Old 08-12-2013, 02:34 PM   #29
vtmike
vtmike's Avatar
Drives: Scion FR-S
Anyone know the torque spec for the axle nut?
Sent from my SCH-I535 using Tapatalk 4
vtmike is offline   Reply With Quote
Old 08-12-2013, 03:24 PM   #30
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
140 pounds
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following User Says Thank You to feldy For This Useful Post:
vtmike (08-12-2013)
Old 08-12-2013, 03:25 PM   #31
feldy
feldy's Avatar
Originally Posted by dschock View Post
This clunk has been bothering me since I bought the car last September. Two dealerships have looked at it and the best I get is "We don't have another one here to compare to", or "Just let the clutch out slower". Getting pretty sick of this. This video is where I suspect the problem is coming from. The parking brake set and transmission in neutral, and I am able to rotate the drive shaft a good 20-30 degrees. Can anyone else try this out and post a video to compare?
That's just drive train slop. some of that is normal. To which extent I'm not sure.
Old 08-12-2013, 06:53 PM   #32
feldy
feldy's Avatar
Originally Posted by vteclol View Post
WHAT. Have there been any successful warranty claims for this?
It was a long time ago when I first noticed the sound (~12k miles now), but it initially only clicked when going from forward to reverse and vice versa. I though it was just another "normal" 86 sound, but now it's happening when on and off throttle. What a piece of junk.
Same thing here man same thing. Dealer torqued my nut down for me.still clicks going into reverse or something but not as much when the car is under load.
Old 08-12-2013, 10:37 PM   #33
Carwhisperer
Drives: A lot of supercars.
Mines ticking a LOT more than normal.. But I'm having much more serious misfire issues atm to deal with.
[ame="https://www.youtube.com/watch?v=OCyJ5-10QyE"]VID 20130616 175852 - YouTube[/ame] starts to tick at 0:13
Carwhisperer is offline   Reply With Quote
Old 08-12-2013, 10:39 PM   #34
FRS1010
Drives: 2013 FRS
Seems like if your car is lowered they are using that as an excuse to deny claims.
FRS1010 is offline   Reply With Quote
Old 08-13-2013, 02:59 PM   #35
ProTekk
ProTekk's Avatar
Drives: Whiteout FR-S
Getting the clicking/ticking as well, AT. Sound direction is hard to judge in the car but I swear it sounds like it's coming from the left rear axle. Could be wrong. Anything that we can check on our own?
ProTekk is offline   Reply With Quote
Old 08-13-2013, 03:48 PM   #36
feldy
feldy's Avatar
You can try to torque the nut down to 140lbs of torque
Old 08-15-2013, 07:31 PM   #37
feldy
feldy's Avatar
To anyone having this issue . Get to the dealer right away about it. I took it Saturday they torqued it down still doing the noise. Today they emailed me that I have a new axle at the dealer waiting to get replaced under warranty. Pretty rad as they didn't tell me they were even ordering one. I feel like they maybe more open to fixing it before it snaps as if you brought it in snapped but who knows.
Old 08-17-2013, 07:31 PM   #38
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Rampage View Post
Ticking common before this failure:
is there a DIY on how to prevent this before it gets to that point, or fix it after it does?
Old 08-17-2013, 09:20 PM   #39
kodyo
Drives: Scion FR-S
Some more discussion in this thread:
http://www.ft86club.com/forums/showthread.php?t=40463
If it happened to me and wasn't warrantied, i'd be tempted to go with this as a fix:
http://www.driveshaftshop.com/featur...-in-rear-axles
kodyo is offline   Reply With Quote
lifter tick? DarkCard Issues | Warranty | Recalls / TSB 11 02-07-2016 01:51 PM
Tick tick tick from the dash FRiSson Issues | Warranty | Recalls / TSB 23 06-12-2013 05:11 PM
Tick Click Tick (injector orgy) empower-auto Issues | Warranty | Recalls / TSB 4 08-27-2012 02:28 PM
Tick Tick injuryexpert Engine, Exhaust, Transmission 3 08-21-2012 08:31 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
