Old 11-07-2013, 08:39 PM   #29
roddy
roddy's Avatar
Drives: '13 Ultramarine
Originally Posted by Diode Dynamics View Post
Hahaha dang you! That's what I was going to post
I think OP should take this a step further:
Nick C.
Oldsmobile power! FU*K YEAH!
Old 11-07-2013, 09:54 PM   #30
nemes
Drives: scion frs, corolla, gsxr750
This is sick
nemes is offline   Reply With Quote
Old 02-14-2014, 08:22 PM   #31
FRSfan111
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
Decided to do it too. Figured I have an oil cooler, might as well hear wrap it too.
FRSfan111 is offline   Reply With Quote
Old 02-14-2014, 09:52 PM   #32
White64Goat
Fo Shizzle FRzizzle............
Old 02-18-2014, 08:37 PM   #33
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Originally Posted by Braxton... View Post
lol I was going to say that NASA uses stuff like this for satellites and space ships to insulate them from the harsh temperatures of space I wonder if you could wrap headers with this stuff.
It's not direct heat so much as it is radiation and IR radiation. Gold is specially suited to filtering out/blocking IR and other types of radiation, which causes a transfer of heat energy upon impact with a solid body (and why radioactive metals are warm to the touch).
For the same reason, it's effective in cars at blocking radiated heat, although a small buffer layer (foam, etc...) would drastically enhance that effect.
DoomsdayJesus is offline   Reply With Quote
Old 02-18-2014, 11:29 PM   #34
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
If anyone's doing this to lower intake temps.. which they obviously are. Don't forget to BYPASS the radiator plumbing on the throttle body. That gets hot to the touch after 15mins of normal driving.
Here's my updated intake.
stevo_12v is offline   Reply With Quote
Old 02-20-2014, 01:59 PM   #35
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Pics or a DIY for this would be great, as well as part number for a bypass coupler.
Old 02-20-2014, 02:22 PM   #36
stevo_12v
Doesn't need a new part, just unhook the radiator tubing off the TB and route back into the system, just bypass the TB altogether. Not recommended in VERY cold climates though, the reason the radiator passes through the TB is so the butterfly doesn't freeze solid and can open/close.
** go through my build thread around where I bought my TODA big throttle body, it will show the pipes for the radiator hosing, just don't connect those up.
UPDATE: Found it
Pic courtesy of @MAPerformance
Just install the TB like that...WITHOUT hooking up those two connectors. Easy done. One of the hoses *should* be long enough to plug it back into the radiator system.
Planning to vinyl wrap the hood, how much vinyl wrap to buy? retrosmiths Cosmetic Modification (Interior/Exterior/Lighting) 2 08-12-2013 10:32 AM
Car Wrap / Foil Wrap : Pros and Cons? LeBryan Cosmetic Modification (Interior/Exterior/Lighting) 0 06-25-2013 09:13 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
