Old 01-06-2014, 10:10 PM   #29
ZionsWrath
Thanks
ZionsWrath's Avatar
Anyone running 8.5 / 9.5 +45 wheels on RCE yellows? Anyone running 8.5 +45 front with OEM camber bolt and RCE yellow? What size tires if you are?
Want to know if any rubbing issues? I want these springs or maybe STI pink but a little concerned it will rub.
Old 01-06-2014, 10:28 PM   #30
OrbitalEllipses
Drives: Attitude
I can guarantee 9.5 +45 will rub on anything near stock size spring perches.
whataboutbob (01-07-2014)
Old 01-07-2014, 12:57 AM   #31
whataboutbob
AutoX-10/10ths every run
17x9et35 RPF1s w 245/40R17 Z2s. -2 3/8 ft camber, -1.8 rear.
Build thread:Here
The Following 2 Users Say Thank You to whataboutbob For This Useful Post:
fooddude (03-30-2014), WRB-DZA-BRZ (04-07-2014)
Old 01-07-2014, 01:24 AM   #32
whataboutbob
Maybe one of the best shots yet for the car.
Build thread:Here
The Following 3 Users Say Thank You to whataboutbob For This Useful Post:
Anthonytpt (01-07-2014), fooddude (03-30-2014), fstlane (01-07-2014)
Old 01-07-2014, 03:14 AM   #33
ZionsWrath
Thanks
ZionsWrath's Avatar
On rear? Im talking stagger
Old 01-07-2014, 12:05 PM   #34
OrbitalEllipses
Drives: Attitude
Front for sure. Rear? Check the wheel guide. I'd say ask @King Tut, but no one can see him. You could ask @Jive Turkey too.
Old 01-07-2014, 12:09 PM   #35
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You won't see this post right now, but I will answer anyways. They will work just fine on the rear. The only thing to watch is the bracket that connects to the lower control arm that holds the parking brake cable in place. I bent mine in to get a little more clearance between the bracket and the tire.
Old 01-07-2014, 09:33 PM   #36
ZionsWrath
Thanks
ZionsWrath's Avatar
I'm asking in this thread about specific sizes on these springs, not trying to guess work and check guides. Wanting to see someone with this setup and how it fits. ^_^
Old 01-07-2014, 09:41 PM   #37
OrbitalEllipses
Drives: Attitude
Whatever you said, all I read was "I like to ignore the wisdom of my predecessors and use the tools already available to me." People have had trouble fitting 9.5" +45 wheels on aftermarket threaded-body coilovers that have a narrower spring-perch. Does that make sense to you?
Old 01-07-2014, 09:43 PM   #38
ZionsWrath
Thanks
ZionsWrath's Avatar
Show me? I haven't seen those threads of 9.5 +45 not fitting in rear with coils.
Old 01-08-2014, 12:58 PM   #39
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by husker741 View Post
Specs? Any camber adjustment?
Front is -2, rear is -1.5.
Work VS-XX (PG)
18x9" +34
18x9.5" +39
Toyo Proxes T1 Sport
245/35-18
255/35-18
The tires are a lot more square than other similar tires, hence the "tight" fitment.
-alex
Old 01-13-2014, 11:16 AM   #40
ZionsWrath
Thanks
ZionsWrath's Avatar
Moar
Old 01-17-2014, 10:10 AM   #41
husker741
Bump
husker741 is offline   Reply With Quote
Old 03-29-2014, 10:48 PM   #42
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
Here's mine. Not the best pic but all I have on me at the moment. I can always take more if needed.
18x8.75 +35 XXR 527's.
Jaylyons1 is offline   Reply With Quote
FS: RCE Yellows + Koni Yellows ***SOLD*** raul Brakes, Suspension, Chassis 0 10-22-2013 01:14 PM
Feeler: RCE Yellows + Koni Yellows *PRE-ASSEMBLED* raul Brakes, Suspension, Chassis 0 08-09-2013 03:22 PM
WTB: RCE Yellows GTHachiRoku Want-To-Buy Requests 0 07-23-2013 08:18 AM
RCE Yellows + Koni Yellows + Whiteline Camber Adjustment Bushings raul Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 05-24-2013 08:33 AM
Pic of RCE yellows on stock wheels? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-23-2013 10:10 AM
