Old 09-29-2013, 11:24 PM   #29
m.box.design
m.box.design's Avatar
Drives: 2013 Whiteout FRS
definitely looking better and better. keep up the experimenting!
there's a local plastic shop here that does a lot of custom work. wondering if they can make a custom housing for those led strips.
http://www.tapplastics.com/product_applications
i'll probably find time to go in and get some ideas thrown around.
The Following User Says Thank You to m.box.design For This Useful Post:
retrosmiths (10-01-2013)
Old 09-29-2013, 11:59 PM   #30
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Originally Posted by retrosmiths View Post
Thanks! For bigger LEDs though I would have to actually solder individual LED modules together, but I've given it some thought.
Tapa and the forum aren't getting along right now so I can't post pics, but I made a 46 5050 SMT dual color LED board for my domelight and a 40 (same but different color) for a friend. If you need help, let me know. I do my own custom design work.
Old 09-30-2013, 12:18 AM   #31
retrosmiths
Drives: Scion FR-S Whiteout
Originally Posted by FiRStsc10n View Post
Final product looks really good. My only suggestion would be do the standard DRL delete for the Amber turn-signals and let the LEDs play the role of DRL unless of course you need it to power the LEDs
Oh this isn't the final product It's just the prototype.
I have heard of them and have actually bought plastic polishes from them, which I used to finish off my candy red tail lights. I've also heard they will custom-cut plastic, but it might be easier for me to create the mount first in a metal sheet like how I did it now.
YES! I do a bit of soldering here and there, but I haven't done something really complicated like this switchback circuit I am talking about, so I will be bugging you once I started on the next version! Thanks!
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 09-30-2013, 01:18 AM   #32
m.box.design
What if I actually get them to make a set or two and send them to you to demo?
Old 09-30-2013, 01:27 AM   #33
retrosmiths
That will be awesome, but how will you provide the exact size to them?
2013 Scion FR-S
Old 09-30-2013, 01:43 AM   #34
m.box.design
#eyeballthemeasurements
i was thinkin you could provide the necessary measurements to accommodate your LED strips. i'll have to design them in sketchup, and make one out of chip board for mockup.
Old 09-30-2013, 01:54 AM   #35
retrosmiths
Ok, cool man, I will create the template in sheet metal first, then give you the measurements.
2013 Scion FR-S
Old 09-30-2013, 09:22 PM   #36
retrosmiths
Looks like it's holding up well..
2013 Scion FR-S
Old 09-30-2013, 09:38 PM   #37
soundman98
ProCrastinationConsultant
soundman98's Avatar
i think you need a new sig pic
retrosmiths (09-30-2013)
Old 09-30-2013, 09:58 PM   #38
retrosmiths
Yeah, lol, I can't wait for the next revision.
I'm planning on cutting up squares of these:
...attaching them to a larger panel made of metal sheet (or plastic) and re-soldering them in "steps" formation, kinda like the LED modules here:
Then, I'll probably add amber LED strips on top the same size as the white I have now.
Finally, I'll lightly smoke the entire chrome assembly to get rid of too much glare, using this paint ([ame="http://www.amazon.com/Dupli-Color-MC206-Smoke-Metal-Anodized/product-reviews/B00295T4JW/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1"]MetalCast Chrome[/ame])
...which is from the same family of paint I used in the candy red tail lights.
2013 Scion FR-S
The Following 2 Users Say Thank You to retrosmiths For This Useful Post:
DaJo (09-30-2013), SkAsphalt (10-16-2013)
Old 09-30-2013, 10:15 PM   #39
soundman98
soundman98's Avatar
i don't care for those at all...
how about some of these reflectors?
http://www.exledshop.com/d.i.y-parts...ector-1ea.html
they are a side-firing reflector very similar to the original reflector used by the design you're trying to copy.
otherwise, some osram point led's might be a good consideration as they can be mounted from below a circuit board, making for a very thin profile design. they should have output similar to the plcc2 led's that strip has..
another idea that's a bit more of a long shot-- look into remote phosphor panels
http://www.hidplanet.com/forums/show...assorted-ideas
all white led's are actually blue led's with a red/green coating above them to create the rest of the white spectrum.. by using the separate pieces, you can do some interesting effects that lend to a really smooth output that normal led iterations can't do without a lot of acrylic diffusing work...
Old 09-30-2013, 10:43 PM   #40
m.box.design
sign me up for your 2nd set. headlight swap with my stockers?
Old 09-30-2013, 11:22 PM   #41
boredom.is.me
Custom User Title
@retrosmiths
You made me post this! Let me at it!
http://www.ft86club.com/forums/showthread.php?t=47979
If you do the 4 row strip, I think the high beam housing would look good as the turn signal. I can make custom enclosures (minus the lens) for the 4-way.
The Following User Says Thank You to boredom.is.me For This Useful Post:
Old 09-30-2013, 11:26 PM   #42
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
I would suggest a reflector housing like someone mentioned above, to hide the LED diodes for a cleaner OEM look when they're off.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Prototype Swift Springs for FR-S mines13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 137 09-17-2013 09:36 PM
P&L Header prototype Hawaiian Engine, Exhaust, Transmission 388 05-31-2013 01:50 PM
WGP Looking for a BRZ For LS Swap Prototype Doug@WGP Announcements, Contests, Giveaways 25 10-10-2012 05:20 PM
Different wheels on the prototype ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 06-20-2011 05:00 PM
Wheels on the Prototype joshuo Scion FR-S / Toyota 86 GT86 General Forum 13 11-03-2009 07:37 PM
