Old 01-23-2012, 07:41 PM   #29
Gearbanger
Gearbanger's Avatar
Drives: Lexus is300 celica gts
Wow that's weak. NA cars dont respond well to bolt ons. My wife's Camry has more whp.
Gearbanger is offline   Reply With Quote
Old 01-23-2012, 07:43 PM   #30
merlin2111
merlin2111's Avatar
Drives: Widebody '94 Miata R-Package
Looks like the hp/weight will be similar to my NA Miata which is no drag queen but can get my 215 star specs sideways at will around corners. This car will be a great replacement just with a warranty!
I <3 my Miata.
But I <3 my new BRZ even more!
merlin2111 is offline   Reply With Quote
Old 01-23-2012, 07:45 PM   #31
merlin2111
merlin2111's Avatar
I <3 my Miata.
Old 01-23-2012, 07:45 PM   #32
MiguelAE86
Drives: NB Miata
Anyone notice the nifty shift-sound indicator? that's AWESOME! toyota's paying attention to the details!
MiguelAE86 is offline   Reply With Quote
Old 01-23-2012, 07:50 PM   #33
catharsis
Drives: honda civic si 08
Originally Posted by merlin2111 View Post
He's right, if his wife has the v6 camry it will smoke this thing. This car won't be fast by any measure...
catharsis is offline   Reply With Quote
Old 01-23-2012, 07:51 PM   #34
illmatic
illmatic's Avatar
Drives: BRZ Limited 6MT, 02 AW, 03PSM WRX
Actually, that feature has been standard since the 2001(GDB) WRX STi.
illmatic is offline   Reply With Quote
Old 01-23-2012, 07:51 PM   #35
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
Originally Posted by smadasam View Post
I don't know why people are whining so much about open deck. I think there are some cooling advantages. Besides we aren't really talking about a lot of power. I have an open deck ej205 (built) that puts down a reliable 330 whp for the last few years. That block can handle much more than that.
i don't mind open deck there are some perks, but im just a bit surprised! especially considering vs your open deck ej205.
-the FA20 has 12.5c/r vs your 8.1c/r. (less volumetric pressure on cylinder walls)
-D4-S which naturally runs leaner and combustion temps are much hotter
-86x86 vs 92x75 (RPM vibrations)
big thing i was worried about was long term wear and fatigue without additional the structuring. i was expecting semi-closed deck. not a fully closed deck.
Originally Posted by gal1950 View Post
Good luck with getting more horsepower out of this engine without turbo charging it. I have owned 25 Subaru's with 1.8- 2.5 N/A and Turbo Boxer engines, and increasing horsepower and torque, other than turbocharging, is not easy to do. Most think by putting exhaust and cold air intake system that this will achieve the performance you want. With most engines it might be the case, but not with the Boxer N/A engine. This is the same engine type, that is now found in the new Impreza 2012, which puts out only 148 hp, and about 145 torque. Subaru has worked on this engine, to achieve 170 hp and about 152 torque, so other than turbo, or supercharging this engine, I wouldn't suspect to much more left, without expensive engine modification. Also most N/A Boxer engines stock will only allow you do achieve more hp and torque with low Turbo PSI 4-6, more than that, the internals will not last. I have heard that Subaru expects to a Turbo for the BRZ, but haven't heard anything for the FR-S. But your typical bolt ons don't respond the same way as with other 4 cylinder engines.
FB not same structure as FA
lurk more
WingsofWar is offline   Reply With Quote
Old 01-23-2012, 07:54 PM   #36
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by WingsofWar View Post
im still more interested in the TQ curve than peak hp
Tq=Hp*RPM/5252
They show the Horsepower curve, you can figure out the tq from there if you need to so badly.
Old 01-23-2012, 07:56 PM   #37
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Originally Posted by Calum View Post
Tq=Hp*RPM/5252
formula for peak tq..not same as looking at tq graph.
Old 01-23-2012, 07:56 PM   #38
Calum
That Guy
Did anyone notice the size of the intake and exhaust ports? That alone tells me the head should be capable of flowing well.
Old 01-23-2012, 07:59 PM   #39
Calum
That Guy
No, it's the formula for tq. You can look at the Hp graph and get an idea of the values at different points in the curve and plug them into the formula. Or you can ignore the Tq and understand that horsepower is a measure to the amount of work the engine can do.
Old 01-23-2012, 08:01 PM   #40
Silverpike
popular among the JDM
Silverpike's Avatar
Drives: 2014 BRZ Limited
Originally Posted by lfawishes View Post
yeah its always employed as a cost cutting measure by subaru it seems.
It's not a cost cutting measure.
Silverpike is offline   Reply With Quote
Old 01-23-2012, 08:03 PM   #41
Gearbanger
Gearbanger's Avatar
Right 07 Camry 268 at the flywheel. Should have gone with turbo NA is nice but not unless it's a LS1 etc.
Old 01-23-2012, 08:10 PM   #42
catharsis
I mean the motor size and everything would have been ok if the car didn't weight 2750 pounds. If it was more at its original goal of 2500 then it'll been pretty damn impressive.
86 dyno, brz dyno, fr-s dyno, frs dyno, hks 86, hks fr-s, hks frs, hks toyota 86, scion fr-s dyno, scion fr-s hks, scion frs dyno, scion frs hks, subaru brz dyno, toyota 86 dyno, toyota 86 hks, toyota gt86 dyno
Any publication strap this car on a dyno yet? mspeed6 Engine, Exhaust, Transmission 67 02-02-2012 04:48 PM
Autoguide gushes on Scion FR-S (w/ track drift video). Says destined to become icon. ZetaVI Scion FR-S / Toyota 86 GT86 General Forum 111 12-16-2011 02:47 AM
Dyno testing and "drivetrain loss" serialk11r Other Vehicles & General Automotive Discussions 5 11-03-2011 08:55 AM
Best drift ever Matador Off-Topic Lounge [WARNING: NO POLITICS] 1 05-11-2010 01:48 PM
ft-86 drift trueno Scion FR-S / Toyota 86 GT86 General Forum 46 01-21-2010 04:39 AM
