Old 11-30-2012, 02:37 AM   #29
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
Originally Posted by Hawaiian View Post
If it's manual, make sure you're not pressing against the gas pedal. The engine floods easily.
Isn't that usually a problem for carbureted engines? The only motor I know of with EFI that flooded regularly is the rotary.
Does this have something to do with the high fuel pump pressure or something?
Not calling you wrong or anything, just sounds strange.
dori. is offline   Reply With Quote
Old 11-30-2012, 02:54 AM   #30
Indestruct
Drives: 2013 SWP Limited BRZ, MT
This happened to me once in 5,000 miles. I have a push button and it just kept clicking on it's own for a few seconds.
Indestruct is offline   Reply With Quote
Old 11-30-2012, 03:15 AM   #31
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Well, I admit I'm far from a car expert, but I learn quickly. When I had first gotten my car I was having an issue with starting my frs. Sometimes it would start fine, but occasionally I would have a problem with it cranking for 10-20 seconds before starting, or starting on the second try.
I took mental note of everything I had done different every time I started the vehicle, and after a few of these starts I pinpointed to when I was parked on an incline, I would push in the brake to the floor before starting. I also noticed my heel was clipping the gas pedal enough to open the throttle.
Flooding might not be the correct term for it, but my car never had the issue again.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 11-30-2012, 09:33 AM   #32
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
I had it once at around 500miles, i now have ~2000 and not again.
microbionic is offline   Reply With Quote
Old 11-30-2012, 01:21 PM   #33
RavenFR-S
I'm not on an incline. I always wait for it to prime. And my foot isn't on the gas, nor the brake for that matter. The clutch is fully engaged as well. And this has been happening to me far too often this week.
RavenFR-S is offline   Reply With Quote
Old 12-06-2012, 03:00 PM   #34
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
I had it today at 5400kms
shu5892001 is offline   Reply With Quote
Old 12-07-2012, 03:21 PM   #35
s2kdrew
Drives: 2013 hot lava FRS
I had the same issue, I personally believe is the fuel one way valve at the fuel pump allowing the fuel to return completely.
2013 FRS
2000 S2000
2004 RSX-S
2002 RSX
s2kdrew is offline   Reply With Quote
Old 12-13-2012, 06:59 AM   #36
slidethis
Drives: Argento
Happent to mine, at 5683 miles. it was cold and raining. It turned over it crank but it didnt start. turn the kick back. then waited, put the key over let the gauges go up, then started the car took about 4 seconds. I think its when is cold..
slidethis is offline   Reply With Quote
Old 12-17-2012, 03:28 AM   #37
root
Drives: Raven FR-S
Had my second hard start today, this time at Auto-X. First time was accompanied by some pretty bad smell, second time I didn't notice, but it was very windy.
root is offline   Reply With Quote
Old 12-17-2012, 06:16 PM   #38
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Happened to me twice so far. First time it was chilly and raining, second time it was down right cold out.
Probably about 1000 miles apart. Once at about 7k and the second around 8k.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 12-17-2012, 06:31 PM   #39
pjb86
pjb86's Avatar
Drives: 2013 Scion FRS Raven
I had it on my first one the first time I started it after the dealer handed me my keys!
My replacement, after the first one got wrecked, didn't do it until 8000km.
pjb86 is offline   Reply With Quote
Old 12-17-2012, 07:45 PM   #40
_hollywood
Drives: 97 itr sold
I start all of my cars like it is a diesel, hard habit to break but i dont have any problems, also lets your car run for 10 seconds before heading out to drift, lol i see so many people start their car and within .5 seconds they are flying down the road, lol
FR-S #56 of 86 Raven MT ***FOR SALE***
_hollywood is offline   Reply With Quote
Old 12-21-2012, 07:56 PM   #41
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
my guess?
the key, (which has an engine immobilizer) somehow lost communication with the body ecu for a short period. ive seen this happen on a few toyotas before, it may even have a code stored if thats the case.
but i cant remember if it would crank over or not in that situation, but, just a wild guess
Jesse is offline   Reply With Quote
Old 12-22-2012, 09:00 PM   #42
BRZnut
Drives: BRZ DGM Limited
Are these hard starts happening in only the manuels, or the auto too? also, always when below freezing out?
After Market Problem Signals Fuse Popped- Car Wont Go into Gear ScionFR-S Issues | Warranty | Recalls / TSB 14 11-20-2012 03:34 PM
Car Won't Start schtebie Issues | Warranty | Recalls / TSB 25 10-15-2012 05:06 PM
trunk wont unlatch bakerr6 Issues | Warranty | Recalls / TSB 9 09-24-2012 02:32 AM
GTS come with push start? adam AUSTRALIA 13 06-04-2012 04:28 AM
Car won't start, no spark? #87 Other Vehicles & General Automotive Discussions 5 12-19-2011 01:29 PM
