#29 | |
Drives: BRZ and NA
Also, do you live in the city? It could just be rail dust/pollution that got on your car after it was Opti-Coated. |
#30 | |
I do live in the city and drive under a railway over pass everyday. I also think the rail dust/pollution/iron deposits could be from driving around country roads in Quebec on the way to the ski hills. Thanks for the suggestions everyone. |
#31 |
Drives: MY00 Impreza 2.5RS
If it was rusting I honestly wouldn't be surprised. When the 08 WRX remodel came out there was a recall for rust on the front of the rear quarters from the front tires flinging sand/rocks at it. They ended up putting thick clear bra like film on that location from the factory.
#32 |
Drives: 2015 Mustang GT (on order)
yeah, either your detail guy didn't prep well enough or you are getting iron fallout on your paint from another source now. Either way, it has nothing to do with the car you bought. I'm fairly certain your car will need to be properly stripped down, removing any opti-coat you have, for this problem to go away.
#33 | |
Grip>Drift
Drives: FRS
#34 |
Drives: GT86
All white cars look like that. It's not rust. If you have studded winter tires it usually gets even worse.
It's what someone stated it's just crap that's on the roads (from railways and such). All cars get's this but on white it's ALOT more visibile. It will be better or worse depending on where you live and how much you drive You can remove it with cleaner clay and at my workplace we have a special liquid that you can apply to the "rust spots" and it will erase them with just water flushed over. |
#35 |
What is this rust that you speak of?
#36 |
i'm sorry, what?
Drives: Canada
so much misinformation in this thread!
these are IRON deposits that eat themselves into the clearcoat, also known as rail rust and it's present on all cars that were train-sported and left untreated by their original buyers. that's why when i bought my car i had it cleaned by a professional (In my case, Hamza) by using a combination of claying and special compound that helps to remove these iron deposits. here is my car, see that purple stuff, that's iron deposits, my entire car turned purple after the application of IRON-X ![]() so after a wash, iron-x, claying, and polishing, my paint was sealed using opti-coat i have no rust spots on the car. the dealership will most likely deny coverage but good luck anyway. i suggest you contact a local detailer to see if they can iron-x/claybar/polish because the last thing you want is to actually re-paint a brand new car. and if you live in an area of high air pollution/rail sediment then invest into a high protection wax/coating/sealant and re-apply/clean regularly to avoid the contaminates from getting to the base layer
#37 |
Also do a search in the forums for spots or brown spots. I've seen a thread where someone else has had this type problem.
#38 |
Pull my finger...
Drives: Silver Scion Slushbox
This isn't always just from shipping and transport. If you live/work/drive in an area where there's a lot of industry you'll see this too. There are a lot more things that contribute to iron or metals in the air, it's not just trainspotting! LOL
Yes, there is a lot of misinformation here... |
#39 | |
Drives: 2005 S2000
| The Following User Says Thank You to MattZ28 For This Useful Post: | CircuitJerk (01-09-2013) |
#40 |
Drives: 2010 Gen Coupe, 2013 BRZ 6MT S.Tech
I have a white BRZ and I have A LOT of those rail dust near my trunk area only. My car has been opticoated since August.
My question is: If I put iron x on the area do I have to reapply opticoat? |
#41 | |
Drives: Strawberry Pie
So as long as the opti coat was put on the car in good clean condition (which most detailers who do opti coat know prepwork is a must) then you wont have to take it off and re apply. IronX isn't designed to deterior things like wax, sealant, opti coat or clearcoat. It's simply targeting the rust and iron deposits that are most likely sitting on top of the opti coat. Hope that helps a bit. |
| The Following User Says Thank You to Jared0934 For This Useful Post: | ArKiTeCkT (01-17-2013) |
#42 |
I believe its ON TOP of the opticoat. I've been driving through railroads, considering I live beside one.
| Rust on tow hook | ayau | BRZ First-Gen (2012+) — General Topics | 30 | 04-08-2014 03:54 PM |
| Good Rust Proof, Clear Bra places in GTA | Eclipse218 | CANADA | 64 | 02-05-2014 10:48 AM |
| Underbody rust prevention/Tectyl etc | Thobjo | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 01-10-2013 01:10 AM |
| Rust Speck | Jehuty77 | CANADA | 16 | 11-15-2012 10:30 PM |
| Rust already? | Fugazi | BRZ First-Gen (2012+) — General Topics | 9 | 08-26-2012 03:36 PM |
