Old 06-22-2013, 09:05 PM   #29
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
Very nice! Let us know if there are any clearance issues after lowering. I'm strongly considering the same setup.
Wolfking is offline   Reply With Quote
Old 06-25-2013, 12:50 AM   #30
EL7
EL7's Avatar
Drives: 13 BRZ Limited 6MT SWP
Shouldn't be any issues. I'm pretty flush right now and the drop should tuck it in a bit more. I tried to capture that with the top down shot but I didn't realize my wheel was slightly turned.
EL7 is offline   Reply With Quote
Old 06-25-2013, 11:59 AM   #31
djdnz
1337
Drives: 2013 BRZ WRB S/C
There will be lots of room. You're looking at almost an inch of clearance to the stock strut. Lower/Add some camber and you've still got lots of room.
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
Wolfking (06-26-2013)
Old 06-29-2013, 10:32 PM   #32
EL7
EL7's Avatar
Has anyone found a Subaru center cap or suitable sticker? I really don't like the TSW cap. The caps I got are blanks with TSW stickers in a bag. I opted not to put them on.
Old 03-16-2014, 04:16 AM   #33
RacerX
Drives: Subaru BRZ
Tire Recommendation - Tail Happy Longevity
I plan on getting a set of TSW Nurburgring 18x8 +35mm wheels. Now the question is what tires....
I don't do track days (despite what my username might imply). I don't need anything performance orientated, and I would prefer longevity over grip. This is my daily driver. Price is no object. I live in SoCal, the weather is always sunny. So what make of tire/compound/size should I be considering? I still want to rear end to slide out as easily as it does on the stock set up. I like being able to use the throttle to "steer" the car. Will having the wider 8in footprint inhibit that?
Another sorta related question: I plan on lowering the car with the Eibach Pro Kit. Is there a risk of rubbing issues with the flush +35 offset? Does the Pro kit make the ride significantly harsher? With the tire size, offset, and lowering changes will that throw off my speedo? What adjustment figures will need to be made to compensate?
Any advice is appreciated. Thanks guys.
-Tony
RacerX is offline   Reply With Quote
Old 03-16-2014, 08:55 AM   #34
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
If you are looking for a long lasting (for a performance tire) tire with good grip, quiet and very good ride; go with the Continental Extremecontact DW.
If you are looking for a tire for hooning, go with a hard all-season tire designed for long life. In fact, get another set of Primacy tires.
All thing being equal, a wider tire will be harder to break free for drifting. But things are never equal.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 04-08-2015, 06:44 PM   #35
AreteAuto
Racing Enthusiast
AreteAuto's Avatar
Drives: Bone stock 2019 BRZ manual
I had the DW on a Mini Cooper S for a while. They were decent at first but wore fast and the sidewalls were way too soft for autocross. I actually rolled on the sidewalls through hard corners. I'd personally choose Michelin Pilot Super Sports any day for everything. They're perfect.
The Primacy's are nice for sliding though, they're fun if you don't care about times.
AreteAuto is offline   Reply With Quote
Old 01-06-2016, 06:04 PM   #36
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Here to bump:
Just got some 18" TSW Nurburgrings! I'm not sure which size tire I should get. I'm thinking 225/40s for now, but was also considering 235s. Thoughts?
MS, CSCS, TSAC-F, CPT
Old 01-06-2016, 06:34 PM   #37
Pete156
I like to eat!
Originally Posted by weederr33 View Post
Here to bump:
You may want to tell us how wide they are.
If they are 8" wide, 225 or 235s will work
Pete156 is offline   Reply With Quote
Old 01-06-2016, 07:04 PM   #38
weederr33
weederr33's Avatar
They're the 18x8s
Old 10-21-2016, 09:24 PM   #39
Aluma007
Drives: 2017 Brz
i want to upgrade my wheels pretty bad, but my local dealer was threating to cancel my friends warranty when he got 235's on his forester instead of 225s. Gah. I'm just dreading having to deal with a plus 1 fitment and larger tires. :/ Glad to see so many frs/brz in san antonio. I've only seen a few down here in the valley.
Aluma007 is offline   Reply With Quote
Old 06-27-2017, 06:18 PM   #40
kevinly787
Drives: '17 WRB Subaru BRZ
Originally Posted by mikalem View Post
Just got the same set loaded up on my car as well - I'll share for those that want to see what they look like on a different color: (Edit: Same rims, different tire size: 245/35/18)
Are yours +35 all around? How did you get it so flushed? Are you running an spacers?
kevinly787 is offline   Reply With Quote
nurburgring, tsw wheels
Wheel Directory: XXR 527 18x8.75 +35 Bmore_Raven86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 06-11-2016 03:40 PM
Wheel Directory: XXR 530 18x8.75 +33 white_knight Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 11-04-2015 07:22 PM
Wheel Directory: BBS CH 18x8.5 +30 Spaceywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 03-02-2015 02:05 PM
Wheel Directory: BBS CH-R 18x8.0 +38 Racecomp Engineering Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 81 10-01-2014 03:12 AM
Wheel Directory: XXR 530 18x8.75 +20 Jon@TrueStreetIndustries Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 04-02-2014 07:15 PM
