Old 10-31-2012, 12:40 PM   #29
xcelir8brz
Drives: 2013 BRZ Limited
Yeah! I can finally get my enduro yellow bulbs back in. I am so doing this!
xcelir8brz is offline   Reply With Quote
Old 10-31-2012, 01:13 PM   #30
xcelir8brz
Just did this:
http://www.ebay.com/itm/SUBARU-84501...94d03d&vxp=mtr
[ame="http://www.amazon.com/Pico-5340pt-H11-Bulb-Connector/dp/B001TQYO88/ref=sr_1_4?ie=UTF8&qid=1351688687&sr=8-4&keywords=h11+pigtail"]Pico 5340pt #H8 #H11 Hal Bulb Connector : Amazon.com : Automotive[/ame]
http://www.hoen-usa.com/fog.htm
$188.45 dollars later shipped, all I need to do is swap them out and use a little bit of solder and electrical tape on hand. Definitely not more than an hour project.
I am so pleased with the original post.
I was pissed when I found out I couldn't buy the normal bulbs I use for Fog Lights (Hoen Enduro). I went through three different sets of PSX bulbs just to settle on that the fogs are useless and I have some amber LEDs in there. Albeit it looks nice, I want usability.
Now, I can.
Thank you so very much again for the post. I now realize that these fog lights are shared with various cars just like my heater switches.
Rock on!
Old 10-31-2012, 02:52 PM   #31
White64Goat
Let us know if those are the right connectors for the fogs. They look very similar to what is on the back of the fog light and I wonder if they will slide over. I'm wondering if this is on the other end of what you ordered: [ame="http://www.amazon.com/TEMPERATURE-CERAMIC-Headlight-Connector-moisture/dp/B004IA3YQK/ref=sr_1_1?s=automotive&ie=UTF8&qid=1351709842&sr= 1-1&keywords=H11+connector"][/ame]
Old 10-31-2012, 03:13 PM   #32
JonnyRocket
"New hotness"
JonnyRocket's Avatar
Drives: WRB Limited MT BRZ
And all that requires is splicing a PSX24W (PG20) male pigtail to a H11 (PGJ19-2) female pigtail.
Right?
What do you mean "on the other end of what [he] ordered"? He only ordered the connector, there is no other end. He'll cut off the factory connector, pin in the H11 he listed, and plug that into the new fogs. The plug you linked to is also an H11, but the clips are incorrect and it's overpriced. Not to mention unnecessary.
...SOLD my WRB BRZ...
Replaced with a 2013 Mazdaspeed3!
JonnyRocket is offline   Reply With Quote
Old 10-31-2012, 04:28 PM   #33
White64Goat
J.R., if you had gone to the Amazon site and done a search for H11 connectors, you would see that they sell an H11 connector that has both style ends on it available for purchase. I only used that picture as a reference, not that you should buy that specific end. My question was only that, a question, because it LOOKS like the end ordered might not fit over the factory connector on the fog lamp. If it will, great, then I'll order the same ones when I do mine because they offer more protection to the connector. Was not being critical......if I had been, I'd a said it looks like you ordered the wrong ends.
Old 11-06-2012, 07:24 AM   #34
BMWDavid
Drives: '89 911, '06 GTI, '13 BRZ
OK, someone needs to come up with a plug and play pigtail adapter. I know when I bought a set of Euro projector foglights for my MK V GTI from ECS Tuning and they had included a pigtail harness so no cutting or splicing. I'm not a fan of any cutting of wires...like to keep things unmolested.
2005 Honda XR650L
1989 Porsche Carrera 3.2 Coupe
2006 VW GTI/DSG
2013 Subaru BRZ WRB Limited 6MT-gone but not forgotten
2014 Nissan Murano SV
BMWDavid is offline   Reply With Quote
Old 11-06-2012, 07:52 AM   #35
OrbitalEllipses
Drives: Attitude
Read what I said. You can MAKE your own pigtail; stock plug on one side and new on the other. Plugs into the H11 bulb AND stock wire harness.
Old 11-06-2012, 11:21 AM   #36
theredtape
Drives: civic,vfr,BRZ
Why not just install led psx24ws to get white light instead of yellow? I found these on amazon they other day. [ame="http://www.amazon.com/PSX24W-Light-Replacement-Bulbs-White/dp/B006FYI5WU"]Amazon.com: PSX24W 9009 2504 LED Fog Light Replacement Bulbs White (Pack of 2): Automotive[/ame]
I also have noticed that my foglights really dont do much besides look cool. I really wish I could get my led running lights to come on with the headlights... That would be neat.
Because Racecar.
theredtape is offline   Reply With Quote
Old 11-06-2012, 04:06 PM   #37
xcelir8brz
Parts are trickling in. Hope to do this conversion this Friday/weekend.
Old 11-07-2012, 03:14 AM   #38
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
I know we can make an adapter for this but if anyone is able to make one of these things; I'm willing to pay for it.
Only way I can think of to make an adapter for this sort of thing is to source out a wrecked vehicle and cut off it's harness for the H11...solder it to a wire on one side but what about the PSX24W side?
How can we deal with that side as the other end is suppose to simulate as the bulb side?
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 11-07-2012, 03:44 AM   #39
OrbitalEllipses
Drives: Attitude
Pigtails of each socket type are commercially available for purchase. Simply splice together. Boom, harness at a fraction of the cost.
Old 11-08-2012, 04:48 PM   #40
xcelir8brz
Received all the parts. Verified they all work good together. Will do the install tomorrow. Will take pictures.
So far, very happy with the quality of all parts. Should take an hour to retrofit both fog lights.
Old 11-09-2012, 07:34 PM   #41
xcelir8brz
Good evening everyone.
So I did the fog light conversion from the original PSX24W to H11.
  • I can tell you that the OEM stock fog light is inferior in quality to that of the other H11 OEM.
  • I can also tell you that these lights are very bright.
  • In addition, I put them in accordingly and tested the light output towards the ground. Nice.
  • But I also had the idea to flip them upside down to see how they would act in parallel to the HIDs as driving lights. Bingo. This is how I left them on the car and they truly do act as driving lights.
Well worth the effort. Extremely happy.
Link: https://xcelir8brz.squarespace.com/p...ersion-how-to/
Here are the pictures:
Thanks again to the original poster of this thread!
Old 11-10-2012, 08:32 PM   #42
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
If you don't want to cut the factory wires you can buy the connectors here: http://autolumination.com/connectors.htm and make your own pigtails. Then it is "plug & play".
xcelir8brz - it was super easy wasn't it...like they were meant to go there before some bean counting accountant found something cheaper.
2023 GR Cup Car
Opie is offline   Reply With Quote
DIY Rear foglight Silverdub DIY (Do-It-Yourself) Guides 159 04-09-2018 12:14 PM
Is foglight wiring in the car? FastLap Scion FR-S / Toyota 86 GT86 General Forum 7 08-26-2012 11:54 PM
Foglight replacement help Zadkiel Cosmetic Modification (Interior/Exterior/Lighting) 4 08-06-2012 11:11 AM
Rear Bumper Foglight kanundrum Cosmetic Modification (Interior/Exterior/Lighting) 2 06-08-2012 12:47 AM
