Old 06-19-2013, 01:50 PM   #29
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
Thanks @neutron256! I really like the multi purpose gauges, and yours looks great in the vent pod! Thanks for the video and I'm glad the DIY helped you!!
Thanks again,
Rick
RallySport Direct is offline   Reply With Quote
Old 07-15-2013, 09:54 AM   #30
itdansharpe
itdansharpe's Avatar
Hey, this is a great tutorial. I ran through it when installing 2 gauges last week and noticed I was having overheating issues (the gauges themselves were overheating). Do you know what the source is of the 12v constant?
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 07-16-2013, 06:12 PM   #31
RallySport Direct
To be honest, I don't know the exact source of the 12V constant. I just poked around with my multimeter until I found a 12V constant and then tested it in all conditions to make sure it was an absolute constant.
What gauges are you using, and what are the symptoms? Anything else odd with the gauges besides the heat issue?
Thanks,
Rick
Old 07-17-2013, 07:59 AM   #32
itdansharpe
Thanks,
Rick
Strange things are happening.
I'm using Halo Prosport AFR & Boost gauges, and they are overheating. I mean hot. after about a half hour of use, they kick off due to the heat. Their support team suggested wiring in a 10amp fuse for the 12v constant, but to me, that just sounds like that won't solve the issue.
Old 07-17-2013, 12:47 PM   #33
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
Hey, because I am an idiot and do not understand the intricacies of forced induction, is a boost gauge recommended for a super charger? I do not plan on getting a turbo, but I do hope to get a vortech kit next year.
Thaaaaanks
Old 07-17-2013, 01:22 PM   #34
RallySport Direct
Yeah that is really odd, it may not be a bad idea to double check all of the connections, or check voltage on the wires. I was trying to do some research and was not able to find anything that would help you out. I will keep on digging though.
Thaaaaanks
Yeah, I would always recommend a boost gauge with any form of forced induction. Always a good idea to know how much boost you are running at any given time
Thanks,
Rick
The Following User Says Thank You to RallySport Direct For This Useful Post:
SkAsphalt (07-17-2013)
Old 07-18-2013, 10:07 AM   #35
itdansharpe
Thanks,
Rick
Hey Rick, I believe the 12v constant is shown to the left of this diagram, and runs off a 15A fuse.
http://img9.imageshack.us/img9/7673/ft86full.jpg
Old 07-18-2013, 06:53 PM   #36
RallySport Direct
Hmm, yeah that should be correct. I am not really sure on this one, you could try a different power source, but I would assume you would have the same symptoms, but worth a shot.
Thanks,
Rick
Old 08-15-2013, 10:46 PM   #37
sw20kosh
Drives: 2013 Black FR-S
If i have a 52mm gauge, would I need to buy the ATi 60mm vented ring + the 60 -52 mm adaptor ring?
Old 08-16-2013, 07:45 PM   #38
RallySport Direct
Correct, you would want to use the 60mm to 52mm adapter ring
Thanks,
Rick
Old 08-17-2013, 12:08 AM   #39
xclusive_brett
xclusive_brett's Avatar
Drives: 08 scion xb
got my shipping info today!
xclusive_brett is offline   Reply With Quote
Old 08-17-2013, 07:48 AM   #40
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
Originally Posted by ft_sjo View Post
Does this gauge holder work in either side?
Just to confirm, the gauge holder works perfectly in the right hand vent, for those of us who drive on the correct side of the road
(don't worry, my gauge is now vertical, and not slightly skew as in the picture)
Pitman is offline   Reply With Quote
The Following 3 Users Say Thank You to Pitman For This Useful Post:
ft_sjo (08-17-2013), Hags86 (08-17-2013), RallySport Direct (08-19-2013)
Old 08-19-2013, 05:29 PM   #41
RallySport Direct
Nice, that is great to know! Thank you for posting this up for our fellow RHD members!
Thanks again,
Rick
Old 08-19-2013, 06:15 PM   #42
RallySport Direct
Nice! You will have to let us know how you like it
Thanks,
Rick
Gauge install, dash cluster light cable, Tach RPM cable help... Sportsguy83 Electronics | Audio | NAV | Infotainment 99 08-07-2016 10:36 PM
FS [BNE] - Pivot DXW-R air vent gauge, Cusco catch can and Team Voodoo gear knob Nardi330 Australia Classifieds 3 04-22-2016 09:24 AM
DIY - Defi 60mm Boost Gauge Install in AC Vent msile DIY (Do-It-Yourself) Guides 55 02-27-2016 01:10 PM
How-to: Install JPM Coachworks Stitched Alcantara Gauge Cluster Hood JPM Coachworks DIY (Do-It-Yourself) Guides 109 05-01-2015 01:19 PM
DCW Single Gauge Pod - 52/60mm gauges - In stock USA No Limit Motorsport Interior Parts (Incl. Lighting) 17 06-27-2013 04:20 PM
