Old 12-09-2012, 04:17 PM   #29
Shit Luck
Drives: red frs
Originally Posted by cnk View Post
So let me understand you correctly. Ecutek has modified a cable so that it is the only cable that will work with their software so that they can make it more difficult for competitors to reverse engineer their R&D efforts in cracking the ecu. You want someone to tell you how that cable is different. Good luck with that.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 2
have they?
thats what the hell i am trying to figure out. a specific reason, if visconti or someone who acutally knows something can specifically tell me that there is some kind of proprietary tech in there so be it.
none of you know that for sure, basically none of you know anything about it or the software other than you can buy it on the net.
Shit Luck is offline   Reply With Quote
Old 12-09-2012, 04:18 PM   #30
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Shit Luck View Post
damn... i guess the original post must be in code?
News flash man, unless you notify them (for example with a mention), no tuner will come in and see it. They are busy enough with their business to be roaming random threads. Just trying to help you get your answer here. don't understand why you need to be all defensive and worked up about it. Send them a PM and you will get your answer directly from them.
Old 12-09-2012, 04:18 PM   #31
ducks
Drives: car
have they?
so why are you asking here?
http://www.ecutek.com/Contact-Us.aspx
ducks is offline   Reply With Quote
Old 12-09-2012, 04:19 PM   #32
Shit Luck
Drives: red frs
silly me... thinking a company out to make a killing on a product might not want to answer my question that would cause them to not make a profit....
Old 12-09-2012, 04:23 PM   #33
cnk
Drives: '13 DGM BRZ Limited
No. Not in code. Just your ability to comprehend the answers that have been given to you because they are not the answers you want to see.
Let me make it simple for you.
Ecutek pro cable needed to work with Ecutek software. Software checks to determine if the connected cable was provided by Ecutek or not. No one short of Ecutek is going to be able to tell you exactly what is different. If someone knew then there would be no reason to buy the cable from Ecutek. If you don't like this business practice then don't buy from Ecutek, go standalone as you mentioned above, and stand by your word as a man and be done with this thread.
cnk is offline   Reply With Quote
Old 12-09-2012, 04:47 PM   #34
cruzinbill
Drives: Argento 6spd FR-S
actually you have not stated at reason that it wont work other than... "its not the same cable".
i am looking for an actual reason from someone who can explain the difference between the two peices of hardware.
No one who has posted here is an actual tuner, just a bunch of forum jockeys that bought it from someone else with no actual knowledge of the products internal workings.
there are many different cables out there, i agree. however if i have a can bus cable, or a hex cable or whatever other forms of cables are out there i would love to know the actual difference between them.
you guys are like the clowns at autozone that tell people a gm ignition module wont work on a toyota truck just because your computer says so. (it does work by the way and is a much cheaper option than the toyota)
It has been stated and its really simple, the electronics in it are different, that way people(like you) arent using some other cable with their software they spent time to develop.
It covers their money and ass if someone decides they wanna use some piece of shit cable from ebay and it messes up their ecu.
It also stops other companies from reverse engineering their software/hardware.
People shouldnt have to spoon feed you that it doesnt work and justify to you why. Only their cable works with it and thats all there is to it. Either pay the money for it or not. You may as well ask why you can plug your VW ecu into the FR-S and have it work properly.
cruzinbill is offline   Reply With Quote
Old 12-09-2012, 05:30 PM   #35
Craig
Craig's Avatar
Drives: Asphalt FRS
Thought he was going back to the VW forums...
You don't like the advice from us 'forum monkeys,' don't come askin us! The cable wont work for the aforementioned reasons, take it or leave it.
Craig is offline   Reply With Quote
Old 12-09-2012, 05:45 PM   #36
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
All i see here is a guy looking for a fight on the internet, with a lot of posts after claiming to be done.
Ask samsung why they dont let iphone cables work on their phones, or better yet- why apple doesn't make iphone3+4/5 cables backwards compatible. Its all about money, and that's why the companies are still in business. It would be nice if everything were free or dirt cheap- but it aint like that in real life. We live in a capitalist society, and don't count on that changing any time soon.
Ravenlokk is offline   Reply With Quote
Old 12-09-2012, 05:49 PM   #37
Shit Luck
Drives: red frs
Thanks again for not actually answering the question.
Old 12-09-2012, 05:50 PM   #38
wbradley
Sarcastic SOB
wbradley's Avatar
And further, if someone here does know how the software detects the cable type, why would they tell anyone on an open forum? Looking to be charged with piracy?
Here's my suggestion; buy a cable and dissect it. maybe something to do with pinouts, or an embedded Pal chip or something. Could be simple to, like a resistor or something though I highly doubt it. Sometimes a cable looks the same but isn't. I have dealt with fixing an unusual Pinball 2000 pinball machine with late 90's Cyrix type CPU inside. Only cable that sincs with a laptop to reflash was a null modem cable, no longer sold as its old tech. Turns out its a pinout thing and moving a ground pin allow a regular serial cable to work.
Personally I'll do things legally. However depending on how things are engineered, they can usually be reverse engineered at a cost.
Old 12-09-2012, 05:54 PM   #39
xjohnx
Grip>Slip
xjohnx's Avatar
*insert passive aggressive response here*
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
Freeman (12-10-2012), Sportsguy83 (12-09-2012)
Old 12-09-2012, 05:57 PM   #40
Dimman
Kuruma Otaku
Dimman's Avatar
You just change chkcbl=1 to chkcbl=0.
Because titanium.
The Following User Says Thank You to Dimman For This Useful Post:
Sportsguy83 (12-11-2012)
Old 12-09-2012, 06:06 PM   #41
Shit Luck
Drives: red frs
Honestly I have given up on getting a real answer....
It was more of a curiosity question, just so I understood the technologies a little more.
oh well I guess ignorance is bliss.
Old 12-09-2012, 06:13 PM   #42
wbradley
Sarcastic SOB
wbradley's Avatar
Obviously nobody knows and since the vendors for the product are on the forum daily, even if we did know why blab it out?
You genuinely are ungrateful for people *trying* to explain.
Go on an online bank site and start a thread on how to hack their ATMs.
Ecutek cable markmatley Hawaii 11 07-22-2013 06:36 PM
Anyone have an EcuTek cable? ProTekk NY / NJ / CT / PA 9 12-05-2012 09:28 PM
Ecutek Cable jpit Northwest 0 09-04-2012 01:14 AM
Ecutek Cable brz007 Northwest 0 08-25-2012 06:11 PM
Cable in glovebox KamalT AUSTRALIA 8 08-23-2012 07:52 AM
