Old 01-13-2014, 10:44 AM   #29
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by ramiram1984 View Post
And that's def what she said, too.
X2
Sent from my IBrick
Old 01-13-2014, 10:45 AM   #30
Thongpocket
Master Troll
Thongpocket's Avatar
Drives: 2013 BRZ Limited
I have a question. This pipe is 60mm. The N1 Invidia I have on my car is 65mm. Most headers also have a 65mm outlet. Would this smaller diameter pipe be an issue for performace versus a 65mm overpipe from someone like MOtiv? I beleive in Invidia and will probably buy this but wanted some opinions. Given that our engines NA dont flow massive CFM's of air I would assume its not an issue and would only expedite the expulsion of the exhaust once it leaves the overpipe. Thoughts?
Thongpocket is offline   Reply With Quote
Old 01-13-2014, 12:37 PM   #31
jm1681
Drives: MKVI VW GTI
Way I see it, there is a pressure differential to be taken advantage of, as the overpipe is in-between two cats. Reducing pressure behind the first cat should aid flow through it, and increasing volume into the second cat can't be a bad thing, right?
jm1681 is offline   Reply With Quote
Old 01-13-2014, 01:14 PM   #32
Thongpocket
Master Troll
Unless you have no second cat as I do. Lol
Sent from my XT1080 using Tapatalk
Old 01-13-2014, 01:14 PM   #33
OrbitalEllipses
Drives: Attitude
Originally Posted by SmsAlSuwaidi View Post
Because bigger is always better
That's what she said.
hehehe
The Following 2 Users Say Thank You to OrbitalEllipses For This Useful Post:
Jaylyons1 (01-13-2014), SmsAlSuwaidi (01-13-2014)
Old 01-13-2014, 01:25 PM   #34
kurbkilla
kurbkilla's Avatar
Drives: Scion FRS (Asphalt)
Sorry to disappoint, but you do not have 65mm exhaust. You have 60mm (2.3") with 101mm Tips per their website here.
To my knowledge this is the same for most exhaust and headers leading to my topic about exhaust sizing here.
kurbkilla is offline   Reply With Quote
Old 01-13-2014, 01:33 PM   #35
FR-S Matt
I have a full Invidia Q300 exhaust, minus the overpipe. The entire piping from the front pipe to the tips is 60mm (2.36")
Old 01-13-2014, 01:35 PM   #36
1086
1086's Avatar
Drives: UM86 - 6MT
what would replacing my stock OP really do for me?
1086 is offline   Reply With Quote
Old 01-13-2014, 02:10 PM   #37
JS + BRZ
Drives: 2010 MS3
Ask your gf if bigger is always better.
JS + BRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to JS + BRZ For This Useful Post:
ramiram1984 (01-13-2014), SmsAlSuwaidi (01-13-2014)
Old 01-13-2014, 03:01 PM   #38
FR-S Matt
Replacing everything up to the catback is worthwhile. The stock system is restrictive big time. Pick your flavor of catback.
I like the Invidia system because it's a great design, nice and straight. (no homo)
Old 01-13-2014, 03:48 PM   #39
fazm
Drives: 2014 FR-S
Seems like a solid choice for an entire system with cats would be:
FT-86Speed Catted Header
This overpipe
Whichever lightweight 2.5 exhaust suits your fancy.
What do you call overpipe back? Catback?
fazm is offline   Reply With Quote
Old 01-13-2014, 11:32 PM   #40
Seattle944t
Drives: Sc10n
This overpipe
Front pipe + catback is the overpipe back. Front pipe is the 2nd cat and attaches to the overpipe before the catback.
Seattle944t is offline   Reply With Quote
The Following User Says Thank You to Seattle944t For This Useful Post:
fazm (01-14-2014)
Old 01-14-2014, 06:49 AM   #41
FR-S Matt
This overpipe
Headerback.
The Following User Says Thank You to FR-S Matt For This Useful Post:
fazm (01-14-2014)
Old 01-16-2014, 09:20 AM   #42
ChandlerSwyng
ChandlerSwyng's Avatar
Drives: 2013 Red Subaru Brz
Has anyone installed this yet?
Invidia N1 SS Catback, Revworks UEL Headers(Brand new), Invidia Front Pipe; &&&MOREEE brzadmir Engine, Exhaust, Bolt-Ons 20 12-23-2013 10:34 AM
PTUNING Weekly Special: Invidia Catless Front-pipe / Test pipe $229 INSTALLED! Patrick@Ptuning Engine, Exhaust, Bolt-Ons 3 10-01-2013 03:16 PM
Invidia front pipe rub? Admired Engine, Exhaust, Transmission 12 08-13-2013 10:16 PM
FS: Invidia Q300 & Invidia Front Pipe DR1FT Engine, Exhaust, Bolt-Ons 15 06-07-2013 07:29 PM
◙◙◙ [NY Local] Invidia Q300 SS tips & Invidia Front Pipe INSTALLED SPECIAL | RAD ◙◙◙ Kevin@RAD Announcements, Contests, Giveaways 44 06-07-2013 02:26 PM
