Old 03-26-2013, 05:47 PM   #29
efactor84
efactor84's Avatar
Drives: 2015 Scion FR-S
Just curious about the trims compare to Perrin's Intake. This may make me have a split decision making on both.
efactor84 is offline   Reply With Quote
Old 03-27-2013, 12:31 AM   #30
nb2005
Drives: Scion FRS
just curious how hard it is to change out the filter. Is the filter foam or cotton ? Oil or dry ?
nb2005 is offline   Reply With Quote
Old 03-27-2013, 09:31 AM   #31
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Today is a beautiful day so ill bring the laptop with me and try do some runs while im out and about. Going to race the bmw to the bronx today so ill do some logging while im doing that.
brichard0625 is offline   Reply With Quote
Old 03-28-2013, 05:38 PM   #32
brichard0625
So today i was doing some simple data logging and this veloster turbo pulled up next to me and was egging me on the race. So i decided to record the log and got a little 2nd gear pull from 2000 to 7400rpm and put it in virtual dyno. Theres a little dip on the end because of the run had a slight dip at the end of the run but i got a pretty good run logged.. This is with visconti's updated map and for a 2nd gear pull i thought it was pretty good numbers wise. By the way the veloster is pretty freaking slow, was barely a challenge from about a 20mph pull but for some reason i love the look of the car. not sure if it was a manual or auto but i hear the auto veloster turbo is faster than the manual.
Old 04-03-2013, 11:45 AM   #33
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
I'm interested in this answer to, as the Perrin one looks to be abit of a pita to deal with taking the bumper off etc. Not sure there is an easier way however with this general design?
Old 04-03-2013, 11:52 AM   #34
brichard0625
http://store.automasteramr.com/AMR-B...tem_p_177.html
some pictures of how the intake looks with the bumper off..not sure if its easy to take off and put back on...
Old 04-03-2013, 12:00 PM   #35
Xdragonxb0i
Drives: ex500r
Well all cai designs would require taking off the bumper to install. Correct me if I'm wrong. If you want to be lazy. Get is a ram intake or drop in air filter
Xdragonxb0i is offline   Reply With Quote
Old 04-03-2013, 12:07 PM   #36
OICU812
Just a dude
OICU812's Avatar
LOL fair enough, guess my comment sounded lazy, just was thinking if there was some sort of a break down connector where the front snorkel/filter could be motivated out from backside was all.
Old 04-03-2013, 12:08 PM   #37
brichard0625
Well you can pop open the hood and pull the bumper back just a little to get to the filter but im not sure if it will be that simple...when i get a chance ill check it out and see if can be done without breaking anything or putting too much stress on the bumper
Old 06-04-2013, 12:26 PM   #38
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
Just ordered this intake for mine this morning. Pretty excited to get it! I was going to go with Perrin's until I saw this was an all stainless design.
IG: @dustin_faulkner
Kuzuri is offline   Reply With Quote
Old 06-04-2013, 01:31 PM   #39
brichard0625
let us know how u like it...so far i have no issues with the intake. and you can def feel the power increase in the middle of the rev band
Old 06-04-2013, 02:09 PM   #40
jordanrw260
Drives: Dark Grey Metallic 2013 BRZ
Have you had drop in filter previously before you had this intake to feel the difference between the two?
jordanrw260 is offline   Reply With Quote
Old 06-04-2013, 02:56 PM   #41
brichard0625
yes i have. I have used an hks filter and i have made a 3inch inlet tube with hks filter. I will say that the hks filter has a little more throttle response but once you hit 3000 rpm you can feel nice increase all the way to redline..and the sound is way better than a drop in
Old 06-04-2013, 03:07 PM   #42
jordanrw260
Thanks I currently have the hks drop in with Perrin inlet tube. You have given me something to consider.
Sent from my DROID RAZR using Tapatalk 2
2013 Subaru BRZ Metallic Grey 6-Speed - Mods: HKS Drop in, Perrin Inlet Tube, Kartboy Crank Pulley, Berk HFC Front Pipe, Borla UEL Header, PLM Overpipe, Open Flash Tablet Stg 2 tune
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
