarket Rear Diffuser Realm Cosmetic Modification (Interior/Exterior/Lighting) 8 05-09-2013 12:23 AM
FS: BNIB Concept Three LED Amber/White signal bulbs Front and Rear with Relay xxscaxx Exterior Parts (Aero, Lighting, Etc.) 10 03-27-2013 11:17 AM
DIY: front and rear LED turn signal bulbs jjdrivesajazz DIY (Do-It-Yourself) Guides 6 10-15-2012 10:53 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 01:42 PM
