#29 |
Drives: small
Can you give an idea of what kind of camber plates you were looking at for the Ohlins project? I was actually about to pull the trigger on some Hancheys. Might still if such a project would takes a bit more time.
One way is the only thing that has kept me from getting the Ohlins. My last car had KW v.3s and the thought of finally getting Ohlins but w/ only one-ways is something of a downgrade psychologically and possibly performance wise. It was down to Ohlins or the Bilstein damptronic (leaning Bilstein) for me till I heard about this potential project. |
#30 |
People jumping on the Ohlin's wagon because it's proven and expensive.. while it is a seriously awesome kit, it's not adjustable - which is a big nono for me!
#31 |
Drives: '23 BRZ
Ohlins R&T DFV adjustment is for low-speed rebound and compression damping. The ratio between rebound and compression is appropriate, so not necessarily a huge benefit to having them separately adjusted. Remarkably smooove and very well-controlled. Lack of camber adjustability up front would be my main issue with them on the 86.
| The Following User Says Thank You to ZDan For This Useful Post: | CSG David (11-10-2013) |
#32 | |
Just a dude
Drives: Scion FR-S 2013
| The Following User Says Thank You to OICU812 For This Useful Post: | CSG David (11-10-2013) |
#33 | |||
Like ZDan said, 1-way is supposed to adjust rebound and compression simultaneously in proportion to each other, but in reality, 1-way adjustable setups affect rebound more than the compression. Simply put, you are basically stuck with that particular spring rate since the valving is tailored specifically to that spring rate. There is absolutely no "downgrade" to this. If the suspension kit is high end enough, there will be much more quality differences than the lower end market. On top of that, most people are not able to tune 2-ways properly. To give you an idea, many clients come to us asking us to help them out with their suspension setups, more particularly KW V3 or Club Sport owners. They end up realizing their rebound and compression settings are way off. The KW line up is formulate as a street coilover with some competition built into them. If you want the real deal KW motorsports stuff, then you have to be willing to pay for it just like the Ohlins 2-way setups. Quote:
There are adjustments on the R&T with camber plates. So I'm not sure what adjustability you're looking for? Quote:
The benefit of a 2-way is much more effective in the hands of the proper user/tuner. While Ohlins R&T is extremely high end compared to their competitors (unless you're pointing out the ASM Sachs stuff... ), it also utilizes proper engineering to provide significant differences per click. This is one of the best 1-way available on the market and it's proven to be rightfully so. |
| The Following User Says Thank You to CSG David For This Useful Post: | whataboutbob (11-10-2013) |
#34 |
Drives: '23 BRZ
#35 | |
Drives: 2005 Toyota Camry
Would you, as a driver, benefit from having 2-way adjustment? Do you know how to set this up and dial it in? Or do you have access to someone that can test the car out for you? Are you good enough of a driver to know/feel the difference? A lot of times people want adjustability, but they don't know what to do with them. I got Ohlins for a variety of reasons, but in the end I just wanted something simple for street and track use given my skillset. Tein SRCs and KW V3s/Clubsports are great, but beyond the "what you pay is what you get" mentality, there's also a matter of if all the adjustments will be more harm than good. Unless we're all the same driver behind the wheel, a lot of suspension choice comes down to driving experience and on-hand resources available. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | CSG David (11-11-2013) |
#36 |
Site Moderator
Drives: Stuff
I like Ohlins.. but that seems like an absolute statement that isn't always true, especially on production cars.
I can't suggest either for the BRZ as I haven't driven either on a BRZ. In my experience with other cars I'd almost always rock Penske's over Ohlins though
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | CSG David (11-11-2013) |
#37 | |
Ohlins R&T is a good offering in the 1-way format. However if you want a motorsports grade coilover, SRCs are the one of the best coilovers for what you're looking for in terms of performance, quality, and value. If you are interested in having your multi-way coilovers dialed by CSG, let us know. |
| The Following User Says Thank You to CSG David For This Useful Post: | whataboutbob (11-20-2013) |
#38 | |
#39 | |
Site Moderator
Drives: Stuff
) and don't own a set
-Dave
#40 | |
#41 | |
Site Moderator
Drives: Stuff
-Dave
#42 | |
Back on topic though: Ohlins R&T if you want that 1-way street style setup; SRCs if you want that motorsports grade 2-way coilover. R&T can track, but obvious limitations due to valving and dual workhorse design. Both ride very well on the street. R&T ~ SRC on street. SRCs > R&T on track. |
| FS: Tein Flex Coilover | Jade 86 | Brakes, Suspension, Chassis | 43 | 06-15-2013 10:35 PM |
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 09:15 AM |
| TEIN COILOVER SPRINGS | jammz | Brakes, Suspension, Chassis | 0 | 04-01-2013 02:33 AM |
| Found a new coilover option from Tein | JoeBoxer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 02-23-2013 12:17 AM |
