Old 09-03-2014, 08:42 AM   #29
DAEMANO
Time Traveller
Originally Posted by Dihudaxia View Post
Hold on...
This is a properly noob question here.
You mean you can lower an FRS on 100% stock suspensions just by adding LCA's?
I mean i got the impression by the product description...
Just the rear, the front would need some other lowering solution.
Old 09-03-2014, 11:03 AM   #30
Dihudaxia
Drives: 86
Is there anyway to lower the front at all without resorting to changing springs or coils??
I miss my stock suspension's ride....
Dihudaxia is offline   Reply With Quote
Old 09-03-2014, 11:07 AM   #31
DAEMANO
Time Traveller
Top mounted front camber plates (like RaceComps, Ground Control's, or HVTs) lower about 3/8". Nothing else on the market as of yet as far as I know.
Old 09-03-2014, 11:13 AM   #32
Dihudaxia
Drives: 86
Thanks for the info...
Looks like i am stuck with my springs for now..
Old 09-04-2014, 09:57 AM   #33
JamesBond000
First Class Speeder
Drives: Silent and Quick
Powered by max i asked them if they plan on making more kinds of suspension parts for the FR-S etc and i was told in the next few months they will start to have more kinds of parts!!!
JamesBond000 is offline   Reply With Quote
Old 06-27-2015, 09:39 PM   #34
dito
Drives: SWP BRZ
So i just installed these lower control arm and wanted to dial in -3.5 rear camber but the shop told me they cant do it because i would need aftermarket toe arms but i see a few members here going up to -4 without aftermarket toe arms. Also the shop told me i had to grind/shave down my subframe so they can access the lca to adjust them. Anyone had any experience with this??
dito is offline   Reply With Quote
Old 06-28-2015, 12:19 AM   #35
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
If i wanted to lower my car another half inch or so would these work? I have Swift springs with Bilstein B6 shocks and SPC LCA's right now. It just has a little rake right now and the rear could go down another 10mm or so if possible.
JoeBoxer is offline   Reply With Quote
Old 06-28-2015, 04:31 PM   #36
Bergen23
Drives: '15 Halo FR-S
Yup, I have FA 500's. At the lowest setting in the rear I had around 1.25 to 1.5 inches of gap between fender and tire. After installing these LCAs in the lowest mounting point, I was tucking rim. Definitely seemed like it lowered it by more than 40mm. The good thing is that they have 2 holes to attach your coils to, one is -40 and the other is -15 or -25, can't remember which off the top of my head.
Bergen23 is offline   Reply With Quote
Old 06-29-2015, 02:34 PM   #37
srizzors25
Daedalus Moto
srizzors25's Avatar
Not sure if you guys ran into this or if its just common but the winter roads beat up the front side of the LCA's, pretty much chipped the paint off now they don't look so good from the front :/ function wise they are good but cosmetically they aren't the prettiest on one side
Old 06-29-2015, 04:09 PM   #38
Bergen23
Happened to my Megan's, assuming the same will happen with the PBMs as well. I'm not worried. Not like you can see it anyways.
Old 06-30-2015, 07:30 AM   #39
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
We see this with almost all the "fancy" rear LCAs in terms of the adjustments. IIRC my techs told me they welded up a tool to reach the adjusters on the cusco/fancy style arms.
-mike
AZP Installs is offline   Reply With Quote
Old 10-21-2015, 04:46 AM   #40
dito
Drives: SWP BRZ
hey guys, do any of you guys get any noise from these lca? mine is clunking pretty bad in the rear and im pretty sure its the lca, perhaps bolts not tighten properly or stuff. just wondering what exactly should i do to recheck all nut and bolt. im on airlift suspension. thanks
Old 07-05-2016, 08:32 PM   #41
PeterFRS
PeterFRS's Avatar
Drives: FRS
are they any updates as to these LCA's in terms of review/install?
I have been looking at these for couple months and this thread seems to be the only one that talks about these LCAs..
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
Old 07-07-2016, 01:54 PM   #42
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
I love the clamps to hold your alignment settings. They also have nuts, so it's a double locking mechanism, although i think the nuts are not really necessary.
They are hard as stone, but a bit heavy.
tato.valverde is offline   Reply With Quote
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 88 08-26-2013 11:49 PM
More power with Agency Power vividracing Engine, Exhaust, Bolt-Ons 0 07-26-2013 04:27 PM
BRZ STI NA with more power Harinjo BRZ First-Gen (2012+) — General Topics 79 12-22-2011 04:24 PM
