Old 11-29-2013, 09:32 PM   #29
Howardwei
Um question
Originally Posted by mid_life_crisis View Post
You are absolutely correct. I should not have quoted you and have removed that from my post.
I stand by my concern, though. Properly fitted tires on 9 inch rims are too large for this car. I have real issues with function taking a back seat to style when it comes to choosing rim/tire combinations. I have never understood the logic of stretching a narrow tire over a rim that is too wide for it. It just seems like it's begging for trouble.
I was told by evasivmotor and ravspec that these cars on 18x8. front 18x9.5 would fit on stock suspension and an inch drop. even with 255 rear and 225 front.? just wondering. Te37SL was the specific wheel. Jive turkey have it set up square 18x9.5 all around with camber and a drop. apparently its working out well for him on the track.
Howardwei is offline   Reply With Quote
Old 11-29-2013, 09:56 PM   #30
mid_life_crisis
Drives: FR-S 10 #103 AT
Don't those cars also have what might be termed "significant other mods"?
Old 11-29-2013, 11:45 PM   #31
Howardwei
"stock suspension" so I guess what I am saying here is. it would fit. and my question for you is how fitting a wider tire or wheel would be bad except for the weight. I thought this car oversteer to easily, so on a track, one may find it hard to get on gas early without a "significant amount of traction on stock power"?
Old 11-29-2013, 11:46 PM   #32
Howardwei
For clarity, the person did not have any F.I.
Old 11-30-2013, 11:32 AM   #33
mid_life_crisis
The car, as designed, supposedly is remarkably well balanced between power and traction. I've never taken it to a track so I cannot speak from personal experience with this vehicle, but I've owned other light, moderately powerful vehicles before and when you take a car that is designed to be thrown around and dramatically change its traction levels, you can screw it up. It's a really bizarre sounding concept, but you can actually have too much traction. In effect, you can make it a gokart that is easy for most people to drive faster than stock, but take away what makes it possible for a truly skilled driver to wring extraordinary things from it.
Sure, signifacantly wider tires will fit, but as has been observed, "just because you can do a thing, it does not follow that you should do a thing."
Old 11-30-2013, 10:19 PM   #34
wparsons
wparsons's Avatar
And just because a tire is wider doesn't mean it will be stickier... at stockish power levels some good drivers are having a hard time getting enough heat into anything wider than 225's to get good grip.
flickr
Wheel Directory: Enkei RPF1 17x8.0 +45 track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 163 03-17-2022 02:00 AM
Wheel Directory: Enkei RPF1 17x8.0 +35 Faceless Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 70 10-12-2020 06:16 PM
FS enkei RPF1 17x8 subaruferrucci Wheels and Tires 8 05-13-2013 05:01 PM
FS: 17X8 +45 RPF1'S (TX) track_warrior Wheels and Tires 20 02-26-2013 06:07 PM
Any vendor have in stock rpf1's in black 17x8 +45 offset? track_warrior Wheels and Tires 0 06-25-2012 01:57 PM
