Old 04-29-2013, 02:08 PM   #29
ptuning
ptuning's Avatar
Drives: White FR-S
Yeah. I am still hoping to get back on a dyno and fine tune my ignition timing for MBT as you can't do that on a street tune.
Sounds good. Yeah, definitely get the car on the dyno to tune timing. You'll often find that street tuning alone can often result in exceeding MBT during parts of the first 4-5K of the powerband.
ptuning is offline   Reply With Quote
Old 04-29-2013, 02:13 PM   #30
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
This is the meth kit I have been running.
Works GREAT!
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
The Following 3 Users Say Thank You to deucethemoose For This Useful Post:
Sonolin (04-29-2013), Sportsguy83 (04-29-2013), Tomzilla (04-29-2013)
Old 04-29-2013, 02:18 PM   #31
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Originally Posted by ptuning View Post
The few pump failures we've seen in the past were on cars that sat around for 6 months to a year at a time without running. In cases like these, even the fuel pump can clunk out too.
Justin, our lead tech, has been using the same WMI pump and system for the past 7 years. It's seen use on his xA with the Blitz SC, non-intercooled Greddy Turbocharger, and now the PTUNING Turbo and Built Motor (stock cylinder head) combo.
His car currently makes 350+WHP on our DD Dyno with 93 octane pump and WMI. For the first 3-4 years, he was running just -20F blue windshield washer fluid, but has recently switched over to a 50/50 custom blend.
His xA currently has 147,000+ miles on the odometer. He estimates that his WMI pump has seen over 120K of use so far. So yeah, WMI can be very reliable.
Same here. I have multiple systems that have been running without failure for nearly 10 years and another running on 4 years without failure @ 70k miles. As long as you are maintaining your system it has the potential to outlast your engine. When I refer to maintenance I just mean cleaning your nozzles from time to time. I did have a SNOW boost referenced module that had a failure right out of the box years ago but I caught it before install since I bench test all the systems before installation. It was not progressively PWMing the pump but rather just full injection regardless of the ramp up settings. SNOW replaced it no questions asked. AEM modules DO NOT GET WET or they can do some funny things. I learned this the hard way before I realized they are not weather packed for spraying the engine bay out haha (My fault). After it dried out out though no issues at all. I believe somewhere in their instructions it even warns you about getting their module wet. Long story short, the systems don't really seem to have a shelf life even under daily abuse.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
NA water meth injection? Ingen Engine, Exhaust, Transmission 26 06-03-2014 05:08 PM
AEM WATER METH METHANOL INJECTION KIT JPxM0Dz Engine, Exhaust, Transmission 10 04-13-2013 11:03 PM
Meth/Water Injection question showbe Engine, Exhaust, Transmission 9 10-18-2012 07:25 PM
Nitrous Oxide/Meth injection JDLM Engine, Exhaust, Transmission 6 12-17-2011 04:23 AM
