Old 03-03-2013, 01:05 AM   #29
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
Originally Posted by Black Tire View Post
What weight can be removed from a car in RSR. Spare tire, tool kit, owners manual, back seat, acid dipped body? What is allowed?
In RTR you can remove weight by using lighter weight wheels (although as seen above a lot of the weight is gained back by using heavier tires) but the wheels need to be the same as stock size height and width, and the offset has to be within 1/4" or 6mm. The spare tire, jack and associated hardware in the trunk can be removed to save around 31 lbs, a muffler delete can be installed to save 23 lbs, you can run minimal fuel to save up to 70-75 lbs, and the floor mats and owner's manual, other glove box junk can be removed. That's all that comes to mind without doing crazy stuff like shaving down stock brake rotors to the minimum spec to save a half pound to a pound per corner.
Unfortunately nearly all of the weight that can be removed in CS/RTR on our cars is in the back. Some people prefer to leave a lot of that weight back there to maintain the factory's front to rear weight distribution, personally I usually prefer to lose the 120 lbs and try to drive around it.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
KW V3 Setup for Street use. Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 09-03-2016 02:48 AM
Optimal Wheel Size for Stock Power Tanuki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 110 06-09-2016 10:08 PM
optimal street tire size for RTR on 17x7 hankster Tracking / Autocross / HPDE / Drifting 110 03-21-2013 12:40 AM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Optimal tint (California mostly) Oriental Life Southern California 49 08-17-2012 07:05 PM
