Old 12-04-2011, 02:39 AM   #29
LSxJunkie
LSxJunkie's Avatar
Drives: Car
Originally Posted by DuMa View Post
found this
its for the GT86 but BRZ might as well be sporting these 16s if its true for the premium.
6.5" wide steelies? Those will be great for snows.
LSxJunkie is offline   Reply With Quote
Old 12-04-2011, 11:57 AM   #30
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
found this
According to MT they will, however, the FR-S does not.. pay more.. and get crappy all seasons on steelies? Again, Subaru just isn't that stupid
It will have the 17 alloys for the premium, I can't see them doing anything LESS than the cheaper FR-S.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-04-2011, 01:12 PM   #31
madfast
Drives: 2010 Evo X MR-T
Regarding the Stability control, what do you guys think the difference is between pressing the VSC OFF once and VSC Sport? which mode allows more slip? i know in my car, and probably others, if you press VSC OFF once, it turns off the throttle cut portion of VSC. if you hold down VSC OFF for 3 sec then it turns off the braking portion of VSC too, thus turning off VSC completely. is that the case here? so then does that mean VSC sport leaves on both throttle cut VSC and braking VSC, and just raises the limit?
madfast is offline   Reply With Quote
Old 12-04-2011, 01:26 PM   #32
LSxJunkie
LSxJunkie's Avatar
Drives: Car
VSC OFF will allow more slip. It will allow all the slip you could possibly want. Including spinning into the weeds. VSC Sport raises the threshold and severity of intervention. I'm not sure how it will do it on this specific system, but the result will be later intervention when you have the car sideways.
Old 12-04-2011, 02:19 PM   #33
madfast
yeah but there is VSC OFF and VSC OFF OFF (hold button down 3 sec). so im guessing it goes Normal > VSC SPORT > VSC OFF > VSC OFF OFF
Old 12-04-2011, 04:33 PM   #34
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Left button for Traction Control. Press it once and it'll let you spin the tires a bit but still try to keep you in a straight line. Hold it down and it'll step aside and let you try to kill yourself. Right button is for VSC Sport, which is, if I'm not mistaken, supposed to make you faster than your talent by letting you get the back of the car out more than normal.
See this part of the MT review:
Originally Posted by Motor Trend
Traction and stability control algorithms are governed by three buttons mounted just behind the shifter in 6AT-equipped BRZs. (Manuals lose the center Sport/Snow button.) With one touch, the left button partial turns off stability control; when held down for 3 seconds, it turns off completely. As you'd expect, the latter is a must for wannabe drifters.
Punching the rightmost button engages Sport VSC mode. This activates a combination of stability/sport indicator lights on the gauge cluster and lets you hang the car's tail out a touch, via steering angle, yaw rate, and lateral G sensors that forecast the vehicle's position. If that future looks too sideways, brake and throttle cut precautions engage. In practice, it's the best mode for spirited road courses like the SKC handling track. This twisty second/third-gear course had several tight low-speed turns and a couple of nasty mid-corner bumps that conspired to unsettle the BRZ. Sport VSC caught it every time, with a more progressive engagement of stability control over the normal mode.
Problem is it doesn't specify exactly what "partially turns off stability control" means... either way I'll have it off completely for track and autocross use, and on for the street as I don't drive agressively enough to engage it anyways and I really don't mind the nanny if something unexpectedly bad happens on the street.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-04-2011, 05:30 PM   #35
madfast
this is what i mean. its not clear. is there a practical difference between "partially" turning it off and raising the limit?
my assumption is that VSC SPORT is less aggressive than VSC OFF but no review has mentioned much of what the difference is. they all say they "turn off" the VSC, but is that VSC OFF or press and hold 3 sec VSC OFF. they make no distinction...
Old 12-04-2011, 05:41 PM   #36
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It may just allow burnouts or something, who knows. The VSC Sport uses all the sensors and changes the point at which it engages. I'm guessing the partial just removes one sensor from the mix.. but no idea.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-04-2011, 05:43 PM   #37
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
dont know why i havent seen pics of these wheels but they were shown in the parade run
[U2b]UBdcBnn9YM8[/U2b]
they appear to be 16s. if they are, i think they look better than the 17s. strictly in design though.
DuMa is offline   Reply With Quote
Old 12-04-2011, 05:48 PM   #38
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
The low spec was supposed to have 16" alloys, only the customize grade got the 16" steel wheels so I wouldn't be surprised by 16s in that video.
Scion said their car will get the 17" alloys though so I really can't see the more expensive Subaru not getting the 17" alloys, even at the most base version of the car.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-04-2011, 09:04 PM   #39
Zaku
-Proud of Brzerhood-
Zaku's Avatar
Drives: '17 BRZ CWP LMT.
If you look carefully those 86 are pretty much FRS, they don't have the GT86 lights and they have the smaller wheels, only diff is that they are RHD. Basically this is there base and that's the FRS we're getting with our own ... Unique interior XD
Old 12-05-2011, 03:58 AM   #40
nrclptcnsmniak
Professional Athlete
Drives: Marty's Hover Board
The fronts will NOT be solid. As for brake differences this is the first time we have heard of front brake differences (and IMO it's incorrect) so most likely both versions will have the same. Fr-s will also be the same. You'd care about the vents when your brakes overheat though
wait so im going to assume now that vented is not the same as slotted and or drilled? whats vented exactly then?
I'm the type of guy who loves his girlfriend.
nrclptcnsmniak is offline   Reply With Quote
Old 12-05-2011, 05:46 AM   #41
Quantum
Drives: Infiniti G35
You guys are getting worked up over a typo. Obviously it doesn't come with 15/16" brake rotors. That's why I posted the LINK and said I corrected Motor Trend's typo.
Not sure who added to my original post, but they quoted the older/incorrect version of the article.
Cheers,
Hong
Quantum is offline   Reply With Quote
Old 12-05-2011, 10:08 AM   #42
nrclptcnsmniak
haha yeah got it thanks ^_^ I misunderstood. :P
brz review, brz reviews, brz test drive review, brz test drive reviews, subaru brz review, subaru brz reviews, subaru test drive review
Subaru BRZ First Drive Review by Automobile Magazine - "A Great Drive" Sport-Tech BRZ First-Gen (2012+) — General Topics 36 12-07-2011 04:13 PM
Road & Track Test Drive Review of 2013 Subaru BRZ Hachiroku BRZ First-Gen (2012+) — General Topics 39 12-05-2011 10:45 AM
2012 Subaru BRZ Test Drive Review by Autoweek Sport-Tech BRZ First-Gen (2012+) — General Topics 1 12-02-2011 07:34 PM
Subaru BRZ Prototype First Drive Review: "Off the Chart" (Motor Trend) Hachiroku BRZ First-Gen (2012+) — General Topics 67 11-09-2011 06:58 PM
Subaru FT-86/216a news: Subaru Confirms Rear-Drive Coupe Debut for Geneva Motor Show C-Bone BRZ First-Gen (2012+) — General Topics 39 03-24-2011 10:22 AM
