Old 09-23-2013, 04:48 PM   #29
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by vgi View Post
I don't know. Why do people crack photoshop when there is a gimp
because gimp's interface terribly clunky. However, comparing ecutek license keys or cloned ecutek roms to OFT/BRZEdit/romraider/ecuflash is not really comparing two like things.
photoshop and gimp both have the capability of editing photos.
but with a cloned/pirated ECUtek rom flashed on your ECU (or a fake license key), unless you've got a vendor's license and software then you're still not able to edit the map you pirated. it would be read only without those tools.
whereas when using OFT/BRZEdit/romraider/ecuflash the end user could edit their tunes at their leisure.
Old 09-23-2013, 05:25 PM   #30
vgi
Drives: frs
yep, i would guess number of folks would rather use familiar ecutech interface and features they know how to access.
yep, so does ecutech and OFT/BRZEdit/romraider/ecuflash
but with ... pirated ECUtek [using fake license key], unless you've got a vendor's license and software then you're still not able to edit the map you pirated. it would be read only without those tools.
it's like saying that if you have a pirated photoshop license key and software installation binary or disk then once you install and register this photoshop with pirated key you will only be able to see the images but not modify or save them.
the clones would only be used for figuring out the licensing algorithm/handshake between the tune and software using authentic cable.
as for modifying cloned ecu, if you're interested, using the original cable - you should ask shiv if it's doable, i would guess yes since he was able to flash back to stock tune.
but again, these are just my speculations and you might be right
neither do I care. when I decide on what to get - I will just pay the money to support the solution I like.
imo, OFT shouldn't have tried reading and deciphering EcuTech tunes. This is IP of other people and that's how they make money. Now though it's been compromised. Now that BrzEdit allows reading and flashing free tunes from OFT it also may hurt sales of OFT. It's a war out there.
vgi is offline   Reply With Quote
The Following User Says Thank You to vgi For This Useful Post:
xjohnx (09-23-2013)
Old 09-23-2013, 05:30 PM   #31
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
There is no "deciphering" of ecutek tunes. They use the same map addresses as the stock tune. And we read an ecutek rom using the standard read protocol used to read stock roms. We won't even bother trying to crack the ecutek security because, IMHO, it's not necessary or even worth doing given other (better) options.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
vgi (09-23-2013)
Old 09-23-2013, 05:54 PM   #32
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by shiv@vishnu View Post
We won't even bother trying to crack the ecutek security because, IMHO, it's not necessary or even worth doing.
In fact beacuse of the STUPID DMCA law it would even be illegal.
The DMCA makes even attempting to reverse engineer ANY encryption illegal. That is why it is even illegal to make a pdf or *.doc viewer without permission from the original vendor since the compressed nature of those files are considered "encryption".
If I made a hammer with encryption on it, it would be illegal to reverse engineer the hammer. That is how stupid the DMCA is.
The Following 3 Users Say Thank You to stugray For This Useful Post:
Anthony (10-26-2013), Sonolin (09-25-2013), wparsons (09-23-2013)
Old 09-23-2013, 09:39 PM   #33
wparsons
wparsons's Avatar
just found this post from delicious that states it's not locked:
Awesome, thanks!
flickr
Old 09-25-2013, 05:11 PM   #34
xjohnx
Grip>Slip
xjohnx's Avatar
oh man. shit just got real.
Here is a full ROM for ZA1JA00C to get you started. I'll be posing up a beta for and EcuFlash version that does the "OEM style" 0x8000-0x13FEFF reads and writes in the next day or so, just to get you started while I work on finishing up a kernel based reflash which will be quicker and more flexible, along with being able to read out the full ROM. Since there is no longer a kernel loader in the stock ROM, I will be adding a patch to allow for this. I'm also working on another patch to add fast and complete logging capability.
just part of the latest update on romraider...
The Following 6 Users Say Thank You to xjohnx For This Useful Post:
calispec (09-25-2013), illmatic (09-25-2013), King Tut (09-25-2013), SkullWorks (09-25-2013), Sportsguy83 (09-25-2013), vgi (09-25-2013)
Old 09-25-2013, 06:50 PM   #35
Sonolin
Nice! Very excited to see where this goes.
Sonolin is offline   Reply With Quote
Old 09-27-2013, 03:52 PM   #36
bfrank1972
Drives: 2013 FR-S Argento
Very cool stuff! So correct me if I'm wrong, the only expendature is a $170 tactrix cable?
bfrank1972 is offline   Reply With Quote
Old 09-27-2013, 04:01 PM   #37
xjohnx
Grip>Slip
xjohnx's Avatar
assuming you know how to tune yourself, then yes.
Old 09-27-2013, 04:38 PM   #38
bfrank1972
I don't, though I'd love to learn how to. I'm assuming as Romraider/EcuFlash make their way to the BRZ/FR-S market people will adopt, tune, and maps will be available.
Old 09-28-2013, 12:40 AM   #39
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
Tactrix cable and ideally a wideband O2 gauge (iirc innovate's can log alongside the romraider stuff).
Also a k-line obd ii cable could be used as a Tactrix cable (ver 1). Not sure if a generic k-line cable will work with the new can bus ecu we have.
Edit:
http://www.tactrix.com/index.php?pag...mart&Itemid=53
Yep innovate's wideband plugs right in.
Im really interested in how the DI tables look. After seeing how much is addressable it should be interesting. Looks like you can squirt whenever and wherever you want. That's a lot to explore.
robot is offline   Reply With Quote
Old 09-28-2013, 12:44 AM   #40
xjohnx
Grip>Slip
xjohnx's Avatar
Edit:
ordered one the other day in anticipation of this coming out. Granted, i likely won't be using it on my car right away unless my tuner is ok tuning in it. but i'd be more than happy to help out some locals if they want to be one of the firsts to try.
Old 09-28-2013, 12:59 AM   #41
robot
I just want to log for now.
Old 09-28-2013, 02:29 PM   #42
jamesm
this doesn't work on the latest ecuflash builds (anything past 1.28 i believe, as that is the newest version that i could get to recognize a standard j2534 cable). the newer versions require the tactrix branded cable, though that appears to be easily defeated with dongle cracking tricks if you were so inclined (unless you already own a bus pirate, you probably don't wanna go that route ).
best to save the trouble and buy the tactrix cable as it's cheap, has cool features (onboard logging, and the innovate plug you mentioned) and is a very good cable for the price.
Close iJason Member's Car Journals 1 08-04-2013 08:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 02:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 01:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 09:40 AM
