| Member's Car Journals Car journals by our members. |
#29 | |
Drives: 2014 Subaru BRZ
I agree with this as well
#30 |
Drives: 2013 Rocketbunny GT86
The best way to create power in your budget range is to re-circulate the exhaust into the intake; and since you are such a big fan of household plastics, you will love the simplicity. This is how all of the honda guys are sh*ting on all the exotic cars at the drag strip.
connect two pieces of flexible 2.5 inch piping to your exhaust, then use a plastic PVC Y pipe and connect them. Now run a long piece of PVC pipe to the front of the car. You might need to connect it underneath with Zip ties or Duct tape. IMHO the pink duct tape looks the best. Now once you have the pipe at the front, start the car and take a big breath of air out of the pipe to mke sure you installed it correctly. Now connect another piece of flexible piping from the long piece underneath, secure it with a hose clamp as you will have so much boost you might pop it off! Connect the flexible piping to your intake snorkle under your bumper. Now your car is pretty much a ram jet and your wife and you will have so much pOOWWWAAA you wont know what to do with it!!!! |
| The Following User Says Thank You to Maverick22 For This Useful Post: | mikepaul21 (11-29-2013) |
#31 |
Drives: 2013 Subaru BRZ & 99' Ford Explorer
intake ~250
pulley kit ~250 or save 100 more for ecutek tune 600 FREE / CHEAP MODS 1 Cap the intake and delete the sound tube. not sure if it actually does anything (some people say it makes a tiny difference) 2 Mod the stock stock snorkle. drill out 2 rivets. 1 on each resonator. remove the resonators. then cut off the 2 pieces that stick out. fill the 2 holes with plastic and epoxy to close off. at the turn (the long part) cut the front and using a heat gun bend the bottom. then use plastic and epoxy to close off the side(the original inlet). then fill the front, bottom and other side to close it off leaving a large opening in the front right behind the grill to create a ram air kind of effect. which probably wont have much of a ram air effect but in theory it should and it will defiantly help get colder air to the intake. |
#32 |
Drives: 2013 MT Asphalt FRS
| FA20CLUB Innovate Supercharger Tuning, Parts, Improvements & Results | FA20Club.com | Forced Induction | 143 | 12-18-2013 08:48 AM |
| Cheapest GT86 Badges | gatorbushmen | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 12-17-2013 06:28 AM |
| Hypothetical: Cheapest way to 200 whp w/o E85 | m.wood0213 | Engine, Exhaust, Transmission | 19 | 09-16-2013 07:05 PM |
| cheapest oem parts | Bt216 | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 07-02-2013 07:40 PM |
| Cheapest paid for Evo 3? | TheGuyWithTheFireStorm | Engine, Exhaust, Transmission | 15 | 07-02-2013 12:04 AM |
