Old 06-20-2013, 05:04 PM   #29
RurumariGhost
Drives: Dark Grey Metallic 2013 BRZ
My parts department threw in a free crush washer when i went to buy an OEM oil filter...winning
RurumariGhost is offline   Reply With Quote
Old 06-21-2013, 03:34 PM   #30
qoncept
qoncept's Avatar
I got a handful of them one day when I was buying something else. Ask about the washers after you've paid for the filter.
qoncept is offline   Reply With Quote
Old 06-21-2013, 09:24 PM   #31
superpilun
Drives: 1986 MR2
https://www.belmetric.com/ga18x24t-a...ml?cPath=11_92
It's too bad they don't have the crush washer in M18 but I'd imagine a non-crush would work just as well.
superpilun is offline   Reply With Quote
Old 01-04-2014, 04:18 AM   #32
Terrapin77
Terrapin77's Avatar
Drives: 2013 Argento FR-S
Originally Posted by developer View Post
So I just received my overpriced gaskets/washer for the transmission and the differential:
Differential fill plug gasket: SU00300122 - 24mm OD x 18mm ID x 2mm Crush
Differential drain plug gasket: TOY1215710010 - 24mm OD x 18mm IDx 2mm Crush
Transmission fill/drain plug gasket: SU00303626 - 24mm OD x 18mm ID x 2mm Flat
They all look to be aluminum but that is just a guess. All measurements were made with calipers.
Edit: The crush washers stuck to the magnet on the drain plug so I guess they are not aluminum
Left Image is the diff drain/fill gaskets and they look identical. They are the exact same outer/inner diameter and thickness. They are both crush type washer.
The right image is the transmission fill/drain plug gasket is the same size as the differential gasket but is a flat washer.
After I pull the transmission gasket I will compare the thickness of the used and the new gasket to see if the transmission flat washer did actually "crush".
Edit: The original flat washer was within a 1000th of an inch of the new flat washer so I would guess they are not meant to crush.
When I order the differential crush washers again I will just order two of the same part number instead of two different parts.
Sorry to bump an old thread, but if anyone is interested in the washers for a FR-S auto tranny, the part # is SU00303621.
Terrapin77 is offline   Reply With Quote
The Following User Says Thank You to Terrapin77 For This Useful Post:
Magoo (03-12-2016)
Old 02-16-2015, 12:06 PM   #33
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Just ordered some generic washers from belmetric.. 4 crush for diff and 4 flat for tranny based on the measurements provided. Total of 11 bucks and thats including the shipping which was $8 lol so the washers turned out to be around $1 a piece. Ill report back on fitment and results after fluid replacement.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 02-16-2015, 12:20 PM   #34
Koa
Take this with a grain of salt, but the tranny washers seem to be reuseable if the mileage is low and you flip them.
These types of washers typically are good for one torque down per side. If your car is pretty new, many on here have reported reusing the washers with no ill results. I reused and checked at 1k mile increments for the past 5k miles after fluid swap (was 5k miles when swapped on diff and tranny.. now at 10k solid as a rock, no weeping fluids).
If you do reuse, don't forget to flip them
Old 02-16-2015, 01:24 PM   #35
yomny
yomny's Avatar
Yeah i normally do that, lol but i flushed the fluids at 1k lol so i can't flip anymore. Thanks though. Just ordered these for kicks, want to see as the dealer ones are a bit expensive for what they are.
The Following User Says Thank You to yomny For This Useful Post:
Koa (02-16-2015)
Old 02-16-2015, 02:16 PM   #36
Koa
they're sooo expensive. Seriously how they get away with calling them a "gasket" and at that $40 pricepoint... get real guys. Post a pic of them when you get 'em?
Old 02-16-2015, 02:20 PM   #37
yomny
yomny's Avatar
Will do, most things OEM are a joke.. some are worth their price but man some others really make you wonder lol.
Koa (02-16-2015)
Old 03-16-2015, 11:45 AM   #38
yomny
yomny's Avatar
Quoting myself here to give an update the washers and crush washers i had ordered. Installed these and worked like a charm, just as the expensive oem one. Great fitment and seal on both crush and flat.
Koa (03-16-2015)
Old 04-15-2015, 02:41 AM   #39
YouShallKnow
Drives: Man
Send a message via ICQ to YouShallKnow Send a message via AIM to YouShallKnow Send a message via Yahoo to YouShallKnow
What sizes? I'm going to need some new ones next fluid change.
You don't have a link do you?
YouShallKnow is offline   Reply With Quote
Old 04-15-2015, 10:39 AM   #40
yomny
yomny's Avatar
The sizes are posted in the first couple of posts in this thread, some guy was cool enough to enlightened us..
Differential fill plug gasket: 24mm OD x 18mm ID x 2mm Crush
Differential drain plug gasket: - 24mm OD x 18mm IDx 2mm Crush
Transmission fill/drain plug gasket: - 24mm OD x 18mm ID x 2mm Flat
This is my order from belmtric.com which are the same dimensions and fit perfectly. I ordered extras. LEt me know if you need more help.
Here's the page
4 ea. GCA18X24 - Copper hollow crush gasket $2.88
4 ea. GA18X24T - Aluminum Gasket THICK $1.52
The Following 8 Users Say Thank You to yomny For This Useful Post:
aegisdrgn (10-01-2015), dkstylezz (05-06-2015), PWBRZ (07-08-2015), Rybot (02-11-2016), slizoth (08-03-2018), ThisGuyRett (09-24-2016), TMF (06-05-2018), WhiteFRS69 (06-02-2015)
Old 03-07-2016, 03:39 PM   #41
foreverlost1986
Drives: 2017 BRZ yellow series
I will just put this here. the subaru part no#.
1215710010 GASKET DRAIN PLUG
11126JB000 GSKT DRAIN PLUG
17008AA050 TRANSMISSION GASKET
foreverlost1986 is offline   Reply With Quote
The Following 3 Users Say Thank You to foreverlost1986 For This Useful Post:
Bramick (05-22-2016), Magoo (03-12-2016), RL_BRZ (08-08-2018)
Old 03-22-2016, 04:47 PM   #42
unplugged
Master Member
Drives: Subaru BRZ
I always replace the washers after each fluid change. My subaru dealer hands them out for free anyway as long as I buy something from them during that trip.
unplugged is offline   Reply With Quote
Washer Mod? 636 Engine, Exhaust, Transmission 64 02-20-2018 05:08 PM
Pressure Washer $60 at super store Aznek CANADA 6 09-10-2012 12:08 PM
Engine oil drain plug washer BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-28-2012 12:28 PM
front washer? Filipino Royale Cosmetic Modification (Interior/Exterior/Lighting) 0 06-21-2012 03:06 PM
Man Crush A Friend's Car With A 100-ft Axe ichitaka05 Off-Topic Lounge [WARNING: NO POLITICS] 11 01-19-2012 04:31 PM
