Old 03-14-2013, 12:37 AM   #29
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Ninjaneer View Post
Another thought/comment on proper oil operating temp. Someone correct me if I'm wrong, because I don't yet have a FR-S; but the recommend oil is a 0w-20 synthetic, correct? That is a lower viscosity oil than most cars run. With it running thinner oil, I wouldn't be as concerned with oil warm up as I would with high oil temps under heavy load.
That is correct but IMO (and based on my oil pressure gauge) it doesn't maintain high enough pressure in the upper RPM when warm/hot, so I run 5W30 which does.. that does increase heat a bit though.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-24-2013, 12:39 PM   #30
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
Have you found that the Higher oil viscosity increased the heat?
I'm running 10/30 right now
Torco SR1
jdzumwalt is offline   Reply With Quote
Old 03-24-2013, 12:43 PM   #31
jdzumwalt
Motor Sports slut
Are you running -8 or -10 line for your oil cooler?
Old 03-25-2013, 06:06 PM   #32
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Torco SR1
I didn't have the temp gauge installed when I was using the 0W-20, so I can't answer that with data. Thicker oil *should* result in higher temps though as it prevents some heat transfer which adds heat overall.
For your other question, -10.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-25-2013, 10:06 PM   #33
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Trying this, with a 12v fan, criticism and feedback welcome(seriously)
Huehuecoyotl is offline   Reply With Quote
Old 03-25-2013, 11:44 PM   #34
jdzumwalt
Motor Sports slut
Those tabs look a little concerning. should be supported top and bottom if your mounting it like that. I don't like the idea of the cooler being mounted over the engine no way for it to pull cool air. I'm thinking integrated heat exchanger or mounting mine on the hot side of the intercooler since it's way over sized.
I'll post up once I make something happen.
Gregg
Old 03-26-2013, 12:04 AM   #35
bpracer
Drives: Asphalt FR-S
I would rubber mount the cooler, at least something to remove vibrations being directed to the cooler. There are lots of brazed or epoxied joints in a cooler that won't like vibration. A cracked cooler makes a mess. "Well-nuts" or something similar should work.
Asphalt FR-S
1965 Mustang Vintage Road Racer
Ducati Paul Smart 1000LE
Ducati 848
bpracer is offline   Reply With Quote
Old 03-26-2013, 12:09 AM   #36
bpracer
Gregg
I run a water to oil cooler in my racecar (not the FRS) and they also typically reduce the length of the oil lines and reduce the need for an oil thermostat.
The shorter the oil lines, the better...
Asphalt FR-S
Ducati 848
Old 03-26-2013, 12:31 AM   #37
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
I so wanted to do this with a hood scoop, to leave more air flow to the intercooler. Looks like you got to top mount before me.. lol
Two V8s, one turbo, 12 Wheels total.
Batman is offline   Reply With Quote
Old 07-18-2014, 05:42 PM   #38
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
I was just debating this last night! what size cooler and how did it turn out? I want to add a fan as well.
Originally Posted by Jesse@JDLAutodesign View Post
Here's my one off setup...this was before lines were done.
Does one change the oil in an oil cooler? Captain Snooze Engine, Exhaust, Transmission 29 05-09-2016 05:42 PM
HKS Oil Cooler Kit - Keep those oil temps down. - Photos FT-86 SpeedFactory Engine, Exhaust, Transmission 23 08-10-2015 03:08 PM
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 12:55 AM
