Old 03-19-2014, 12:24 AM   #29
HI
HI's Avatar
Drives: 2013 FR-S Ultramarine
Just found out from toyota today that I'll be getting a brand new trans.
HI is offline   Reply With Quote
Old 04-21-2014, 02:27 AM   #30
unlimited86
Drives: s2000
I think I somewhat experience the issue today and I am wondering if its the same as you guys, I couldn't hear any sound since road noise was loud, but as I shift from 4 to 5th at around 4-5k rpm. Going into 5th felt like a grind, but was not a grind where it would force you out of gear, it was more like the gears hitting each other trying to mesh, but can still go into gear.
unlimited86 is offline   Reply With Quote
Old 04-21-2014, 02:29 PM   #31
Myv
Myv's Avatar
Drives: SWP BRZ Limited MT
I have the same issue... sort of, reason is because I think it's my fault for either not pushing clutch in completely or letting go of clutch too early when shifting into 5th.
Sometimes I get into the car, and tell myself not to grind the gears today, and it still happens time to time lol
Myv is offline   Reply With Quote
Old 04-21-2014, 05:05 PM   #32
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Originally Posted by Norton 850 View Post
I'm eager to hear responses to this one. I suspect that the replacement gearboxes are the same. And since only some of the 2013/2014 gearboxes have crappy shifting performance, I suspect a QA/QC problem. I am keen to get to the bottom of this issue.
i would like to know this as well.
we need to create a poll who changed transmission under warranty and see whether people still have same issue.
Old 04-24-2014, 02:46 PM   #33
JRP
JRP's Avatar
Drives: 2013 Perl White FR-S
I have the grinding going from 6th to 5th above about 50 mph, with the trans hot or cold. Below that the down shift is fine. Waiting to see what the dealer is going to do about i. THe dealer is waiting to hear from a main Toyota office in Portland.
I was able to reproduce the problem with a tech in the car, who was not able to reproduce the problem even my description of how to reproduce it.
Jim
JRP is offline   Reply With Quote
Old 05-07-2014, 05:48 AM   #34
Xlr8
Drives: 2013 Ultramarine FR-S
Well I'm not sure if this is good news or not. I came here looking for answers and see it's not just me. My FR-S has started doing the grind within the last 400-500 miles and as of right now it has 10,006 miles on it. It grinds going into 3-4th above 4K RPM's and going into 6th as well. Looks like I will be visiting the dealer about this.
I will say other than this the car has been great. Minus the characteristic crickets. I just chalked that up to coming with the territory like Ford F-150/ Excursions burning the garage down or GM ignition issues.
Either Get Busy Livin or Get Busy Dyin
Xlr8 is offline   Reply With Quote
Old 05-07-2014, 07:44 AM   #35
86viper
Drives: 2013 Toyota 86 GTS
Im thinking this is a QA/QC issue
Im upto 20k miles and my car/transmission gets a beating regularly.
Its well serviced and looked after but is driven hard and touch wood, my transmission (and the whole car) is perfect.
86viper is offline   Reply With Quote
Old 05-07-2014, 08:07 AM   #36
slickd
slickd's Avatar
Drives: 2013 silver toyota 86 (high) man.
86 gearshift
Does anyone experience abit of difficulty shifting gears on the 86? Particularly moving between 1st and 2nd. When i stop at the lights and try slotting into 1st before the lights go green, i have to sorta force the gear in sometimes. Not sure if maybe its cause its cold outside and the weather affects it?
slickd is offline   Reply With Quote
Old 05-07-2014, 11:56 AM   #37
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
I see you didnt really read the whole thread before posting... notchiness is common on Aisan transmissions. The things you can do to help it are bushings/heavier knob/switch to better fluids. Moving back to neutral before angaging a gear can also help.
Sent from my SGH-I337M using Tapatalk
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 05-12-2014, 01:01 PM   #38
slickd
slickd's Avatar
ohhh
Sorry, didnt see the other threads. Thanks for the info
Old 05-15-2014, 05:38 AM   #39
Ingen
Drives: Ultramarine FR-S 6MT
Originally Posted by Muaddib View Post
I have the same problem but Toyota will NOT do anything about it. They told me to monitor the situation ( I guess till the 5th gear is completely gone).
Until our warranties are gone.
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 05-15-2014, 09:46 PM   #40
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
The S2000 had similar problem till they replaced the synchro in the AP2.
Muaddib is offline   Reply With Quote
Old 07-08-2014, 08:41 AM   #41
Nissanfan
Drives: subaru brz
How often does that happen to people here? I'm at 15k miles and start to notice hear grinding from 4-5 or downshift 4-3. It doesn't happen all the time, but more frequently, that I've have noticed it. I've questioned myself with not pushing clutch all the way, but that's not the case. Anybody else got their transmission looked at or replaced by the dealer? (Subaru)
2013 BRZ Limited 6speed Manual
Nissanfan is offline   Reply With Quote
Old 07-08-2014, 01:54 PM   #42
tomkozski
Drives: 2017 WRB BRZ w/ PP
Just had the 5th gear grind happen to me on my drive from Massachusetts back to DC. Occurred only 3 times, at random speeds (damn traffic in NJ and CT), and when I would try to recreate the situation it wouldn't grind.
I own a BRZ, but have the TRD Quick Shifter installed. For now I can't recreate the situation (transmission is working fine today), but would Subaru deny my claim since I have the Quick Shifter installed? It is a Scion-sanctioned part though...(fortunately I have all the original components, including the original rubber shift boot).
tomkozski is offline   Reply With Quote
5th gear, grinding, new transmission, transmission issue
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 12:08 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Any thoughts on my "mini" engineering and business plan.? KidWonder Off-Topic Lounge [WARNING: NO POLITICS] 24 12-29-2011 01:16 PM
