Old 09-07-2013, 02:58 AM   #29
whataboutbob
AutoX-10/10ths every run
Originally Posted by whitefrs View Post
I had it Then i dropped it lol
Me too. Luckily my buddies (@EN2_Squirrel) had grabbed a magnetic telescoping tool when they went out for coolant for me during my Innovate SC install.
Build thread:Here
Old 09-07-2013, 05:36 AM   #30
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Originally Posted by spitfire481 View Post
I did the same thing a few days ago. Left the injector ecu hanging there so I could check my new port injectors for leaks. 4 fouled plugs from a flooded engine/stalling later I was able to get it dyno tuned today. Always make sure that thing is grounded. FYI it started and idled fine after I grounded it. It misfired in boost over 6psi though. New oem plugs and we had no issues up to 10.5 psi. Lesson learned
So u saying that not grounding these will damage ur plugs?
Maybe thats whats wrong with my car
Sent from my iPhone using Tapatalk - now Free
Old 09-07-2013, 06:50 AM   #31
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
My car acts like this when there is a vac leak
You sure you not leaking air somewhere?
448hpsti is offline   Reply With Quote
Old 09-07-2013, 08:45 AM   #32
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
No idea really. My car was super rich at startup, stumbled like crazy, then stalled itself out. I tried 3 or 4 times. Then when we realized that the injector ecu needed to be grounded it started and idled fine. Once on the dyno it misfired in boost, which it never did prior before this mishap
Old 09-07-2013, 09:48 AM   #33
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
but WAS misfiring at cruising but not anymore. but i have a really hard start and they say that it can be a ground problem
Old 09-09-2013, 11:08 AM   #34
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Didn't see this post till today. I can shoot you some more startup logs if you need them. My car cold starts and warm starts perfectly everytime.
Old 09-09-2013, 11:13 AM   #35
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Here is a video of my issue
I know what your car's problem is. No Full Blown powered car will want to start with that music playing in the background. I didn't realize you are running full speed density either. My understanding was that EcuTek hadn't perfected the speed density modifications yet.
Old 09-09-2013, 11:18 AM   #36
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Old 09-09-2013, 01:36 PM   #37
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Since Miley Cyrus was twerking that song car will act weird lmao
The Following User Says Thank You to whitefrs For This Useful Post:
Sportsguy83 (09-09-2013)
Old 09-09-2013, 01:38 PM   #38
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Old 09-09-2013, 02:00 PM   #39
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by ATSAaron View Post
Thanks guys. Here is a screenshot of what I am looking at. I think I screwed up my injector scaling and just need to seriously reduce the amount of fuel spraying in there. At first I thought I was too lean, but now I am thinking I am too rich. It is next to impossible to use a wideband at this point in tuning btw..it's either not enough exhaust to really show up, or incomplete combustion because of a cold motor, or cold sensor, etc..so it's basically change and test, change and test..not a problem with a stand alone, but kind of a pain int he ass when reflashes take several minutes.
Oh my log is on bottom, WhiteFRS is on top.
Looks like his hunts like crazy when it first starts..but his starts way faster than mine. Mine basically cranks and cranks until the port injector drops to 2 millisecs, then it sorta stumbles to life. I think I am drowning the poor thing.
Aaron
Looks too me like you have way too much cranking enrichment, you can see where it needs to be based on what the injection time is when the cranking rpms start to ramp up just as the engine fires off. Stock ECU goes into flood protection mode and starts dialing back the cranking pulse width if it does not fire right away. If it is a long crank then fires you have too much enrichment, if it take multiple cranks before it fires you don't have enough.
Old 09-09-2013, 03:24 PM   #40
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
How about mine lol
Old 09-10-2013, 12:51 AM   #41
ATSAaron
Drives: 2013 Raven FR-S
You were correct. In EcuTek there is an injector scaler where you supposedly can just enter the new injector size. Turns out it's not as linear as they thought. For example I have ID1000's but my car runs best with a value of 500 in there (the original value is 228). This value seems to still have nothing to do with cranking enrichment. I also had to drop my cranking fuel enrichment table and my cranking fueling - coolant table by half.
Aaron
ATSAaron is offline   Reply With Quote
Old 09-10-2013, 08:53 AM   #42
mad_sb
Aaron
Injectors almost never scale to the actual size they are. The Stock ports scale at 225 ish cc but are probably 250cc in all reality. You also always need to adjust the injector latency values to account for differences, especially with big injectors. Typically you do the rough scaling to get fueling under load where it should be and then you dial in the latency values to get idle and low load where they need to be.
Any pro tuner should know how to do this using the tables that are natively available in the rom (assuming injector latency and scaling are there, and they are in the case of the twins). Yet another reason i don't like ecutek.. but thats not the point of this thread.
The Following User Says Thank You to mad_sb For This Useful Post:
xjohnx (09-10-2013)
I can't send and receive PMs Hanakuso Site Announcements / Questions / Issues 1 06-14-2012 03:08 PM
Quebec Fr-S Test Drive ! Send me a message to reserve !!! SCIONMONTREAL CANADA 11 04-27-2012 04:11 PM
I send a msg on Tetsuya Tada facebook page 4agze Scion FR-S / Toyota 86 GT86 General Forum 63 06-28-2011 05:51 AM
