Old 05-11-2013, 11:52 AM   #29
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Curious to hear more about the boost control setup used on this car.
I'd highly prefer a setup like this where the boost is controlled by Ecutek. IM*H*O it should come set up like that out of the box really.
Props to @Viaconti for setting it up right!
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 05-11-2013, 01:09 PM   #30
Visconti
Drives: 05 STi
No problem
Ill be offering kits very soon
Visconti is offline   Reply With Quote
Old 05-11-2013, 05:42 PM   #31
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by driver01 View Post
as per the instructions from deatschwerks i used two orings. did not transfer
the spacer and o ring from the oem pump
Originally Posted by Sportsguy83 View Post
So now you have 4 O-rings? And, does the canister still close like normal with the added
o-rings?
I so much wish you tell me you are still using two, but fear you say 4. I don't want to take that shit out of the tank anymore!!!!
I took the plunge today, removed the fuel pump, and added two extra O rings, so now I have four. I can wholeheartedly say, my leaning issue sometimes at high RPM is gone. Car is now holding AFR's strong. I will update my journal soon.
Old 05-11-2013, 08:29 PM   #32
driver01
Drives: brz 13
o-rings?
yup, running 4 o rings
driver01 is offline   Reply With Quote
Old 05-11-2013, 08:59 PM   #33
driver01
Drives: brz 13
[ame="http://www.youtube.com/watch?v=Egaxj5VGWAU"]Dyno - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=baRJfXjny9o"]pull - YouTube[/ame]
Old 05-11-2013, 09:01 PM   #34
driver01
Drives: brz 13
Good to hear!!
we should contact deatshwerks and give them a piece of our mind for writing those instructions
Old 05-11-2013, 09:04 PM   #35
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
I just bought an injector and fuel pump kit from visconti... Wondering if they come with sll the extra orings
Silverdub is offline   Reply With Quote
Old 05-11-2013, 09:04 PM   #36
Sportsguy83
Drives: Limited BRZ
Good to hear!!
I know!! And the sad part is that before installing i called and triple asked to be sure about all the install process. .
Although in their defense, maybe we dod something wrong installing the whole fuel keg assembly in the tank? Maybe not tight enough and that allows the FP to come out of its place a bit?
I wouldn't rule it out at least in my setup. This time I did everything properly (specially the freaking gasket) and tapped the lid a bit with a hammer and screwdriver to make sure it is TIGHT!!
Old 05-11-2013, 09:16 PM   #37
Sportsguy83
Drives: Limited BRZ
The Visconti Pump uses the stock white spacer and includes two O rings. You won't need four for that one, two are fine.
The DW pump does not use the OEM white spacer but only includes two O Rings.
Old 05-11-2013, 09:22 PM   #38
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Hopefully ill be ae to boost more spiking 12 and holding 8.5 isnt enough!
Old 05-11-2013, 09:41 PM   #39
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
Originally Posted by AVOturboworld View Post
A hub dyno and 10.5 psi of boost.
Already hit 250~260 ft/lbs at 10.5psi, and 295whp on 92. After that, though, you are looking at a fuel pump, possibly injectors, and definitely a clutch.
soooo your saying we can push 10.5 on stock components !?!??!
and possible a little more with 93 ?
killerkid08 is offline   Reply With Quote
Old 05-12-2013, 02:18 AM   #40
Visconti
Drives: 05 STi
It's not suggested.
Nothing good can come from over taxing the direct injection system.
If your after higher boost levels spend the extra money on injectors .. Ecu controlled boost is also the cats ass
John
Old 05-12-2013, 10:52 AM   #41
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
It's not suggested.
John
then i ll be buying that boost controller kit once you bring it out.. any eta on that?
Old 05-12-2013, 02:07 PM   #42
Visconti
Drives: 05 STi
Just waiting for units to come in.
Sometime next week
Worlds Fastest Turbo BRZ gets faster! Accelerated Performance Built - Visconti Tuned Visconti Forced Induction 697 11-13-2013 06:18 PM
Congiiee's Vortech Supercharger INSTALLED!!! Visconti Tuned congiiee Forced Induction 131 05-30-2013 12:28 AM
Visconti Tuned 0-60 brichard0625 Engine, Exhaust, Transmission 96 09-16-2012 09:56 PM
Worlds fastest BRZ - Accelerated Performance Built - Visconti Tuned !!! Visconti Forced Induction 135 09-06-2012 05:43 PM
Another Accelerated Performance Turbo BRZ - Visconti Tuned ! Visconti Forced Induction 34 08-28-2012 12:47 AM
