Old 12-13-2012, 03:21 PM   #29
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
Is it possible to get 2 piece? I already have a lightweight pulley
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline
Old 12-13-2012, 05:03 PM   #30
gmookher
nice kit
gmookher is offline
Old 12-13-2012, 05:26 PM   #31
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Interested but I wanna see how it performs for others. Won't be putting any parts on the FR-S till May anyways.
Darryljr11 is offline
Old 12-13-2012, 07:21 PM   #32
OrbitalEllipses
Drives: Attitude
Originally Posted by Captain Insano View Post
Awesome writeup!!
For those asking if this benefits AT - of course it does. Anything that drops rotational weight is beneficial for quicker revs and acceleration the more weight you drop... and less driveline weight the engine needs to directly move/spin. You wont notice from a shift "feel" perspective like a MT though since that is all "automated" on the AT cars.
The problem with the AT will be the torque converter. You can drop all the rotational mass you want, but that torque converter will always have the most drag (fluid).
OrbitalEllipses is offline
Old 12-13-2012, 07:25 PM   #33
Captain Insano
Ummm... Even if you think the torque converter is a huge loss in power (in reality it's not) dropping rotational mass is still only going to help. If you have to fight the fluid in torque converter and 100 lbs of mass to spin, and you change the equation so you have to fight the fluid in the torque converter and only have to fight say 90 or 80 or 70 lbs of mass... Does it help to have dropped that mass? Rhetorical question.
Captain Insano is offline
Old 12-13-2012, 07:28 PM   #34
OrbitalEllipses
Drives: Attitude
The point was that incremental drops in rotating mass won't help as much as you're making it seem like they do. You can't defeat physics at the end of the day.
And I never said power.
Old 12-13-2012, 07:39 PM   #35
Captain Insano
The same could be said on an MT or AT.
And the tiny fraction of a difference the torque converter makes compared to the MT, you could again say the same thing you said...
I guess my opinion is - if you are contending these pulleys make no difference or minimal difference on an AT or MT, maybe that is true, I haven't run them. But I would say I'm a very firm believer in dropping weight, especially rotational weight. If you are trying to say these pulleys make a bigger difference on an MT versus an AT, maybe, but I woudl think it would be so imperceptible that the diff would not be noticeable.
I'm done, I'm not going to fight about AT versus MT. It has been beaten to death.
The pulleys look great.
Old 12-13-2012, 07:43 PM   #36
OrbitalEllipses
Drives: Attitude
Heavy fluid filled torque converter vs. flywheel that you can replace for a lightweight piece; that's where the most difference in feel will be had from dropping rotating mass.
Enjoy your delusions. /out
Old 12-13-2012, 07:47 PM   #37
Captain Insano
OK, I will enjoy my delusional state that a torque converter somehow renders dropping rotation weight as a pointless exercise. I guess lightweight wheels, lighter drive shafts, lighter pulleys are all pointless modifications on a car with a torque converter. Thanks for all your wisdom on this topic I do appreciate it. /out
Old 12-14-2012, 10:36 AM   #38
soros151
SorosMotorsports
soros151's Avatar
Drives: Whiteout Pearl
Originally Posted by Touge Factory View Post
Here is what Go Fast Bits wrote:
A better name for a harmonic balancer would be "torsional dampener" since its main task is to absorb the rotational pulses inflicted on the crankshaft by the pistons. Most often it is incorporated into the crank pulley by attaching the outer belt drive ring to the inner by means of vulcanized rubber. At the right RPM, it is possible for a resonant frequency to be set up torsionally on the crankshaft. Resonant frequency occurs when the pulses of the engine correspond with the natural frequency of the crankshaft and it ancillary components. However, since factory pulleys are often comparatively heavy (reasons for this are described later) it is actually the large mass (and therefore inertia) of the factory harmonic balancer and flywheel that will help to excite this natural frequency. So by dramatically reducing the weight and inertia of the crank pulley, the natural frequency of the crankshaft is shifted and its ability to self-excite is greatly reduced. So in fact it is the harmonic balancer's own weight that necessitates the dampening, and since the weight of a GFB crank pulley is typically about 20% of the factory component it cannot supply an exciting force significant enough to damage the crankshaft.
An opinion often expressed is "if the manufacturer put it there, it must be there for a reason". However, if you look at it from the car manufacturer's point of view, casting pulleys from steel is very cheap and easy, because they can be produced in large numbers and there is no waste (as opposed to machining them from billet). But because the resulting pulley weighs significantly more than one made from aluminium alloy, it requires dampening.
Manufacturers will always build cars (even high performance cars) to suit the widest possible selection of driving scenarios and drivers, which means there are always compromises. The weight of the flywheel and pulley also affect how fast the revs drop between gear shifts, and a production car is designed to only allow the revs to drop fast enough for average shifts. If you hurry the shift the revs will be too high for the next gear, resulting in a sharp jerk as the momentum of the engine transmits through the drivetrain. Reducing the engines' inertia with a lightweight pulley kit allows faster and smoother shifting.
When looking at high performance engines such as those found in Honda VTEC equipped cars and the S2000, it is obvious that manufacturers do understand the benefits of reducing engine inertia, and have utilized lightweight pulleys to help the power output and responsiveness without the use of a harmonic balancer.
However, this is not the case for all engines, many of them do require the use of the harmonic balancer to prevent failure. Skylines with the RB20, 25 and 26 are a good example of this, which is why we don't make a pulley kit for them. The pulley kits we do make are for engines that do not rely on the balancer to any significant degree.
That's a good theory. Nice. The CEL engine everyone is talking about is about the pulley being so light that the crank sensor would read twice and thus throw a check engine light.
soros151 is offline
Old 12-17-2012, 04:16 PM   #39
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Good news guys,
GFB will allow customers to purchase the two accessory pulleys for anyone that already has the crank pulley.
MSRP: $190.00 for the two pulleys.
Touge Factory is offline
Old 01-11-2013, 08:13 PM   #40
Touge Factory
Drives: ZN6
The 3 piece pulley sets are BACK IN STOCK!
Old 01-11-2013, 08:29 PM   #41
Celica00
Celica00's Avatar
Drives: 86
Originally Posted by number1Tango View Post
this won't throw CELs for being so light? don't quote me on this but, I remember reading on here someone talking about the wrx's and what not having CELs because the system was so light the car thought it was misfiring.. anyone have any incite? Perrin said something that that's why they kept theirs at a moderate weight and they HAD the option of going lower in weight but didn't. maybe that's just a thing of the past..
no it wont. its just like getting a lighter flywheel. just makes engines more responsive during acceleration
Celica00 is offline
Old 01-12-2013, 03:56 PM   #42
bpracer
Drives: Asphalt FR-S
It was a fine explanation until that point, but the last part is utter crap.
It is the outer mass that does the damping, it is that mass that is tuned.
I'm not saying there is anything wrong with the product, but that explanation is just wrong.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline
TODA lightweight pulley kit Hanakuso Engine, Exhaust, Transmission 62 04-25-2019 01:04 PM
Effectiveness of a Lightweight pulley DrifterX Engine, Exhaust, Transmission 94 12-11-2016 01:10 AM
Lightweight pulley wow Silverdub Engine, Exhaust, Transmission 240 01-23-2013 01:00 PM
KARTBOY Lightweight Aluminum Crankshaft Pulley! RallySport Direct Engine, Exhaust, Bolt-Ons 0 10-29-2012 02:55 PM
Aluminum pulley not a damper, thats ok with alotta folk? gmookher BRZ First-Gen (2012+) — General Topics 28 09-13-2012 05:26 PM
