Old 04-01-2014, 05:59 PM   #29
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Trying to edit the launch control. Should I be worried?
Loaded the XML file "._RR_ZA1JA00C" into ROMRaider, opened up the bin file "Stg1 A00C" and it showed me this..
My CAL is A00C. It still loads after giving me this message but I'm hesitant to flash it with this message lol.
l0aded is offline   Reply With Quote
Old 04-01-2014, 06:10 PM   #30
steve99
You need to get the definition files from the openflash site here (bottom of page)
http://openflashtablet.com/products/...ads/index.html
As I think the defs from RR are on a different github branch and don't have LC tables defined.
The checksum message is normal as OFT ROM's are not check sum corrected, when you save rom it will be corrected and the OFT would correct it anyway
Old 04-01-2014, 07:03 PM   #31
l0aded
Addicted
l0aded's Avatar
I downloaded the romraided XML from the OFT website. Just so I understand clearly this is normal or doesn't matter correct? When I save it the checksum would be fixed anyways?
Old 04-01-2014, 07:11 PM   #32
steve99
Yes. whenever you save a ROM in RR it fixs the checksum1.
you also get an error re checksum2 you can ignore that one.
I think the OFT ROM's are done with tunepro which does not correct the checksum.
Old 04-04-2014, 03:57 AM   #33
Mirko
Mirko's Avatar
Drives: Subaru BRZ
Originally Posted by shiv@vishnu View Post
I'll be working on porting FFS and LC to non-USDM 6MT ROMs over the holidays.
Is this out yet?
Mirko is offline   Reply With Quote
Old 04-04-2014, 06:20 AM   #34
Mirko
Mirko's Avatar
Drives: Subaru BRZ
Originally Posted by Mirko View Post
Is this out yet?
Well, if it is, Im having a hard time making it work.
(first time using RomRaider, took the occasion since I also had to erase a CEL)
Here is what I did:
1- Downloaded the RR xml definition file, RR_ZA1JA01G in my case
2- Added it in the RR ecu definition manager
3- Then started messing around, opening all sort of files (.bin, my supposed original tune, beta tunes, ....)
Somehow I managed to fix the cel on my current tune and also uploaded it successfully on the oft.
But I did not find a way to have the "Alpha BRZ FFS/LC" thing appear on RR left column. Any suggestions? Sorry to bother you guys today, Im doing my best to learn..
I already watched all of Shiv's tutorials on youtube.
Thank you
Old 04-04-2014, 06:34 PM   #35
steve99
Here is what I did:
Thank you
Make sure you get the romraider def from the openflash downloads the "standard ones on RR don't have lc/ffs tables defined.
Also you cannot enable lc/ffs on a stock rom its needs to be a patched rom ie an openflash tablet vishnu rom as they have been patched with extra code for ffs/lc
Old 04-06-2014, 03:53 PM   #36
DC2R
Drives: 2014 Scion FR-S
Originally Posted by t1ao View Post
I currently have B00C, would i be fine using A01C, so i could use launch control?
I would like to know this too. i spent a lot of time trying to find parameters in my B00C bin like an idiot before i read this. Can we flash another version or should we wait for implementation. Also i see all Vishnu tutorials are in TunerPro. Where can we find XDF files for this?
DC2R is offline   Reply With Quote
Old 04-08-2014, 06:15 PM   #37
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Originally Posted by Danklvr View Post
not supported for B01C roms yet - FYI if you have a B01C rom and are looking for this in RomRaider.
Finally got off the 1.5x dev and figured I'd set LC on my b01c.
Still not defined in RomRaider?
Not a big deal, just figured I'd play a bit with romraider is all 8)...
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 04-08-2014, 07:58 PM   #38
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
not yet as far as i know, i am still waiting as well. Probly not a feature i'd actually use, but would be fun to try a couple times on a deserted road.
Most likely will be included in Shiv's next round of OTS map updates.
I heard rumours a while back that 1.6 maps were in testing.
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 04-20-2014, 08:25 PM   #39
KslayFRZ
KslayFRZ's Avatar
Drives: 2013 Frs asphalt
Still nothing on the bo1c LC?
KslayFRZ is offline   Reply With Quote
Old 04-20-2014, 09:45 PM   #40
KslayFRZ
KslayFRZ's Avatar
Am i right?
Old 04-20-2014, 10:43 PM   #41
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Nothing yet. I just haven't had the time to test/implement it. Hopefully by the next OTS map release.
Old 04-21-2014, 01:30 AM   #42
KslayFRZ
KslayFRZ's Avatar
OK so just to make sure I'm not messing up... I can't use this file for my ecu because ur doesn't match right?
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
racerom flat foot shifting ft86me Engine, Exhaust, Transmission 10 07-25-2013 03:02 PM
EcuTek RaceRom Flat Foot Shifting ! Visconti Engine, Exhaust, Transmission 79 11-14-2012 09:36 PM
