Old 08-05-2013, 10:02 PM   #29
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Originally Posted by #944_10_Series_FRS View Post
Why? there is slot in the bottom where you can mount the back up camera. See below. Isn't this better?
It works I guess but feel that the spoiler integration is more classy. My KIA Forte had one mounted in the position you showed and I felt it seemed as an engineering afterthought. I miss having a cam though so at this point anything is better!
BTW, I like the cam you have... Was it a diy?
Subaru STI :
Old 08-05-2013, 10:05 PM   #30
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
It will be tough to put this into the spoiler since you need to tie the nut in the back end and with the spoiler, you might have to drill another hole at the bottom so you can access to the nut to tie up the camera.
#944_10_Series_FRS is offline   Reply With Quote
Old 08-06-2013, 10:05 AM   #31
3_NA_HAF
Diesel Tech
3_NA_HAF's Avatar
Drives: 2013 FR-S Hot Lava 6MT
I've been super busy and kind of abandoned the finishing touches of mine. I used 18 gauge wire throughout. There isn't much of a power draw to worry about needing larger. I tapped power from the radio amplifier like the DIY, just because of location convenience. Don't know if I'm the only one, but this seems to be a bad idea. If the radio is on, there is too much of a voltage draw to run the camera properly. When I get back from my trip, I'm going to power it right from the battery, with a 5amp fuse. This makes sure there's no fluctuation in the voltage or amperage.
3_NA_HAF is offline   Reply With Quote
Old 08-07-2013, 01:10 AM   #32
Obsidiank
10 Series Fanatic
Drives: Scion FR-S 10
Did you not go with the beatsonic? This DIY is way harder than installing the beatsonic.
Originally Posted by Dustin2JZ View Post
ok so I have tried this several times now, going back and forth trying to get it to work and no matter what I do it never shows the backup camera.
I am not the type of guy who uses DIY's but i needed it for the correct pinnout of the headunit.
now my car is the 10 Series FRS but all the plugs look the same as the Bespoke.
What am I missing?
EDIT:
Ok I just figured it out, Thanks to a post on another thread, I realized the camera had to be powered within 3 seconds of the head unit powering on. Since I was just testing the wires and nothing is hard wired yet, my camera wasnt powered until later with my power probe. but after giving it power while cutting it on, everything works.
Obsidiank is offline   Reply With Quote
Old 08-07-2013, 12:50 PM   #33
Dustin2JZ
StatusLow
Dustin2JZ's Avatar
Drives: 2013 10 Series FRS
No i didnt go with the beatsonic. I personly just didnt like the white camera it stuck out too much to me. I like my black plate frames
Dustin2JZ is offline   Reply With Quote
Old 12-06-2013, 10:09 AM   #34
sufu05
Drives: Scion FR-S
So i wired up like this is written. bought the video adapter from svx guy, ran the reverse wire from the driver side kick panel to the harness in slot two and powered it from my amp for 12+ power and the camera kicks on when the head unit turns on. once i start playing music it wont go back on the camera mode, i need it to turn on when i put it into reverse.
sufu05 is offline   Reply With Quote
Old 12-06-2013, 10:14 AM   #35
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Double check that your trigger wire only engages when in reverse.
post_break is offline   Reply With Quote
Old 12-24-2013, 12:48 PM   #36
post_break
post_break's Avatar
Bump, this still works on all 2014 FRS's!!! I know because I just installed the 2014 headunit in my car and the camera works perfectly.
Old 05-07-2014, 06:42 PM   #37
FR-S Guy
Drives: '14 Whiteout FR-S
Holy thread revival!!!
Did anyone ever figure out what size terminal was required for properly adding the pin to the 28-pin connector?
And is it true that the camera must be powered when the car starts up? The camera I have has built in lights around it so I was hoping to power it only with reverse. Guess that won't work if this is the case....
FR-S Guy is offline   Reply With Quote
Old 05-07-2014, 07:53 PM   #38
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
Camera must receive power when the head unit starts up... you can not power it off the reverse unless you start the car in reverse, then pop it out of gear once the head unit has finished its bootup sequence.
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 11-16-2014, 10:43 PM   #39
zeal86
zeal86's Avatar
Drives:
This might be what you are looking for http://www.autoharnesshouse.com/23416.html
2014 6-speed Monogram (37J)
zeal86 is offline   Reply With Quote
Old 01-11-2015, 08:24 PM   #40
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Exclamation
Not sure if anyone has done this yet, but instead of mounting the camera below, possibly it could be mounted directly into the rear fog light housing for a more stealth and oem look. It could even be colored red to match.
Chad86 is offline   Reply With Quote
Old 01-12-2015, 07:19 PM   #41
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
You could, but I think the reverse cameras give you better view/perspective when mounted higher up. Also, my reverse camera is pretty darn oem looking, IF you even noticed it.
But, it doesn't hurt to explore
Old 04-05-2015, 12:23 AM   #42
laley81
Scion FR-S
laley81's Avatar
Drives: Scion FR-S 2013
Ok so nothing is working. I have tried everything on the original post. All wires are the same. I have the bespoke premium head unit and took it to 2 audio shops. For some reason today the camera decided to work. It worked for about 6 minutes. Later on the day it stopped working. What is going on? Why isn't it working on my headunit???? Help. Do I needed this adapter? I have a scion FR-S 13 with bespoke premium headunit. Any help will help. Thx.
Do I need to order this??
-1 Backup Camera Harness(Includes connections for 12-volt jumper harness, 16-pin head unit connection, Composite Video input, Relay, and 12-volt output lead)
-1 12-Volt splice harness(T-harness)
-1 Relay (6-volt input coil)
-1 Butt connector to connect 12-Volt output from harness to the backup camera
laley81 is offline   Reply With Quote
Scion FRS Bespoke Backup Camera, What do I need? post_break Electronics | Audio | NAV | Infotainment 8 07-02-2016 09:55 PM
Kenwood CMOS-210 Backup Camera Install TSY Electronics | Audio | NAV | Infotainment 34 12-10-2014 01:18 PM
Running Backup Camera Wire Tony Mac Electronics | Audio | NAV | Infotainment 9 12-04-2013 11:28 PM
Beat-Sonic Backup Camera & Adapter for FR-S (Bespoke) & BRZ Special Price Beat-Sonic Audio/Visual, Electronics, Infotainment, NAV 60 07-15-2013 03:58 PM
Backup Camera Help husker741 Electronics | Audio | NAV | Infotainment 2 02-13-2013 01:04 AM
