Old 05-28-2013, 05:20 PM   #29
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
Ill be honest as much as Im temped to dive right ino coilovers Ive decided to do a season on the stock suspention. Im quite confident I can put down some good laptimes without touching the dampers.
Living life one HPDE at a time
Touge Monster is offline   Reply With Quote
The Following 2 Users Say Thank You to Touge Monster For This Useful Post:
Kido1986 (05-28-2013), WillRacer1jz (05-29-2013)
Old 05-28-2013, 05:48 PM   #30
wootwoot
Drives: FRS
Put the list back up! Or at least PM it to me...
wootwoot is offline   Reply With Quote
Old 05-28-2013, 05:53 PM   #31
JerryMichaels7
Drives: Whiteout FRS
^ what he said i would also like a the list, and oan, has anyone tried the cusco zero 3s or even their street coilover.
JerryMichaels7 is offline   Reply With Quote
Old 05-28-2013, 05:56 PM   #32
IIRC, Cusco stuff is made by Showa, although that may be different in this case. Quality stuff, albeit expensive.
Old 05-28-2013, 05:59 PM   #33
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Eek....didn't mean to stir up all these demands by referencing that list.
People, it was just a compilation of suspension he's ridden on.
But what I WANT to see is a comparison of springs on stock struts so I can make the right choice. Basically that means I want to see data to back up my decision to get RCE Yellows.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-28-2013, 06:02 PM   #34
The only way I can do a true comparison, is to drive all the cars back to back with the same tire and the ideal alignment for each given setup. Even then, my personal bias toward a truly neutral system (which most people perceive as loose) will come into play...
From a "having it right out of the box" standpoint, two way adjustable coilovers are more forgiving. With a one way adjustable system, you only have one "right" spring rate for the compression that's in the damper, and one or two "right" rebound settings. The rest of the settings are just wrong, and shouldn't be used. If you change spring rates, then the compression damping will just never be matched. With a two way adjustable damper, you can swap springs for softer or harder rates, and then adjust both compression and rebound to match the spring.
Of course, the above is highly idealized, and not everyone has access to a shop or individual who can either dial in their dampers for them, or guide them to the right settings.
I'm actually pleasantly surprised that this thread didn't turn into a massive sh*tstorm.
Anthony (08-09-2013), Calum (05-28-2013)
Old 05-28-2013, 06:07 PM   #35
2point0
2point0's Avatar
Ok, feel free to start whenever....
Old 05-28-2013, 06:16 PM   #36
Please supply us with all the suspensions you wanted tested, an appropriate number of cars to put them on, staff to do the installations, recommended alignment settings, and rims/tires for each car.
LOL.
Then again, I should be careful what i wish for... Scion, are you listening?
Old 05-28-2013, 06:18 PM   #37
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
Originally Posted by Racecomp Engineering View Post
Calibrated butt dynos are excellent tools. Feel, driver preference, and driver confidence can be very important too...and sometimes drivers adapt and end up faster. But I do really like having a starting point over a wild-ass guess.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
The Following 7 Users Say Thank You to Kido1986 For This Useful Post:
akuhei (05-28-2013), CSG Mike (05-28-2013), Efferalgan (05-06-2014), F1point4 (08-14-2013), Pseud0logik (06-14-2014), Racecomp Engineering (05-28-2013), whataboutbob (08-23-2013)
Old 05-28-2013, 06:21 PM   #38
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
. Most people will perceive the (somewhat excessive) body roll to be hurting cornering grip
And most of them don't realize this will allow the tires to grip better than a too-stiff setup--netting quicker times--not to mention giving one more confidence.
I personally like a more compliant (read: softer) setup--as I'm getting my $$ worth out of my hi-po tires, and getting a real feel what the car wants to do.
But let's be real: many that have these C/O setups will never see the track, and if they do, not truly driven @ 10/10ths.
The dampers I have (MCS) weren't one that you sampled--but I'd venture to say (with appropriate spring rates) you'd really like them.
My .02...
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
The Following 2 Users Say Thank You to GTB/ZR-1 For This Useful Post:
B L U E S L A T E (05-29-2013), zdr93523 (05-03-2014)
Old 05-28-2013, 06:22 PM   #39
2point0
2point0's Avatar
Please supply us with (lots of stuff)...
Yeah...I'll get back to you on that.
Old 05-28-2013, 06:34 PM   #40
My .02...
I've been curious about MCS too, but I suspect I'd approve
Which dampers are you on?
Old 05-28-2013, 06:37 PM   #41
GTB/ZR-1
GTB/ZR-1's Avatar
MCS
Old 05-28-2013, 06:40 PM   #42
MCS
I meant model :p 2 way, 2 way custom, or 3 way?
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 09:11 AM
Some observations Nardi330 AUSTRALIA 20 02-07-2013 06:18 AM
90 Day Anniversary ..some Observations Scooby South BRZ First-Gen (2012+) — General Topics 6 09-03-2012 11:17 AM
Mike's track videos. CSG Mike Tracking / Autocross / HPDE / Drifting 2 08-16-2012 04:00 AM
First Payment sent, Observations after 6 weeks. Scooby South BRZ First-Gen (2012+) — General Topics 27 08-01-2012 02:02 PM
