Old 04-18-2014, 09:18 AM   #29
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Damn, I might buy that "just in case." That's nice.
Make sure the bolts use a 19mm (or 3/4") socket so I can use my lug nut socket on the bolts. I'm lazy and don't want to have to change tools.
It would also be cool if the spacers used a hex instead of flats, but I appreciate the machining required for a hex is more costly than flats.
celica73 is offline   Reply With Quote
Old 04-18-2014, 09:49 AM   #30
Slambert
Drives: Fast
Sorry, but I'm not going to be able to accommodate either of your requests.
Bolt heads and Flats are 22mm (7/8in). They will need to be that size due to the bolt size.
The Flats allow for more surface area for the hitch tube to rest on.
Install/uninstall with hand tools and torque wrench takes less than 5 minutes.
Slambert is offline   Reply With Quote
Old 04-18-2014, 10:33 AM   #31
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Final revision is looking pretty good Shawn. Nice work.
Ranatsu is offline   Reply With Quote
Old 04-18-2014, 11:00 AM   #32
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Estimated price?
2013 SWP BRZ
Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781
smbstyle is offline   Reply With Quote
Old 04-18-2014, 11:03 AM   #33
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by Scooby South View Post
Here is mine.. and I have the hidden hitch.. only weighs 11 pounds.. Total towing weight is about maybe??? 500 lbs??.
sick man, what trailer is that? or is it custom made?
Old 04-18-2014, 11:13 AM   #34
Slambert
Drives: Fast
Originally Posted by smbstyle View Post
Estimated price?
$250 - $300
Old 04-18-2014, 11:15 AM   #35
vroom4
Im sorry but that design looks terrible for any significant tongue weight. Those bolts are gonna be torqued like crazy in a location/direction they are not designed to be torqued (the threads).
vroom4 is offline   Reply With Quote
Old 04-18-2014, 11:27 AM   #36
smbstyle
smbstyle's Avatar
Don't think anyone was planning on using it for towing their boats; just a tire trailer/bike rack. You do realize that the mounting points are for the factory TOW hooks, right?
2013 SWP BRZ
Old 04-18-2014, 11:39 AM   #37
vroom4
-Towing a boat doesnt have ANY tongue weight
-Towing a tire trailer doesnt have ANY tongue weight
-Factory tow hooks are not in question
I was thinking the problem may arise if someone tries to load one of these puppies up with 300 pounds.
http://www.carid.com/universal-trail...FcURMwodWSgAzg
Old 04-18-2014, 11:42 AM   #38
vroom4
It is a pretty sweet idea though, I mainly just wanted to provide a warning about tongue weight.
I cringed as I bolted up my heavy ass curt hitch. Added 30 pounds over the back end.
Old 04-18-2014, 11:46 AM   #39
Slambert
Drives: Fast
Trailer tongue is typically 10% of the total trailer weight. So your 3000lb boat should have a tongue weight close to 300lbs.
The hitch is rated at 100lb tongue weight and 1000lb trailer weight. This is and will be clearly depicted on each hitch.
Old 04-18-2014, 11:50 AM   #40
vroom4
Cool, well done.
Old 04-18-2014, 11:51 AM   #41
vroom4
Im just waiting till someone tows around one of those pop up campers.
Old 04-18-2014, 11:55 AM   #42
Slambert
Drives: Fast
From what we experienced in the testing phase of this project was that excessive tongue weight is going to affect the rear suspension of the car more than the trailer hitch. Add too much tongue weight and you will be riding on bumpstops.
WTB: 1 OEM FRS/BRZ Tire RedFR-s Canada Classifieds 3 11-08-2013 11:43 AM
Tire Noise? Admiral Ballsy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 07-04-2013 09:02 PM
what is your tire pressure? abling2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-03-2013 10:49 AM
WTB One (1) OEM Tire Trojan_SC Wheels and Tires 2 05-07-2013 03:59 PM
What tire PSI are you using SEC Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-30-2012 09:09 AM
