Old 06-24-2014, 02:21 PM   #29
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
A couple newbie questions since I have never done this before:
1) This is more just to confirm what I am already thinking, but if I am just inspecting my brake pads to see how worn they are, I won't have to worry about the pistons needing to be compressed assuming I am putting the old pads back on?
2) When installing new pads and if I have to drain some brake fluid like mentioned in the OP, is it ok to put that fluid back into the reservoir or do I need to replace it with new fluid?
Thanks in advance.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 06-24-2014, 03:33 PM   #30
PMok
Codename: Stitch
PMok's Avatar
Thanks in advance.
1) yes correct no need to compress.
2) I would not reuse the fluid that comes out. It may be contaminated by the container or tubing you used so better safe than sorry. Refill with new fluid only.
Old 06-24-2014, 03:35 PM   #31
Turkish
Serial Cone Killer
Turkish's Avatar
Thanks,
I kinda thought so, I just wanted to make sure before I put myself in a sticky situation.
... his name is...
C'THULHU
Old 07-15-2014, 08:43 AM   #32
Dangerboyjohn
Drives: White out 2014 FR-S
In a perfect world
Originally Posted by becauseracecar1 View Post
Would there be any issues if I changed the pads one wheel at a time with the jack that came with the car? Thanks!!
I'd like to offer an alternative to buying or having to store extra equipment. You can use the factory jack to raise the car and remove the wheel. Don't put any part of your body where it can get crushed if the car falls. Once you have the wheel off, slide it under the car as an emergency "jack stand". That way, if the jack fails, the car will fall on the wheel and not on you. Even if you have all the proper equipment, you should remember this trick for emergency track- or roadside repairs.
Personally, I wouldn't climb under my car supported like this because my head is wider than my tires, but I have no problem working in my wheel wells like this. Obviously this method falls somewhere on the safety scale between real jack stands and nothing at all.
Dangerboyjohn is offline   Reply With Quote
Old 08-21-2014, 02:54 PM   #33
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
is it absolutely necessary to bleed to brakes if just changing the pads? what is the reason behind this and if i need to bleed them what do i need to replace the fluid with if at all?
Thank You For Your Future Response
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 08-28-2014, 12:06 AM   #34
PMok
Codename: Stitch
PMok's Avatar
the answer depends on whether you track the car or not.
bleeding them is optional if you're just using the car on the street and upgrading your pads to something else. if you're replacing the pads because the old ones are totally worn, then it's recommended to bleed. Replace any lost fluid with the regular DOT4 fluid.
If you are doing track/HPDE then you will probably want to bleed before each track day. And switch to high temperature racing brake fluid like Motul RBF600 or Torque 600 or Project Mu (I forget what the exact name is).
Old 03-26-2015, 06:22 AM   #35
funwheeldrive
@PMok can you upload the pictures again?
Old 06-05-2015, 11:05 AM   #36
LostSalad
Drives: Toyota 86 - Charcoal Grey
@PMok thanks for the great writeup! A question:
When compressing the pistons using a C-Clamp and an old brake pad - will this damage the pad? I'm not sure about the forces involved... Mine should be hardly worn and I'd like to keep them for future re-use.
LostSalad is offline   Reply With Quote
Old 06-17-2015, 11:14 AM   #37
PMok
Codename: Stitch
PMok's Avatar
No, it should be fine if you are careful. Or you could use something else similarly flat and solid instead.
Old 09-27-2015, 08:17 PM   #38
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Awesome Write-UP!!!!
Old 01-27-2016, 02:55 AM   #39
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
@PMok if you just take some fluid out of the resavoir, and then refill it again with fresh fluid, you don't need to bleed your brakes... Right? Just want to be 1000% sure before I change all four pads over to XP8's.
Keenercarguy is offline   Reply With Quote
Old 01-27-2016, 09:20 AM   #40
jvincent
jvincent's Avatar
Bleeding the brakes gets the old fluid out of the brake lines, which is quite some distance from the reservoir so just changing the fluid in the reservoir won't get fresh fluid into the brake lines.
You'll still need to bleed them to do that.
Old 01-27-2016, 10:19 AM   #41
PMok
Codename: Stitch
PMok's Avatar
@jvincent is exactly right, you'll want to bleed to completely flush out the old fluid from the lines. Keep in mind it's the fluid in the lines and the brake calipers that is doing the work when you brake, and that will be closest to the source of intense heat (the pads and rotors). You don't want to just top off the reservoir with better fluid but leave the older/inferior fluid in the lines.
Old 01-27-2016, 01:32 PM   #42
Keenercarguy
Mountain Runner
Right! I was intending to have them bled by a shop after doing everything else myself, just wanted to make sure that it'd be 100% safe to drive on them to the shop. Sorry not used to working with brakes much, still learning.
brake pads, pad change
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
which brake pads? NESW20 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 165 02-25-2018 02:07 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
brake pads Dpark27 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 09-07-2012 07:58 PM
