Old 03-14-2013, 06:22 PM   #29
dsmx17
4g63>rotards
Drives: 98'GSX 11'Tundra 10'Wrangler
Originally Posted by FirestormFRS View Post
A hydro locked engine in most circumstances dies period. I've seen hydro locked engines on the inside and it's never just one cylinder that is messed up. Generally all four are jacked up and they roll out the side of the block. I doubt it's hydro locked at all
^This.
A couple years ago, I was installing 1600cc injectors on my racecar, after the install and priming the rail, the engine would not turn over by starter or by bigass prybay (on crank) long story short, the injectors were faulty and stayed open under pressure and filled all 4 cylinders with c16....so ofcourse I thought I was boned....(by this time im a case deep in heiniken) and I notice a old spray bottle, I took the top spray pump off, stuck the plastic hose into the cylinder and BAM! fuel pumped into empty Heiny bottles.
the point is, when it locked it was not running however it literally would have locked the whole drivetrain if it pulled enough water to bend a rod.
tldr; shit happens, good luck.
*edit* its also pretty awesome to see fuel shoot over the hood when you crank a hydrolocked engine and plugs out.
dsmx17 is offline   Reply With Quote
Old 03-14-2013, 06:59 PM   #30
pozer
pozer's Avatar
Drives: 13 FR - s
Send a message via AIM to pozer
Just so we are all on the same page I did not bypass the MAF and in the pic the yellow does show where I drilled the box
pozer is offline   Reply With Quote
The Following 2 Users Say Thank You to pozer For This Useful Post:
Sportsguy83 (03-15-2013), tripjammer (03-19-2013)
Old 03-14-2013, 07:04 PM   #31
jeebus
Drives: 2015 Mustang GT (on order)
I don't understand why you would drill the box like that...regardless, I also don't see how it would cause a problem.
jeebus is offline   Reply With Quote
Old 03-14-2013, 07:22 PM   #32
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
you drilled holes in your airbox? why?
resonator hole left open? but its fine like that?
this cant be real, troll post?
Huehuecoyotl is offline   Reply With Quote
Old 03-14-2013, 07:36 PM   #33
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
+1 DAFUQ?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 03-14-2013, 07:46 PM   #34
FirestormFRS
I so wish I had a picture of the last engine we got a look at. All four rods were bent at 30 degrees. Bearings were flattened, pistons were in pieces. A truly hydro locked engine will not have a bearing knock, it will have a large hole in the crankcase
FirestormFRS is offline   Reply With Quote
Old 03-15-2013, 02:42 PM   #35
Marrk
Drives: Honda Fit
Drilling the air box and removing the resonator may be irrelevant to the issue, but it doesn't help in terms of arguing with these people. And argue I would. Argue the h*ll out of them. There should be an abundance of water evidence (and, as you say, salt) in a hyydro-lock situation. Plus all the other good points that folks have raised in this thread.
So, tell me again: Why do we live in a culture where consumers are willing to tolerate this kind of "buyer does our beta testing for us" sh*t? It only ever leads to mfrs. denying that they brought to market an underdeveloped product.
Marrk is offline   Reply With Quote
The Following 2 Users Say Thank You to Marrk For This Useful Post:
alrashwa (03-22-2013), tripjammer (03-19-2013)
Old 03-15-2013, 03:06 PM   #36
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
Originally Posted by evo4g63 View Post
+1 DAFUQ?
My dad drilled holes in the airbox of his F-150. He said he liked the way it made the truck sound
NRGBalanced is offline   Reply With Quote
Old 03-15-2013, 03:11 PM   #37
Marrk
Drives: Honda Fit
A likable, louder sound is almost always the only outcome of this kind of mod. Same with CAI, etc. Good for posers. Bad for avoiding from the PD. Zero for performance.
Old 03-16-2013, 12:53 AM   #38
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
1. That IS knock
2. That IS horseshit.
3. Sorry man
driftartist is offline   Reply With Quote
Old 03-16-2013, 01:05 AM   #39
Grishbok
Volunteer Fire and Rescue
Grishbok's Avatar
Drives: Ambulance... sideways.
I think they are going to have to pull the black box data to identify what really happened in the motor. The dealership is doing what they do, trying to identify WHY something happened. Politely remind them that their job is to fix it, not waste time playing detective for hypothetical causes and effects. If they believe its in questionable territory, then a scion customer representative can come in and inspect the vehicle and black box data.
It's more fun to drive a slow car fast, than a fast car slow.
Grishbok is offline   Reply With Quote
Old 03-18-2013, 09:23 AM   #40
pozer
pozer's Avatar
Drives: 13 FR - s
This is my intake box.
The Following User Says Thank You to pozer For This Useful Post:
Old 03-18-2013, 10:55 PM   #41
brbrz
Drives: 2013 BRZ Limited DGM
My friend's had had an '83 Civic that that was hydro locked. Bent all 4 piston rods into S shapes but that was the only damage. Replaced the piston rods and put another 100K miles on the car. Weirdest looking thing to see a bunch of piston rods bent like that.
brbrz is offline   Reply With Quote
Old 03-18-2013, 11:15 PM   #42
Captain Insano
I have never liked dealerships, reading this just reinforces my hatred.
BC Racing Coilovers - Knock? 636 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 12-09-2015 10:41 PM
anyone experience engine knock on 91 octane? chenshuo BRZ First-Gen (2012+) — General Topics 15 01-13-2013 07:10 PM
Why you shouldnt support knock off companies.. showbe Engine, Exhaust, Transmission 44 10-29-2012 08:13 AM
Single knock when coming to a stop oops86 Issues | Warranty | Recalls / TSB 14 08-05-2012 01:17 AM
Would you rather buy knock off parts for your car? EJ20 Engine, Exhaust, Transmission 63 11-02-2011 06:17 PM
