Old 10-13-2012, 08:56 PM   #29
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
SubaSteve is offline   Reply With Quote
Old 10-14-2012, 07:57 PM   #30
Splat
Drives: FR-S ultramarine
Originally Posted by CBR600RR View Post
^correct so not necessarily because of the 400hp+
kinda was in air becuase of the 400+ so....................
Splat is offline   Reply With Quote
Old 10-14-2012, 08:46 PM   #31
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
Engine wise most likely the piston rings, other than that the clutch will go out.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 10-14-2012, 08:54 PM   #32
ahausheer
Re-member
Drives: Toyota camry
I would say the head gasket.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 10-14-2012, 09:55 PM   #33
Klar
Drives: 2013 FR-S Whiteout
Someday soon, someone will have the full answer.
Klar is offline   Reply With Quote
Old 10-14-2012, 09:57 PM   #34
benster
Drives: none yet
bearings I'm pretty sure. like someone else said, the ringlands will stay alive until there is detonation. heck, they were able to push 1270hp out of a 4.8L V8 ls type engine with 27psi of boost on 110 octane for over 60 pulls and it didnt blow up. oh, the engine had 200k miles too. as long as the tune keeps detonation away we're good.
benster is offline   Reply With Quote
Old 10-15-2012, 12:47 AM   #35
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
This is interesting because the EJ engines have narrow rod bearings and oil pump issues arise every so often. Toyota also uses very narrow bearings around 14mm wide or so. Most other turbo engines use rather wide bearing profiles. 4g63, sr20, and even the k20 have much wider bearings around 17-19mm wide.
Then again, the bearings on the fa20 are much longer. Though narrow, the crank journals seem to be rather large in total diameter, and perhaps this increases oil film surface area.
Coheed is offline   Reply With Quote
Old 10-15-2012, 01:01 AM   #36
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
the rear diff/tranny
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
WolfsFang is offline   Reply With Quote
Old 10-15-2012, 10:54 AM   #37
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
I hope we don't find out until AVO/PL/Dynosty/AP/et all are in the mid 600's
stevo_12v is offline   Reply With Quote
If the ft86 fails... Sea1monkey2 Other Vehicles & General Automotive Discussions 33 07-16-2011 05:57 AM
Top Automotive Fails of 2009 S2KtoFT86 Other Vehicles & General Automotive Discussions 8 01-28-2010 07:13 PM
