Old 02-13-2013, 03:04 PM   #29
MissNyxxie
MissNyxxie's Avatar
Drives: 2013 Scion FR-S - Asphalt
Now that I've lifted my jaw.... this stuff is awesome!
MissNyxxie is offline   Reply With Quote
Old 02-13-2013, 03:48 PM   #30
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Originally Posted by blackraven1425 View Post
A couple of the comments on the video seem to say that's probably a bad idea. It's toxic to inhale since it's a silica, and if you jumped in the pool, you'd hit the bottom as if there's no water in it.
EDIT: After doing some looking around, it's not transparent. It's a bit cloudy in appearance. They're working on a transparent version, which would obviously be a bit more appropriate for external use. There's also claims that it doesn't take to abrasion very well. It's removed with standard detergents, but I'd think that's not an issue since you'd never need to wash the car anyway.
This stuff would not make you sink. Your body is still less dense than water regardless of how slippery you are. Buoyancy is a simple matter of the weight of the water displaced and the weight of the object displacing the water. A stone for example, is denser than water and thus for the same volume of water, it weighs more, so it sinks. a beach ball weights almost nothing and displaces a large volume, therefore it hardly displaces any water at all and floats very high on the surface. The human body is mostly water but slightly buoyant in most cases (Unless you fill your lungs with water) so you'd still float. You'd just wouldn't really get wet.
Nathan
SubieNate is offline   Reply With Quote
Old 02-13-2013, 03:59 PM   #31
SnapOv3st3r
Drives: 400whp Scion tC
Great for garage floor perhaps. But if it's weak to abrasions then it might not last to long being on the garage floor. It looks pretty awesome.
SnapOv3st3r is offline   Reply With Quote
Old 02-13-2013, 04:50 PM   #32
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
Blackraven, you do know that silica is sand, right? It's in your toothpaste, it's what glass is made of. It isn't toxic, and it has no water- and oil-repellent properties.
b.e is offline   Reply With Quote
Old 02-13-2013, 05:54 PM   #33
SubieNate
SubieNate's Avatar
Silica is only bad if you inhale it. Silicosis is no joke. But, it's generally only an issue with chronic exposure.
Old 02-13-2013, 06:18 PM   #34
blackraven1425
Drives: raven at
Nathan
You're missing the fact that you'd jump in and slide right through the water. Surface tension isn't so strong when the water is rushing away from you as fast as possible. Sure, you'd be buoyant after you settle, but you'd also be carrying that momentum straight to the floor of the pool.
I could see this being brought up in a massive controversy in a couple years at the next Olympics when someone decides it's a good idea to toss it onto their swimsuit. It's be much better than the sharkskin replicas they're making now.
blackraven1425 is offline   Reply With Quote
Old 02-13-2013, 06:20 PM   #35
blackraven1425
Drives: raven at
When it's an extremely fine particulate, it's going to ruin your lungs. Look up acute silicosis. It'll irritate your eyes and skin too.
Old 02-13-2013, 06:42 PM   #36
SubieNate
SubieNate's Avatar
Still, you'd come back up. You're still displacing water which makes drag, which means you'd stop at some point even if you were diving into the Mariana trench. Skin friction drag is only one part of the equation, you still have the parasitic drag caused by your body forcing water to flow around it as you travel and the vortices and disturbances you leave in your wake.
Old 02-13-2013, 06:58 PM   #37
blackraven1425
Drives: raven at
Definitely, except I already hit the bottom of a 6 foot pool jumping in quite easily. Removing a large portion of the drag entirely would mean I'm going to hit it much harder than I do now.
Old 02-13-2013, 07:00 PM   #38
SubieNate
SubieNate's Avatar
Solution: Bellyflop every time.
The Following User Says Thank You to SubieNate For This Useful Post:
bestwheelbase (02-14-2013)
Old 02-13-2013, 07:35 PM   #39
b.e
Seriously? The particles are going to leap out of the coating as a fine dust?
My point was, the silica isn't the active ingredient. It's the fibers.
Old 02-13-2013, 07:38 PM   #40
wrxgoose
WUB WUB
Drives: 2013 Firestorm
i think that they need to test it now. put it on a model boat that obviously floats, then chuck it into a pool
wrxgoose is offline   Reply With Quote
Old 02-13-2013, 09:21 PM   #41
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Toilet bowl I think wins the thread.
Game over.
PRO86 | WTCC | STL
Old 02-13-2013, 10:47 PM   #42
wrxgoose
WUB WUB
only problem is when you have paper in there, then flush might take some of the stuff with it.
i got the frictionless toilet bowl idea from a book a long time ago. but it'd be so awesome
The most amazing thing I've done with my BRZ so far azngolfur BRZ Photos, Videos, Wallpapers, Gallery Forum 8 01-09-2013 09:23 PM
Get on the Waiting List for Sonax Nano Polish and Fine Abrasive DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 0 10-18-2012 09:34 AM
Amazing car physics engine Suffa Off-Topic Lounge [WARNING: NO POLITICS] 1 10-07-2012 01:51 AM
The Amazing Spiderman trailer vaporiz Off-Topic Lounge [WARNING: NO POLITICS] 13 02-14-2012 04:13 AM
Nano house $700. 1660 Off-Topic Lounge [WARNING: NO POLITICS] 1 07-29-2011 04:04 PM
